11-01-2019, 05:52 PM
#16
Real Name: Evan
Real Name: Evan
Originally Posted by MarkBlack
Looks awesome! Im having the same issue with my antenna, ill be doing this tomorrow!
Awesome! Glad it could help!
2002 Sport Edition Build - 17" Pro Comp Series 40 Wheels - Pro Comp 285/70R17 AT Tires - 3" Toytec Lift Coils, Bilstein 5100 Fronts, OME Rear Coils, Pro Comp Nitrogen Rear Shocks - 1" Toytec Front Diff Drop - Wheelers Off Road SS 4" Extended Rear Brake Lines - Stubby Antenna Mod
11-02-2019, 12:22 PM
#17
So my motor died as well but I took an even simpler path , I pulled up the top of the old antenna and when I got a good grip I pulled real hard until the antenna was forced up about 3/4 of the way up................. and I left it there , and there it stays and reception is great
11-02-2019, 01:28 PM
#18
Simply chopping that thing is genius. I've been meaning to do the tacoma whip or something like this for ages but put it off because of the hassle with buying parts and fishing the cable through to the head unit.
99 SR5 v6 4WD
11 SR5 v6 4WD
11-18-2019, 01:53 PM
#19
Real Name: Evan
Real Name: Evan
It's easy to do and no rewiring is needed! Give it a go
04-09-2020, 04:34 PM
#20
One of the easiest mods yet! Thanks for the write up! Word to the wise...be careful using a flathead to unscrew the cover piece. One slip and you’ve got a nice gouge in the paint. I used a towel behind the nut just in case and glad I did!
04-10-2020, 08:21 PM
#21
I always wondered why it wasn't possible to install the new antennas without taking off the dash and running the wires. Going to add this to my list of projects to do. Mostly use the stereo for bluetooth, so I don't care much for the radio anyhow.
Thanks for your post!
01-29-2021, 07:44 AM
#22
Real Name: David Cowan
Originally Posted by BondoMN
Hey all! I'm not sure if this has been done before or not. My retractable antenna was bent, broken and not doing much for retracting anymore so I figured out a way with some hardware to make this work. I figured I would make a post anyway in case others want to do this.
I started with buying a 4th gen stubby antenna.
Link: The Original Stubby Antenna Replacement for 2002-2013 Toyota 4Runner
It says it fits 02s, but it definitely does not so don't order thinking it will work.
Parts used:
(QTY: 1) #10-32 6" Threaded Rod
(QTY: 2) #10-32 Coupler
(QTY: 2) #10-32 Jam Nut
(QTY: 2) #10-32 Flat Washer
Step 1:
Remove the nut on the base of the antenna
Step 2:
Remove the retractable antenna motor by unscrewing/clipping the fender liner in the wheel well
Step 3:
Cut the bottom of the antenna stem off. I cut about 5" from the top of the antenna (the part you unthreaded the top nut off of).
Step 4:
Take the antenna, unscrew the little short threaded rod that comes with it. With a washer against the antenna followed by the coupler, followed by the jam nut, thread the rod into the antenna until it stops. Once you find that point, tighten the jam nut against the coupler to lock it in place.
Step 5:
Take the other coupler nut and thread it on the bottom of the threaded rod. Put that assembly you've made, with the threaded rod and antenna, through the base of the antenna that you cut. Thread the coupler nut down far enough to be flush with the cut you made (it is not flush in the pic, so you can see what I'm talking about).
Step 6:
Put the other washer you have onto the threaded rod after the coupler nut. It should be just about the same diameter as the antenna base/tube. Then thread on the jam nut on top of that washer and tighten it down.
Step 7:
Remove the stubby antenna and washer from the top of the threaded rod. The threaded rod will fall out, so you can tape it in place if you want to, I just held it in place. Now you're ready to put the antenna assembly back up through the fender. While pushing the antenna back up through the fender, put that top chrome antenna nut back on and tighten it down so that the top of the coupler nut is flush with it (not flush in pic).
Step 8:
Put the washer on top of the chrome antenna nut and screw on the stubby antenna until it's tight. BAM! Now you have a stubby antenna on your 3rd gen! My reception works just as good as before with no issues!
Thanks for reading, I hope this helps someone!
Thanks for the info. I am in the midst of doing this mod now. My antenna tube once cut has a rubber lining on the inside that doesn't allow my coupling nuts to go in easily. Is there a good way to get that rubber lining out?
01-29-2021, 02:56 PM
#23
Real Name: Blair
Real Name: Blair
Looks clean! Question - did you leave power attached to the motor? The reason I killed my antenna was due to the incessant grinding noise the motor made trying to extend the (broken, disconnected) antenna. My motor is unplugged and living in its regular location.
01-29-2021, 08:27 PM
#24
Real Name: Devan
Real Name: Devan
Don't stubby antennas have notoriously shit reception?
02-01-2021, 05:23 PM
#25
Real Name: Patrick
Real Name: Patrick
Yes they do
02-01-2021, 06:25 PM
#26
better solution than just ripping it all out like i did and 3D printing a cap. I really only listen to stuff from my phone or worst case, a CD, so i havent noticed but i probably should have gone this route just incase.
– 96 SR5 5SPD Elocker "the Barnacle"
–02 bmw 540i6
–19 Highlander SE
02-02-2021, 10:00 AM
#27
Real Name: Devan
Real Name: Devan
why not a tacoma whip antenna
takes maybe an hour to do
07-26-2021, 10:21 PM
#28
Put the saw down
Step 3:
You can skip any cutting by removing the plastic “poncho” over the motor cut the tape holding the stem to the motor section. It will just be a couple inches longer but saves some effort.
02-01-2023, 01:20 PM
#29
Parts used:
Step 1:
Step 2:
Step 3:
Step 4:
Step 5:
Step 6:
Step 7:
Step 8:
What is the need for both of the couplers? Any different than just using 2 jam nuts instead?
02-01-2023, 11:35 PM
#30
Real Name: Blair
Real Name: Blair
Since this popped up again......I never (put the time in to figure it out*, I suppose) understood this particular solution. Is the broadcast signal carried from the stubby along the tube you cut? Does the motor unit need to remain in the vehicle at ail? I pulled the antenna out when the extendo-drive gear failed and threw it away and unclipped the power to the motor. I still get FM in the city and a couple strong AM stations. I just live without the radio but I like to throw a baseball game on from time to time. Is there not an antenna wire in there somewhere that can be extended up to the roof rack area? I plugged the antenna hole with a round plastic splash-guard-liner-type fastener.
*Admittedly, I'm not the sharpest tool in the shed and have done no research.
