Old 09-12-2019, 09:18 AM #1
DUK-RNR DUK-RNR is offline
DUK-RNR is on a distinguished road
Changing Power Steering Fluid
What I've found on line is, jack up the front wheels, suck the fluid out of the reservoir, then put fresh fluid in, start the engine turn the steering wheel back and forth, and repeat until the fluid is clear. This takes a long time.
Is there any reason why I can't pull one of the fittings loose from the rack , take the top of the reservoir and let it drain(engine off)
While we're at it doesn't power steering fluid work just as well as Dextron II?
DUK-RNR is offline   Reply With QuoteReply With Quote
Old 09-12-2019, 10:32 AM #2
T4topher's Avatar
T4topher T4topher is offline
T4topher is a glorious beacon of light T4topher is a glorious beacon of light T4topher is a glorious beacon of light T4topher is a glorious beacon of light T4topher is a glorious beacon of light T4topher is a glorious beacon of light
T4topher's Avatar
You probably could do that but you will introduce a lot of air into the system, watch Timmy the toolmans video on YouTube he has 2 for flushing the power steering system. I kind of did a mixture of both of his videos, removed the fluid with a turkey baster and small syringe 5-10 times and then removed the reservoir and cleaned the screen.
T4Tophers build (click here)
T4topher is offline   Reply With QuoteReply With Quote
Old 09-12-2019, 11:18 AM #3
Gearhead4 Gearhead4 is offline
Gearhead4 is on a distinguished road
3rd Gen T4R DIY Maintenance, Repair and Modification Videos - Page 29 - Toyota 4Runner Forum - Largest 4Runner Forum
1997 4Runner SR5 3.4 5spd, 213k, Sonoran 1.2,Crawler 1” body lift, Nitto Ridge Grapplers 255/80/17 on TRD Pro 17” Wheels, Custom Roof Rack.
Gearhead4 is offline   Reply With QuoteReply With Quote
Old 09-12-2019, 11:26 AM #4
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
Do not use power steering fluid. Different additives than transmission fluid.
Old 09-13-2019, 12:40 AM #5
Rockdawg84's Avatar
Rockdawg84 Rockdawg84 is offline
Real Name: Sam
Rockdawg84 will become famous soon enough Rockdawg84 will become famous soon enough
Rockdawg84's Avatar
Real Name: Sam
X2 power steering fluid in our system will eat the seals and you will have a leaky rack very quickly, (ask me how I know). It says on the fill cap of the Power steering to use ATF and you will be very happy.
84 Crawler Rockdawg84s Pic build thread but mostly pics
94 Fzj80 family hauler - sold
98 SR5 supercharged 5speed on 35's, dual locked, dual cased Smokey build Thread
03 SR5 V8, 4x4, 2.5" Icon's with 35's -Sold The Wife's 03 Build Sold
Rockdawg84 is offline   Reply With QuoteReply With Quote
Old 09-13-2019, 01:11 AM #6
pluton's Avatar
pluton pluton is offline
Real Name: Keith
pluton has a spectacular aura about pluton has a spectacular aura about pluton has a spectacular aura about
pluton's Avatar
Real Name: Keith
Suck old fluid from res.
Disconnect res return line.
Route res ret line into waste can.
No need to start engine.
With wheels off ground, work steering wheel back and forth. The old D-ATF gushes out into waste can.
Refill the res with new D-ATF periodically while doing this.
When you have exchanged a sufficient amount of D-ATF, re-attach return line to reservoir and top off res.
Start/run engine. Stop engine. Check level of D-ATF on dipstick and adjust. If it foams up(usually accompanied by a odd whine sound), let it settle for a while and add D-ATF to replace the settled-out air.
Detaching the reservoir in order to clean the screen at the bottom is optional, but will need to be done at some point.
Use only Dexron ATF.
pluton is offline   Reply With QuoteReply With Quote
Old 05-17-2022, 02:48 PM #7
Geejee Geejee is offline
Banned
Geejee is on a distinguished road
Banned
Can I buy a reservoir for a 2.7 without a pump anywhere?
Had hard steering issues in the cold, did the reservoir pull and blasted the filter screen out with brake clean, couldn't get the factory crimps on the PS top tight enough. I got Ps fluid dripping down on belts and splattered into the bay. Belts a squeekin'
Geejee is offline   Reply With QuoteReply With Quote
Old 05-17-2022, 04:54 PM #8
Real Name: Patrick
Real Name: Patrick
Part number for the reservoir is 44306-04020. What do you mean the factory crimps? Did you remove the top of the reservoir that the cap threads on to?
Old 05-17-2022, 05:30 PM #9
Banned
Banned
yes,Followed that aussie advice on the tubes, pried the 6 crimped connectors to get the top off, but you cant get them crush tabs back in right, Im getting leaks around 3 of the 6 coming out the top. It was a good work around but i don't advise, Also ripped the o ring going back in like everybody else. This is not a advised repair, buy a new rez or pump unit.
Old 05-17-2022, 05:30 PM #10
Banned
Banned
Thanks for the P/N
Old 05-17-2022, 05:32 PM #11
Banned
Banned
Thanks for the P/N
I cant grab some pics if others having this issue
Old 05-17-2022, 06:58 PM #12
Pyral's Avatar
Pyral Pyral is offline
Real Name: N/A
Pyral has a spectacular aura about Pyral has a spectacular aura about
Pyral's Avatar
Real Name: N/A
I wouldn't of removed the tabs. Cleaning the screen is best, but when I did it I just disconnected the return line to direct into a waste bucket and had the inlet tube in a large jug of Dex III for the flush.
Dex III is what you should use, some dealerships will use PS fluid. But there is no reason to use power steering fluid when you have access to the correct fluid. Use Dex III.
Having airbubbles in the fluid directly after a flush is unavoidable, just expect some whining after the first 10 minutes or so.
1998 4runner 2.7 manual
Pyral is offline   Reply With QuoteReply With Quote
Old 05-17-2022, 07:59 PM #13
Banned
Banned
didnt remove, pryed them flat, rebendt them back
Old 05-17-2022, 08:15 PM #14
Real Name: Patrick
Real Name: Patrick
That’s the first time I’ve heard of anyone doing that. Everyone else just puts cleaner in the reservoir and shakes vigorously to clean the screen. Definitely wouldn’t recommend prying the tabs off for anyone else that comes across this.
Old 05-17-2022, 08:25 PM #15
Banned
Banned
Toyota Power Steering Pump Reservoir Clean & Assemble.mp4 - YouTube
fluid , loose , power , reservoir , steering
Power steering fluid level low. Do I use ATF or power steering fluid? 4flyer 3rd gen T4Rs 63 02-24-2020 05:07 AM
Power Steering - cap says Dexron ATF, dealer tech says power steering fluid acolsen Maintenance/Detailing 7 02-24-2017 03:00 PM
Low Power Steering Fluid sct6239 4th Gen T4Rs 5 02-02-2012 03:50 PM
power steering fluid?? MD4Runner014 4th Gen T4Rs 4 12-22-2008 09:34 PM
Which power steering fluid? Gryphon Classic T4Rs 2 12-04-2004 11:29 PM
