Old 09-12-2019, 09:18 AM #1
DUK-RNR DUK-RNR is offline
DUK-RNR is on a distinguished road
Changing Power Steering Fluid
What I've found on line is, jack up the front wheels, suck the fluid out of the reservoir, then put fresh fluid in, start the engine turn the steering wheel back and forth, and repeat until the fluid is clear. This takes a long time.
Is there any reason why I can't pull one of the fittings loose from the rack , take the top of the reservoir and let it drain(engine off)
While we're at it doesn't power steering fluid work just as well as Dextron II?
DUK-RNR is offline   Reply With QuoteReply With Quote
Old 09-12-2019, 10:32 AM #2
T4topher's Avatar
T4topher T4topher is offline
T4topher will become famous soon enough T4topher will become famous soon enough
T4topher's Avatar
You probably could do that but you will introduce a lot of air into the system, watch Timmy the toolmans video on YouTube he has 2 for flushing the power steering system. I kind of did a mixture of both of his videos, removed the fluid with a turkey baster and small syringe 5-10 times and then removed the reservoir and cleaned the screen.
T4Tophers build (click here)
T4topher is offline   Reply With QuoteReply With Quote
Old 09-12-2019, 11:18 AM #3
Gearhead4 Gearhead4 is offline
Gearhead4 is on a distinguished road
3rd Gen T4R DIY Maintenance, Repair and Modification Videos - Page 29 - Toyota 4Runner Forum - Largest 4Runner Forum
1997 4Runner SR5 3.4 5spd, 213k, Sonoran 1.2,Crawler 1 body lift, Nitto Ridge Grapplers 255/80/17 on TRD Pro 17 Wheels, Custom Roof Rack.
Gearhead4 is offline   Reply With QuoteReply With Quote
Old 09-12-2019, 11:26 AM #4
Bad Luck Bad Luck is offline
Real Name: Patrick
Bad Luck has a spectacular aura about Bad Luck has a spectacular aura about
Real Name: Patrick
Do not use power steering fluid. Different additives than transmission fluid.
Old 09-13-2019, 12:40 AM #5
Rockdawg84's Avatar
Rockdawg84 Rockdawg84 is offline
Real Name: Sam
Rockdawg84 will become famous soon enough Rockdawg84 will become famous soon enough
MY GARAGE
Rockdawg84's Avatar
Real Name: Sam
MY GARAGE
X2 power steering fluid in our system will eat the seals and you will have a leaky rack very quickly, (ask me how I know). It says on the fill cap of the Power steering to use ATF and you will be very happy.
84 Crawler Rockdawg84s Pic build thread but mostly pics
94 Fzj80 family hauler
98 SR5 supercharged 5speed on 35's, dual locked, dual cased Smokey build Thread
03 SR5 V8, 4x4, 2.5" Icon's with 35's -Sold The Wife's 03 Build Sold
Rockdawg84 is offline   Reply With QuoteReply With Quote
Old 09-13-2019, 01:11 AM #6
pluton's Avatar
pluton pluton is offline
Real Name: Keith
pluton will become famous soon enough
pluton's Avatar
Real Name: Keith
Suck old fluid from res.
Disconnect res return line.
Route res ret line into waste can.
No need to start engine.
With wheels off ground, work steering wheel back and forth. The old D-ATF gushes out into waste can.
Refill the res with new D-ATF periodically while doing this.
When you have exchanged a sufficient amount of D-ATF, re-attach return line to reservoir and top off res.
Start/run engine. Stop engine. Check level of D-ATF on dipstick and adjust. If it foams up(usually accompanied by a odd whine sound), let it settle for a while and add D-ATF to replace the settled-out air.
Detaching the reservoir in order to clean the screen at the bottom is optional, but will need to be done at some point.
Use only Dexron ATF.
pluton is offline   Reply With QuoteReply With Quote
fluid , loose , power , reservoir , steering
Power steering fluid level low. Do I use ATF or power steering fluid? 4flyer 3rd gen T4Rs 60 12-01-2019 04:04 PM
Power Steering - cap says Dexron ATF, dealer tech says power steering fluid acolsen Maintenance/Detailing 7 02-24-2017 03:00 PM
Low Power Steering Fluid sct6239 4th Gen T4Rs 5 02-02-2012 03:50 PM
power steering fluid?? MD4Runner014 4th Gen T4Rs 4 12-22-2008 09:34 PM
Which power steering fluid? Gryphon Classic T4Rs 2 12-04-2004 11:29 PM
Copyright ©2000 - 2019, vBulletin Solutions Inc.
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
Feedback Buttons provided by Advanced Post Thanks / Like (Lite) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Lite) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
Copyright © 2019
