09-12-2019, 02:04 PM
3rd gen won’t start. No noise. Has charge.
Hi,
My 97 4Runner won’t start. There is no noise when I turn the key. I checked the battery with a multimeter and got a reading of 14, so I don’t think that’s the issue.
Before this every once in a while it wouldn’t quite start, but I’d pump the gas a couple times and it would start. Not sure what’s going on. Would love some advice and to avoid a tow.
Thanks so much!
09-12-2019, 03:15 PM
Real Name: John
Real Name: John
Idle Air Control Solenoid (IAC) most likely
SILVER 2000 4runner Limited TOTALED
WHITE/SILVER 1999 4runner Limited l Rear Locker l Tundra/890 coils | 5100 Bilsteins all around | Sonoran Steel Bumpstops l 199 mm Tundra brake upgrade | SCS Matte Gray Ray10 Rims | 275 70 17 BFG KO2 tires | LR UCAs | EIMKEITH panhard brackets | LED interior upgrade l Rear LED tailights l Pioneer AVH-X5700BHS Alpine Type "R" speakers NVX JAD800.4 Class D Amp Kenwood Under seat Subwoofer l Front window tint 20% l Weathertech window visors and floormats l OutGear Solutions Full Length roofrack l Morimoto 40" LED lightbar
09-12-2019, 03:26 PM
Real Name: Patrick
Real Name: Patrick
How would that cause the vehicle to not turn over or even click?
09-12-2019, 03:45 PM
You gotta give a little more information I think.
When you say no noise, you mean no turn over. Do you hear the starter solenoid click? Faint clicking from the lower engine or truly nothing?
What's happening with dash and dome light while this is happening? Do they dim or shut off when you try to start it? 14 V on the battery is kind of high unless you had just shut the truck off or had it running. Resting battery would be more like 12.6 to 12.8v.
Pumping the gas and slow to start is likely a seperate issue.
-1993 Corolla Wagon 7AFE
-2001 Echo D.D.
09-12-2019, 03:52 PM
Real Name: John
Real Name: John
I guess I focused on the one part saying that it only started when you gave it gas. The post is somewhat confusing because you say you have 14V at the battery which implies that the truck is running.
No start no click most likely would be the starter. Less likely a relay.
09-12-2019, 03:53 PM
Real Name: Jerod
Real Name: Jerod
Classic starter contact failure. I think at least 1/4 of us on here have encountered it, it's a very common part to fail. The starter is located on the passenger's side of the engine, opposite to where the oil filter is on the driver's side. Get yourself a rod or long screwdriver and tap it with a hammer to jolt the starter. If it cranks, your contacts are worn down and won't carry a current anymore. There's some video tutorials on how to replace the contacts. It's a $30 repair but can take several hours depending on how hard it is to remove the starter from the engine bay (or not at all in my case!)
09-12-2019, 08:11 PM
if it cranks over but doesn't start then it could be the fuel pump.
09-12-2019, 09:26 PM
It doesn’t click, or turn over, it’s just completely silent. The whole electrical system seems fine.
It sat for a week before it wouldn’t start. It sat for a week a few weeks before that and I got the same result, but then I pumped the gas and tried again and it fired up.
I tried the same thing this time but I get nothing. I’m interested in giving the started a knock. Is that a two person job? Does one person need to be knocking it while the key is turned?
09-12-2019, 10:08 PM
If your starter is bad, tapping on it will probably not help but it is worth a shot. It's a one man job. Use something non metallic if you tap on your starter so that you don't accidentally cause a short. Pumping the gas was probably coincidental. Is this auto or manual? Do your battery connections look good and clean? Do you have lights on the dash with keys in the ignition? Explain what you mean when you say that the whole electrical system seems fine.
1997 Toyota 4Runner
09-12-2019, 10:32 PM
check and make sure the 7.5 amp sta fuse is good also the starter relay is'good.
09-12-2019, 10:51 PM
Once you know you've got power through the fuse and relay make sure it's actually getting to the starter, there's a 4 pin connector on the bottom of the fuse box where the harness for starter and alternator plugs in.
Sent from my JSN-L23 using Tapatalk
'97 3RZ 5 Speed "FrankenRunner" ( Build Thread) - Dormant
The "shitmobile" 500$ 3RZ Auto 4Runner - ( Saved from the Scrapyard: Resurrecting a 500$ 3rd Gen
02 Tacoma Double Cab, mid-travel, locked, armored, supercharged and riced. (Longbed and 5 speed in the works)
09-13-2019, 12:14 AM
It’s manual. Battery connection at the posts look good. Yes, I have lights on dash, headlights, dome lights, windows, everything works + a good multimeter reading. I can take some pictures or video tomorrow...just not sure what there is to see
09-13-2019, 12:32 AM
It's a manual. Good info to have in your signature so we can help you.
Could your clutch switch be acting up? At the best we have to get the clutch right in the carpet to start the truck. Next time it does it, try the clutch cancel switch and see if anything improves. Not having the clutch switch working would absolutely result in silence.
-2001 Echo D.D.
09-13-2019, 10:24 AM
I'd focus on these three things:
Try starting with clutch cancel switch
Be sure the battery terminals connections are clean inside and out.
Lastly, the starter contacts are a likely problem but they usually give some warning (intermittent cranking when you turn the key).
I found removing the starter quite easy on my '97 5-speed when I replaced the contacts. Might have been attributed to the 1" BL though. I also have a scissor lift in my garage.
'97 SR5 V6 4x4 | 5-speed | e-locker | 33's
09-13-2019, 12:17 PM
It sat for a week before it wouldn’t start (145,000 miles).. It sat for a week a few weeks before that and I got the same result, but then I pumped the gas and tried again and it fired up.
I have replaced 4 starters in my 2005 V6 SR5. The OEM failed after 4 years. I had it rebuilt and that failed after 1 year.
I brought the rebuild shop an AM starter instead of taking their offer to rebuild the OEM again. The new AM starter lasted 4 years, and when it failed after 4 years (again), I replaced it with a Quality Built with a lifetime warrantee ($120 at Amazon), and that's been in the 4runner for 2 years.
I also purchased a backup starter from Amazon.com for $75 - for when the Quality Built fails and I send it back for a new one (kept the receipts, the nice box and called the company). https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
All 4 failures were identical. You turned the key and nothing. No click. No crank. Nothing.
I'm in the Bahamas. Starter from the dealer installed was over $600. There's a 65% custom's duty on importing your parts in this country.
You can usually light tap a starter that fails once or twice to get it to crank, but in my experience it is best to just replace.
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
