Old 09-12-2019, 02:50 PM #1
TheShowtime TheShowtime is offline
TheShowtime is on a distinguished road
4x4 question
Hey all, I have a 01 sport with the center diff lock, was wondering can I use the center diff lock when I’m not in 4low? Also will I be able to turn with them on without messing anything up? And center diff lock means that all 4 wheels are spinning at the same time?
Sorry for the newbie questions this is my first 4x4 I ever owned.
TheShowtime is offline   Reply With QuoteReply With Quote
Old 09-12-2019, 03:00 PM #2
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
Read this:
T-case Differences (all years of 3rd gens).. transfer case, AWD, multi-mode
Old 09-12-2019, 03:03 PM #3
rightyouareken's Avatar
rightyouareken rightyouareken is offline
rightyouareken has a spectacular aura about rightyouareken has a spectacular aura about rightyouareken has a spectacular aura about
Yes you can use center diff lock in 4Hi. But you shouldn't do so on pavement unless it's icy/snowy or you're only driving dead straight. It locks the front and rear axles to spin at the same speed, which they don't when you turn. If you want to use 4WD on pavement, like when it's partly snowy or icy, keep the center diff lock unlocked to prevent binding and damage.
2020 4Runner Venture
2002 4Runner SR5 4WD (sold)
1998 BMW M3/4/5
rightyouareken is offline   Reply With QuoteReply With Quote
Old 09-12-2019, 04:02 PM #4
Thanks for the replies!
Old 09-13-2019, 12:18 AM #5
watersna watersna is offline
watersna is on a distinguished road
The center diff lock doesn't mean that all 4 wheels are getting power, only that the front and rear axles are receiving equal power. Without locks in the front or rear diffs, those wheels are still free to spin independently of the other wheel on its axle.
It's fint to turn on a locked center diff as long as you are on a low-traction surface, like snow, mud, dirt roads, gravel, etc. You shouldn't have the center diff locked on high-traction surfaces like pavement.
My general rule is 2wd on pavement, locked center diff on dirt, and AWD/unlocked center diff in variable conditions (wet pavement, decaying/patchy paved roads, etc.) In dry conditions most dirt/gravel roads won't need 4wd but I pop into it anyway because the system wants to be exercised regularly and my daily driving is all paved.
Using the center diff lock is fine in 4HI as long as you are on a low-traction surface (as with 4LO)
watersna is offline   Reply With QuoteReply With Quote
4x4 , center , diff , lock , means
Quick question tundra fabtech dirt logic question Diggo 3rd gen T4Rs 3 06-09-2016 02:33 PM
Question about 2013 Limited vs SR5 rim & tire question? duckman06 5th gen T4Rs 21 01-09-2013 07:06 AM
2003 V8 90k Maint. Question + Steering Question zerowkul98 Maintenance/Detailing 1 10-21-2010 07:35 AM
Pro Comp Light Bar Question- Tire Rim Question rngesci 3rd gen T4Rs 1 10-25-2008 03:04 PM
