Old 09-12-2019, 04:44 PM #1
pineapple pineapple is offline
pineapple is on a distinguished road
Clunking into Drive
hi there, just bought at 98 4runner SR5 with 237 000 miles for 2200$.
the transmission makes a metallic CLUNK sound when i shift into D. not R or N.
i think it always makes it regardless of temps. havent tested up/down hills.
tranny fluid level is good, and color seems fine (though im replacing all the fluids next week)
anybody have any guesses as to what cuases this? i dont much mind it as long as its not an indicator of something bad coming down the road.
thanks!
pineapple is offline   Reply With QuoteReply With Quote
Old 09-12-2019, 05:05 PM #2
JMat's Avatar
JMat JMat is offline
JMat will become famous soon enough
JMat's Avatar
Could it be u-joints?
1998 Toyota 4Runner 3.4 4x4 with 340,000 miles.
199mm TBU-Bilstein 4600-'99 Tall Springs(Rear).Almost Totally Stock
1997 Toyota 4Runner 3.4 4x4 with 247k miles-Project car
JMat is offline   Reply With QuoteReply With Quote
Old 09-12-2019, 05:19 PM #3
Brian.'s Avatar
Brian. Brian. is offline
Brian. is a name known to all Brian. is a name known to all Brian. is a name known to all Brian. is a name known to all Brian. is a name known to all Brian. is a name known to all
Brian.'s Avatar
Hit the zerk fittings with some grease (there are 4,368 of the suckers under there... ok, maybe not Quite that many). My last 2 Toyotas do that when the driveshaft is running low:
Drive/Prop Shaft Greasing Guide - Toyota 4Runner Forum - Largest 4Runner Forum
Brian. is offline   Reply With QuoteReply With Quote
Old 09-12-2019, 05:39 PM #4
if it was loose u joints, shouldnt it clunk when going into reverse as well?
Old 09-12-2019, 05:39 PM #5
will do! thanks for the link
Old 09-13-2019, 12:20 PM #6
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
Mine clunks when going into drive while holding the brake, then clunk again while going into reverse if I continue to hold the brake. Mine is from excessive backlash in my rear differential.
Old 09-16-2019, 06:59 PM #7
my mechanic diagnosed it to VERY worn out driveshaft joints.
im told the whole assembly looked deplorable, its being replaced today.
Old 01-28-2020, 08:47 AM #8
Pj Benn Pj Benn is offline
Pj Benn is on a distinguished road
Any more clunking after replacing?
Pj Benn is offline   Reply With QuoteReply With Quote
Old 01-28-2020, 02:00 PM #9
VernySanders's Avatar
VernySanders VernySanders is offline
Real Name: Werner
VernySanders will become famous soon enough VernySanders will become famous soon enough
Real Name: Werner
Backlash is very easy to adjust on these 3rd members if you're ever interested in doing it I can show you how. I guess tell you how since this is a website lol. (Unless you know already)
VernySanders is offline   Reply With QuoteReply With Quote
Old 01-28-2020, 03:06 PM #10
Real Name: Patrick
Real Name: Patrick
Mine isn't all that bad since I adjusted my transmission line pressure down from where the PO had it. I rarely notice it unless I change directions without stopping first. Thanks for the offer but I'm just going to ignore it until I regear.
Old 02-04-2020, 10:19 AM #11
mmw0k7o mmw0k7o is offline
mmw0k7o is on a distinguished road
I also have a slight "clunk" when in forward. It doesn't do it when I shift from park into forward nor in reverse. I notice it when I take my foot off the gas at low speeds or coming to a stop. When I reapply gas it occasionally clunks. Was this similar to your experience? I'll inspect my drive shaft joints today and grease all the zerk fittings shown in Brian's link.
I'd love to hear if the replaced joints solved your problem...
mmw0k7o is offline   Reply With QuoteReply With Quote
Old 02-05-2020, 08:39 AM #12
Update on my clunk...
Greased the 8 zerk fittings on the drive shaft and the clunk is gone!!! I can't believe after 18 years of owning this car the low speed transmission clunk is finally solved. My own fault for not greasing the zerks for 18 years.
This just goes to show that the dealerships really have no clue or just don't care unless they can make an easy buck. I brought this car to the dealership back in 2002-3 while the car was still under warranty to complain about the clunk thinking it was the transmission. They said it was perfectly normal.
They suck...you all rule!!! Thank you Brian for the awesome link and thank you Nelsonmd for some priceless info!
I do have a confession to make though... I didn't use moly grease. I already had Calcium Sulfonate grease in my gun, so I just used it. I hope this doesn't destroy the joints. It is also rated NLGI GC-LB #2. I've used it for years in my boat trailer axle hubs. I guess this will be an experiment.
Old 02-05-2020, 09:40 AM #13
Nice! Glad that worked for you. My issue is the same as op’s except Its a groan not a clunk. Hopefully putting some grease In my fittings solves my problem too.
Old 02-05-2023, 11:20 AM #14
TX4Running's Avatar
TX4Running TX4Running is offline
TX4Running is on a distinguished road
TX4Running's Avatar
How has the drive shaft done with the calcium sulfonate grease?
James
2001 4Runner SR5 4WD - 231 mm TBU, B&M 70264 external transmission cooler, Magnefine external transmission filter
TX4Running is offline   Reply With QuoteReply With Quote
clunking , fluids , makes , replacing , week
VIDEO ATTACHED.Front Drive Shaft/Differential odd movement and loud clunking/clicking redrunn Classic T4Rs 5 10-06-2015 02:43 PM
2000 limited, clunking in drive and reverse mtyink 3rd gen T4Rs 6 07-31-2014 01:32 PM
Starts then dies. Will start an drive on 3rd, 4th try; will drive fine til ~1800RPM Ryan'004R 3rd gen T4Rs 4 07-16-2014 10:23 PM
4wd clunking and drive shaft is binding when engaged challenger 3rd gen T4Rs 5 01-05-2011 04:47 PM
HELP, Clunking noise on test drive, newbie needs advice. jpintx 4th Gen T4Rs 3 02-26-2010 04:36 PM
