Old 04-14-2011, 01:01 PM #1
Annalea Annalea is offline
Annalea is on a distinguished road
Rear latch busted . . . is it tough to replace?
Hi there . . . total newb here.
I'm a reasonably handy woman, but know better than to jump in without a little research. The rear latch on my 4Runner has been stiff/sticky for a while, and not knowing any better, we used WD-40 to get it to loosen up.
Well, now it's gummed up even more, and I believe it has broken. The piece that actually moves around the metal loop on the body to keep the hatch shut wobbles some, and what looks like a plastic-type covering on it has peeled partly away. It looks like it MIGHT be a simple switch to put a new one in, but I know my 4R well enough to know that few things are as simple as they seem with Toyotas. ;)
I'm thinking that calling around to the salvage yards to find a replacement might be a good idea, as well as a shop I trust nearby (for pricing comparison).
Any experiences anyone can share on this, so I don't have to repeat someone else's mistakes?
Thanks so much!
'96 SR5, owned since '98.
Annalea is offline   Reply With QuoteReply With Quote
Old 04-14-2011, 05:26 PM #2
Thanks so much, bootown. That's exactly the type of info I was looking for. Removing trim has been intimidating for me, because I can't see what I'm doing; your instructions demystify the process.
You can bet I'll post more ?'s as I come across them . . . it's rainy season here, and we don't have covered parking for the 4Runner. This has got to be fixed asap. Thanks again!
Anybody else want to chime in?
Old 04-14-2011, 07:04 PM #3
jhaag's Avatar
jhaag jhaag is offline
jhaag is on a distinguished road
jhaag's Avatar
i just did this, myself. i had no luck finding one at a salvage yard, which i thought was a good thing. lol a new one was $70 from the dealer. you'll have to go from the inside. its held on by two nuts on studs and not too difficult, just a tough reach around the window actuator. also, you should roll the window down first so that it will be easier to pull up the weatherstripping with the inside trim, and roll it back up to change the handle.
hope this helps.
good luck!
jhaag is offline   Reply With QuoteReply With Quote
Old 04-15-2011, 06:04 AM #4
maxspeed96ct's Avatar
maxspeed96ct maxspeed96ct is offline
maxspeed96ct is on a distinguished road
I pulled my handle and plate trim off when i painted it. And it was a pain , i m.f-ed it for some time.
theres two bolts that hold the handle that are almost impossibe to reach because of the white cover for the rear windor gear and motor.
g/luck.
99 4runner sold and missed
now shopping for a 2nd gen taco !
maxspeed96ct is offline   Reply With QuoteReply With Quote
Old 04-15-2011, 01:40 PM #5
jhaag's Avatar
jhaag's Avatar
Whoops. I thought this was for the handle. Sorry. But I replaced the latch too. It is cable driven and pretty easy to get to. The cable goes from the latch to the opener linkage which is off to the side near the lock so it's not too difficult to access. Sorry for the confusion.
Old 04-15-2011, 02:14 PM #6
98OzarksRunner's Avatar
98OzarksRunner 98OzarksRunner is offline
98OzarksRunner is on a distinguished road
When I bought it, my truck was literally full of a fine brown dust, like flour (I removed seats, carpet, panels, etc. and washed it all down). It had jammed up everything, including the rear latch. I took it out and sprayed WD-40 into it until it ran out clear (which was about a minute!). I put it back in and it works fine. You might try some more WD-40, but I did have to take it out and work it to loosen it up. The plastic coating on mine is coming off too but doesn't bother it.
What bootown said is how to get to it. It's pretty easy to do.
98OzarksRunner is offline   Reply With QuoteReply With Quote
Old 04-15-2011, 04:07 PM #7
Thanks, OzarksRunner. I've run WD-40 through it, and it comes out clear . . . I don't know what's gumming it up, but it's stiff stuff.
I'll probably end up getting a new one, as I don't want to go through the trouble of replacing it, and then have the same trouble in a few months. ;)
Old 04-15-2011, 04:14 PM #8
jhaag's Avatar
jhaag's Avatar
I just remembered that the latch you need was $143 from my local dealer. But I got one online through a nationwide salvage parts locator for $50 shipped.
Old 04-16-2011, 01:15 AM #9
Could you a name, jhaag, or should I Google?
Old 04-16-2011, 10:04 AM #10
jhaag's Avatar
jhaag's Avatar
actually, i went back through my email and found the actual yard it came from. its in colorado called the yota yard and they specialize in 4runner parts. they were really nice to deal with. Yota Yard - Used Toyota Parts
Old 04-16-2011, 10:53 AM #11
marmotan's Avatar
marmotan marmotan is offline
marmotan is on a distinguished road
marmotan's Avatar
I posted a Picasaweb photo set that will walk you through the replacement process step-by-step. Send me a PM for the link.
2013 SR5 4x4
marmotan is offline   Reply With QuoteReply With Quote
Old 04-16-2011, 12:29 PM #12
Wow. Talk about helpful. Thanks so much, you two!
(And why a pm, marmotan? Links are allowed in the forums . . . )
Old 04-16-2011, 05:30 PM #13
Flifisher's Avatar
Flifisher Flifisher is offline
Flifisher is on a distinguished road
Flifisher's Avatar
Mine is the same....I have been searching for a replacement latch mounting assembly...I tried to get it off a while back, but could not get to it. I then tried to remove the license plate plastic shroud, and broke a couple of pins holding it on...I have stopped to regain some composure...I have to get some of the small plastic pins for replacement before I proceed. I know the latch assembly will be completely broken soon, I'll have to take it all apart then.
Great luck!!
'98 Limited Edition 3.4 V6 4x4(Desert Dune),Blue LED Interior Illumination Mod Completed, deckplate MOD completed, Grill Mod Cmpltd, ISR MOD Completed,Stock Rims to be painted Graphite(Summer 2011)-Dunlop RVXT's,Custom Front and Rear Bumpers;Summer 2011
Flifisher is offline   Reply With QuoteReply With Quote
Old 04-16-2011, 05:51 PM #14
Ditto. That would be a great idea.
(And fwiw, one of my personal internet safety practices is not to follow links from near-strangers. As nice as you may be, marmotan, I'm afraid I won't follow a link you provide to images. So, by all means, post it here.)
Old 04-16-2011, 07:54 PM #15
marmotan's Avatar
marmotan's Avatar
Picasaweb is the fastest writeup method for Picasa users, and I've shared it with several forum members over the last few months. But, I'm happy to transfer it to this thread if it makes it easier on folks. I used PostImage.org for the image hosting. Here goes:
Start by removing this bolt:
gently pry your way around the inside trim panel with a flat, blunt object. you'll hear the anchors pop one by one.
the plastic panel being pulled away from the door:
this is what you will see - the photo is taken right-side up. i also pulled off the rubber strip running along the top of the red metal panel before taking this shot. remove the bolts around the black metal panel. don't mess with any of the electronics.
you'll then have to pop out these nylon anchors.
this wiring assembly is anchored to the sheet metal via this rubber post - give it a yank.
the old latch.
the old latch removed, showing the dusty/corroded latch assembly.
this is the other end of the latch assembly - you have to unplug the wiring harness and undo the cable end from the slotted armature.
new latch on top, old one below.
part number for the new latch for my 1997 runner.
another side-by-side.
by the way, before i started i supported the black metal panel with some string so the wiring didn't get stressed.
great time to clean up the panel!
the new latch bolted in, using the 3 old bolts.
Be sure to give your new latch a little lube once or twice a year.
2013 SR5 4x4
Rear Seat Latch Clunk wjamyers 3rd gen T4Rs 4 02-09-2011 05:42 PM
rear latch s2000 3rd gen T4Rs 0 10-20-2010 06:53 PM
Tpms/rear latch gbc 4th Gen T4Rs 3 03-08-2010 03:12 PM
Rear power latch Gofficer Problems & Warranty Issues 0 11-17-2009 06:20 PM
4th gen busted rear diff question Camprunner 4th Gen T4Rs 4 12-04-2007 12:54 PM
