Old 09-14-2019, 11:39 AM #1
wrpsuite wrpsuite is offline
wrpsuite is on a distinguished road
Wheel bearings good till not?
Going through things after 185k and wonder about wheel bearings. Are the good until they make noise or is there a benefit to replacing the bearing and hub early?
wrpsuite is offline   Reply With QuoteReply With Quote
Old 09-14-2019, 11:51 AM #2
Brian.'s Avatar
Brian. Brian. is offline
Brian. is a name known to all Brian. is a name known to all Brian. is a name known to all Brian. is a name known to all Brian. is a name known to all Brian. is a name known to all
Brian.'s Avatar
More or less, they're good till they're not. You can absolutely change them as preventative, and I've done that on other vehicles (my wifes commuter, she was doing 500 miles a week through BFE Wyoming, half on Monday and half on Friday ~ I didn't want her to have issues). Just depends on your level of risk tolerance.
I'll probably replace mine before they fail as I go in and do the rear seals (there's a little goo in the ABS area) and when I put manual hubs on the front (fuel economy, because I want to) just as a course of addressing age, known failure points and doing mods. But I don't worry about them. I remember driving a car on a road-trip where one went out over 600 miles from home. Howled the whole way home, which was annoying, but it never felt unsafe.
Brian. is offline   Reply With QuoteReply With Quote
Old 09-14-2019, 04:36 PM #3
brillo_76's Avatar
brillo_76 brillo_76 is online now
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
You can also feel the bearings and see if they are warn.. when you spin them they should he very smooth and free of play. :]
brillo_76 is online now   Reply With QuoteReply With Quote
Old 09-14-2019, 05:24 PM #4
UnderFire's Avatar
UnderFire UnderFire is offline
UnderFire has a spectacular aura about UnderFire has a spectacular aura about UnderFire has a spectacular aura about
UnderFire's Avatar
They are noisy when they start to eat themselves and give you plenty of warning. For reference the only 2 times I've seen bad bearings they were presumably stock bearings with over 300k.
Sent from my JSN-L23 using Tapatalk
'97 3RZ 5 Speed "FrankenRunner" (Build Thread) - Dormant
The "shitmobile" 500$ 3RZ Auto 4Runner - (Saved from the Scrapyard: Resurrecting a 500$ 3rd Gen
02 Tacoma Double Cab, mid-travel, locked, armored, supercharged and riced. (Longbed and 5 speed in the works)
UnderFire is offline   Reply With QuoteReply With Quote
Old 09-14-2019, 05:32 PM #5
dogtail's Avatar
dogtail dogtail is offline
Real Name: Keith
dogtail has a spectacular aura about dogtail has a spectacular aura about
dogtail's Avatar
Real Name: Keith
Plan on at least 300K on front and rear wheel bearings with conventional use. You're better off not messing with them at all til after that. I can verify that with 3 original bearing rigs I ran over that.
*1999 3.4L, 4wd/5spd, swapped motor and trans, heavy use DD, seasonal rust proofing using WD-40 only
*2000 3.4L, 4wd/5spd, parts rig, picking the carcass
dogtail is offline   Reply With QuoteReply With Quote
Old 09-14-2019, 06:28 PM #6
nobb nobb is offline
nobb is on a distinguished road
390,000 kms and my front bearings are still fine. Had to replace the rears because of the axle seal leak @ 350,000 kms. When bearings start to fail, they make noise which gradually gets worse over time. Even when they make noise there's usually a ton of time left of which you'd have to be severely negligent for the wheels to fall off. Keep in mind that the front bearings are significantly beefier than the rears...there is ALOT of room left for error from the time they start making noise to when they are no longer safe.
nobb is offline   Reply With QuoteReply With Quote
Old 09-14-2019, 07:17 PM #7
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
I agree with dotail and underfire. I would seriously consider changing all wheel bearings by 300K . Can they last longer then that... In certain conditions sure they can lost longer.. However, think of how many revolutions those wheel bearings did at 300K miles. If they are not going bad by then.. They will be on the way to failing.
Old 09-15-2019, 11:30 AM #8
LittleCaesar's Avatar
LittleCaesar LittleCaesar is offline
LittleCaesar is just really nice LittleCaesar is just really nice LittleCaesar is just really nice LittleCaesar is just really nice
At that mileage, leave them alone unless they are giving you problems.
LittleCaesar is offline   Reply With QuoteReply With Quote
bearings , benefit , good , replacing , wheel
New wheel bearings still good after a little abuse? 4eigner 3rd gen T4Rs 9 10-31-2015 06:47 PM
wheel bearings Stgo2019 3rd gen T4Rs 5 08-25-2013 03:31 PM
10% Tire coupon for tirebuyer.com good till 5/13/13 Coveman 4th Gen T4Rs 1 05-12-2013 12:53 PM
Wheel Bearings samdajellybeenie14 3rd gen T4Rs 3 08-20-2011 01:10 AM
Wheel Bearings DIY HELP 2K34R Problems & Warranty Issues 2 04-16-2008 04:07 PM
