Old 09-14-2019, 05:10 PM #1
plcfcng's Avatar
plcfcng plcfcng is offline
Location: Southern California (please don't hold it against me)
Real Name: michael
plcfcng is on a distinguished road
plcfcng's Avatar
Real Name: michael
Early and Late Gen 3
Is there a difference between the quality of the build in early Gen 3's and Later built ones. I have 2 2001 a Sport and SR5. I built a 1997 Limited for my sister inlaw I noticed the doors felt smoother opening closing so I don't know if it's how it was built or how it was taken care of. Both the 2001's feel the same and are fine but just different.
plcfcng is offline   Reply With QuoteReply With Quote
Old 09-14-2019, 05:47 PM #2
UnderFire's Avatar
UnderFire UnderFire is offline
UnderFire will become famous soon enough UnderFire will become famous soon enough
UnderFire's Avatar
Nothing major that I've noticed. All limited models came with a little extra sound deadening, doesn't matter what year. The main areas of improvement in the newer years are ergonomics in the controls, different more resilient fabric in the cloth equipped models and improved lighting equipment as the years went on. Not much changed structurally or mechanically, minor electronic changes were made throughout the years.
Sent from my JSN-L23 using Tapatalk
'97 3RZ 5 Speed "FrankenRunner" (Build Thread) - Tundra TRD/5100's/LC 8 Wraps Lift | 1" BL | 4.88's F/R | 35x15 Toyo M/T on 15x10 AR23's | 4WD Conversion | Manual Hub Conversion | NWTI Front Bumper | Tan Interior Conversion | Infiniti QX4 Seat Swap | 99+ Upgrades | OTRATTW Switches| Yakima rack setup | 42" LED Bars F/R | 2x Lightforce Genesis 210 HID's
UnderFire is offline   Reply With QuoteReply With Quote
Old 09-14-2019, 06:10 PM #3
MaineRunna's Avatar
MaineRunna MaineRunna is offline
MaineRunna will become famous soon enough MaineRunna will become famous soon enough
MY GARAGE
MaineRunna's Avatar
MY GARAGE
Quality-wise and structurally they are the same. All 4Runners are built in Japan and Q/C is good. Also 96-02 Toyotas are some of the best. There are some changes with electronics, ABS, lighting, stereo and heater controls. In some ways 01 and 02 T4Rs are more like 4th gens.
98 SR5 4X4 5spd, desert dune metallic, Toytech Eibach 3" lift, 1" body lift, 4XInnovations bumpers, Doug Thorely Headers, Magna-flow converter, RCI skid plate, SPC UCA's & rear LCA's, Tundra brakes, BFG 255/85R16 Mud Terrain T/A's 225,000 miles
MaineRunna is offline   Reply With QuoteReply With Quote
Old 09-14-2019, 08:29 PM #4
jgue467's Avatar
jgue467 jgue467 is offline
jgue467 will become famous soon enough
jgue467's Avatar
Originally Posted by plcfcng View Post
doors felt smoother opening closing ...
Differences yet not on the doors...
enjoy the runner.
2001 Limited 4WD - 319K - SunfireRed\Thunder Cloud; - 265/75/16 Michelin A/T2s - Fat Pat's 1.5" BL
StopTech slotted rotors - Magnefine trans filter - In series trans cooler, Original: paint, engine, 4wd, trans, mstr cyl & brake system, rear axle seals, A/C, steering pump, steering rack, front/center/rear diffs, all electric motors, seat heaters and on and on. WooHoo!!
Old 09-14-2019, 11:39 PM #5
plcfcng's Avatar
Real Name: michael
plcfcng's Avatar
Real Name: michael
i have settled into these 2 2001's now and long distance care for the 1997. Still work on some of the P and M just enjoying driving them. Trips to Northern CA from So Cal as well as Las Vegas have no fear of break downs even at 250,000 miles.
Old 09-17-2019, 07:45 AM #6
denlion81 denlion81 is offline
denlion81 is on a distinguished road
MY GARAGE
MY GARAGE
Lol. That definitely doesn't apply to my 1996 LTD. The most noisy car I have ever owned ))) But that doesn't stop me from loving it anyway )
denlion81 is offline   Reply With QuoteReply With Quote
Old 09-17-2019, 08:45 AM #7
jgue467's Avatar
jgue467's Avatar
...Trips to Northern CA from So Cal as well as Las Vegas have no fear of break downs even at 250,000 miles.
I drove mine from Austin to San Diego, PCH to SF, Sac, Tahao, Steamboat and up I70 to Denver south/west thru Rockies again and back home past summer, epic and yeah reliable! Never gave it a second thought about pushing a vehicle with over 300k thru that. Enjoy the Runner.
Old 09-17-2019, 10:19 AM #8
brillo_76's Avatar
brillo_76 brillo_76 is online now
Real Name: Jon
brillo_76 has a spectacular aura about brillo_76 has a spectacular aura about
MY GARAGE
brillo_76's Avatar
Real Name: Jon
MY GARAGE
The differences are settle.. Like others have stated Chassis Engines are same. Gas tank lid different after the emissions changes of the late models.. Interior compartment center console slightly different as well as the compartment between the seats. Earlier gen have one cat and the evap box and charcoal canister in the front. Later ones have all that by the gas tank and 2 cats. The trailer 4 pin control box different in the earlier vs later. Transfer case different lots of the sr5 earlier as J configuration. While the later is 2 position and a button.
There is even differences between the Base, SR5 and Limited models. However, one thing is certain. If maintenance is done and issues fixed as they come up. These run for an extremely long time. Just getting broke in at 200K-300K miles.
Even seen someone with 720K one engine rebuild and 5 clutches in it. Mostly 300K to 400K when the engine needs a good internal rebuild if that. Its hard to beat the Cast iron Blocks of the 3rd Gen 4 runners. Anything newer went to aluminum blocks and interference timing chains. I enjoy mine.. ;-) I see lots of other folks are enjoying theirs as well.
1997 4X4 V6 5 Speed Sr5 4 Runner (97 5 speed )
1997 4X4 V6 Red limited 4 Runner (97 Limited)
1998 4X4 V6 Sr5 Red 4 Runner (98 Tetanus1 )
1998 4X4 V6 Sr5 Silver 4 Runner (98 Tetanus2)
2001 4X4 V6 Sport Green 4 Runner (01 Green Sport)
brillo_76 is online now   Reply With QuoteReply With Quote
Old 09-17-2019, 12:15 PM #9
gamefreakgc's Avatar
Real Name: Jerod
gamefreakgc is just really nice gamefreakgc is just really nice gamefreakgc is just really nice gamefreakgc is just really nice
Real Name: Jerod
The main difference is the engine sensors & interior electronics. The 96-98's have more manual controls like pushrods for the climate controls and a manual throttle cable. The 01-02's have a lot more digital screens and the engine bay has more sensors. Slightly higher maintenance since the interior electronics are known to go bad ever so often, when compared to a knob and pushrod which will never go bad. Still great overall though, just minor differences. 01-02's do have AWD though, I do wish my 98 had it in the rain.
'98 4Runner SR5 - 4x4 5VZ-FE Supercharged - 222k miles, JDM engine @ 221k
AEM F/IC 6 Piggyback, 2.1" pulley at 11 PSI, Go-Fast Parts
Old 09-17-2019, 12:40 PM #10
plcfcng's Avatar
Real Name: michael
plcfcng's Avatar
Real Name: michael
i was aware of the component differences as I own 2 2001's I just felt a more solid feeling when entering and exiting the 1997. Don't get me wrong very happy with the 2001's that the wife and I drive. I had to make a cup holder for the 97 I build for my sister inlaw everyone knows about the 98 and older funky little holder. Thanks for all the input.
built , closing , early , gen , opening
late 4rd or early 5th gen advice? wquiles 5th gen T4Rs 9 08-30-2019 07:03 PM
Early versus late 3rd gen T4R Carnutbmw 3rd gen T4Rs 24 12-31-2018 05:22 AM
Which drives better, an early 3rd gen or a late 3rd gen? StreetCreeper 3rd gen T4Rs 60 02-10-2016 07:24 PM
Anyone else listen to late 90s, early 2000s rock? Millerad1651 Off Topic 17 12-15-2013 04:58 AM
Late 3rd Gen Steering Wheel onto Early 3rd gen? PitbullRescuer 3rd gen T4Rs 9 01-19-2012 11:14 AM
Copyright ©2000 - 2019, vBulletin Solutions Inc.
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
Feedback Buttons provided by Advanced Post Thanks / Like (Lite) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Lite) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
Copyright © 2019
