Old 09-16-2019, 02:00 PM #16
AntleredRuin AntleredRuin is offline
Real Name: Daniel
AntleredRuin will become famous soon enough
Real Name: Daniel
+1 to the leave it alone if it was running fine.
Just increase the frequency of your oil changes to every 2k with synthetic oil, and crack the covers again after 10k. I think you'd see a big difference.
AntleredRuin is offline   Reply With QuoteReply With Quote
Old 09-17-2019, 11:48 AM #17
Hood4Runner Hood4Runner is offline
Hood4Runner is on a distinguished road
Well boys I come back to post a sad sad update on this....
I got everything back on and cleaned out. Started it up and was running beautifully and way healthier. I let it idle In the drive way for awhile. I took it for a test drive down the road and got an oil light. I figure itís was low since I cleaned out all that sludge. I get to the bottom of my hill and the truck just losses all power. ****! Right before it died it started knocking. ****! I knew I was low on oil but I had no idea I was that low after cleaning it. So now she knocks in idle which tells me I done ****ed my engine up. Iím guessing the head gasket is toast amongst other things Iíve been reading on here. So what was suppose to cost me 80$ to replace the valve cover gasket is now going to cost me a new motor and cost of labor. Iím trying to look at positives of this, newer Motor with less miles (mine at 223k, was hoping to keep her going way past this but thatís life).
So feel free to roast me into oblivion
Hood4Runner is offline   Reply With QuoteReply With Quote
Old 09-17-2019, 12:11 PM #18
gamefreakgc's Avatar
Real Name: Jerod
gamefreakgc is a splendid one to behold gamefreakgc is a splendid one to behold gamefreakgc is a splendid one to behold gamefreakgc is a splendid one to behold gamefreakgc is a splendid one to behold gamefreakgc is a splendid one to behold gamefreakgc is a splendid one to behold
Real Name: Jerod
That's a real bummer man. How much oil did you put back in? Sounds like you might have drained it, put in the additives but forgot the oil!
'98 4Runner SR5 - 4x4 JDM 5VZ-FE Supercharged - 233K miles.
326WHP 347TQ
AEM F/IC 6 Piggyback, 2.1" pulley at 11 PSI, Go-Fast Parts
Old 09-17-2019, 12:38 PM #19
T4R2014's Avatar
T4R2014 T4R2014 is offline
T4R2014 is a glorious beacon of light T4R2014 is a glorious beacon of light T4R2014 is a glorious beacon of light T4R2014 is a glorious beacon of light T4R2014 is a glorious beacon of light T4R2014 is a glorious beacon of light
T4R2014's Avatar
And this is why you don't fack with the sludge.
Old 09-17-2019, 02:00 PM #20
19963.4lsr5 is a glorious beacon of light 19963.4lsr5 is a glorious beacon of light 19963.4lsr5 is a glorious beacon of light 19963.4lsr5 is a glorious beacon of light 19963.4lsr5 is a glorious beacon of light
The low oil pressure light should turn off the engine instantly.
Old 09-17-2019, 03:03 PM #21
Real Name: Daniel
Real Name: Daniel
Well, the light itself shouldn't, but the driver should when he/she sees that light.
My wife still laughs about a time a couple years ago. We were watching the show 'Home Improvement', and Jill got the oil pressure light and didn't turn off the car, or even tell Tim until a few days later. By then, it was way too late, so he was forced to rebuild the engine and he was all pissed about it.
I muted the TV and turned to her and said something to the effect of "I know he's usually a jackass in this show, but he's completely right to be mad at her. You see that light, you shut it off immediately, and you call me."
She took those words to heart; now every time she even sees a check engine light, she lets me know immediately. Nearly scared the shit out of her on her new-to-her 2005 Sequoia when the CEL, VSC, and TRAC lights all went off at the same time (was just an O2 sensor).
Old 09-17-2019, 04:14 PM #22
audiness's Avatar
audiness audiness is offline
audiness is on a distinguished road
audiness's Avatar
with that much sludge, the motor was neglected, a knocking motor was inevitable anyway. Find a good cheap JDM replacement and move on .
audiness is offline   Reply With QuoteReply With Quote
Old 09-17-2019, 04:56 PM #23
Kanoe's Avatar
Kanoe Kanoe is offline
Kanoe is a jewel in the rough Kanoe is a jewel in the rough Kanoe is a jewel in the rough Kanoe is a jewel in the rough
Kanoe's Avatar
Originally Posted by Hood4Runner View Post
and got an oil light. I figure itís was low since I cleaned out all that sludge. (
Sorry about your truck. This post is not aimed at you OP, just general FYI.
The oil light has nothing (directly at least) to do with oil level. It is an oil pressure light. The switch turns off the oil pressure light when oil pressure is above a certain pressure. 4-5 psi I believe, surprisingly low. And lights up when oil pressure is below that value.
Yes, running out of oil would also cause a low pressure when it gets low enough.
-1996 4Runner. 3RZ 5-Spd. 4x4 Base model. OME2906 rears with 2004 Tacoma Dual Rate Fronts on Bilstien 4600s.
-1993 Corolla Wagon 7AFE
-2001 Echo D.D.
Kanoe is offline   Reply With QuoteReply With Quote
Old 09-17-2019, 06:11 PM #24
Mantilgh Mantilgh is offline
Mantilgh will become famous soon enough
Holy Engine Oil Sludge!
I wonder if a chunk of sludge (from your cleaning) got stuck somewhere and blocked the flow of the oil.
I guess if thereís still a decent amount of oil in the stick, than thatís the case.
Sorry for your loss.
Mantilgh is offline   Reply With QuoteReply With Quote
Old 09-17-2019, 07:08 PM #25
Real Name: Jerod
Real Name: Jerod
Yeah that was my thought, it was pumping air and not oil!
326WHP 347TQ
Old 09-17-2019, 07:58 PM #26
BoomerBob's Avatar
BoomerBob BoomerBob is offline
BoomerBob will become famous soon enough BoomerBob will become famous soon enough
BoomerBob's Avatar
I got everything back on and cleaned out. Started it up and was running beautifully and way healthier. I let it idle In the drive way for awhile. I took it for a test drive down the road and got an oil light. I figure it’s was low since I cleaned out all that sludge. I get to the bottom of my hill and the truck just losses all power. ****! Right before it died it started knocking. ****! I knew I was low on oil but I had no idea I was that low after cleaning it. So now she knocks in idle which tells me I done ****ed my engine up. I’m guessing the head gasket is toast amongst other things I’ve been reading on here. So what was suppose to cost me 80$ to replace the valve cover gasket is now going to cost me a new motor and cost of labor. I’m trying to look at positives of this, newer Motor with less miles (mine at 223k, was hoping to keep her going way past this but that’s life).
No roasting from me. About 6 weeks after getting mine with just 147k the radiator hose blew off after installing a new radiator cap. I thought it just effed up the head gasket and heads but turns out the lower end is also toast so a new long block was needed. I wasted 2 months (long story) and $800 replacing the HG's and spending $400 to get the heads redone along with getting a bunch of tools I may or may not ever use again
It's running great now though. Still in the break in 500 stage. Thought I had a bad front wheel bearing going out too but just ended up being the inner brake pad was not on the pins. I don't how anyone could screw that up. It was floating and making noise. It couldn't fall out but still... What a bone head move on someone's part. Better than a bad bearing I guess.
2001 2wd - Daily Driver
BoomerBob is offline   Reply With QuoteReply With Quote
Old 12-23-2020, 10:25 PM #27
joeczabaranek joeczabaranek is offline
joeczabaranek is on a distinguished road
The 5VZFE on my '98 looked similar to the OP at about 105k miles. I purchased the vehicle at 95k and changed the oil every 5k with dino oil. The previous owner seemed to have done the same with what invoices were handed over to me. At 105k a tiny (1mm?) oil passage in one of the cams clogged and the forward bearing dried up, burned itself and the rubber seal up, and blew all of the engine oil out in my driveway. The journal isn't replaceable so a new cylinder head in addition to the cam would have been required. For a little more than the price of replacing a cylinder head and a little less than replacing both I got a rebuilt motor put in. I'be be really careful doing anything too aggressive trying to remove sludge. It only takes one little flake to kill your motor. Im not sure why the valve train and valve covers sludge up like they do but running synthetic for the life of the engine and <=5k OCIs seems like cheap insurance.
joeczabaranek is offline   Reply With QuoteReply With Quote
Old 12-26-2020, 12:02 PM #28
calimobber's Avatar
calimobber calimobber is offline
calimobber is on a distinguished road
calimobber's Avatar
Dont count it out yet. I know someone who drove a highlander for like an hour after they got an oil change and they forgot to add oil. It was knocking bad but they just put oil back in and it quieted down after a while and its still in use today( this was a few years ago)
My 2002 4runner Build : http://www.toyota-4runner.org/3rd-ge...r-project.html
calimobber is offline   Reply With QuoteReply With Quote
Old 12-26-2020, 01:13 PM #29
JLTD JLTD is offline
JLTD has a spectacular aura about JLTD has a spectacular aura about
You want to do it slow.
I think the sea foam might break it up and clog the oil pump inlet screen.
I totally agree here; Solvents and flushes can release large chunks.
If it were mine, I'd just use short intervals with an inexpensive oil which will gradually clean things up.
In fact I once made a purchase on a badly sludged vehicle, did 2500 mile oil&filter changes for about 4 cycles then worked up to my normal interval....never any oil related problems.
2015 SR5, 69,000 miles
JLTD is offline   Reply With QuoteReply With Quote
cover , miles , sludge , truck , valve
Engine Oil /Sludge Rams Maintenance/Detailing 46 08-29-2014 12:34 PM
Crap! Oil Sludge smallfry 3rd gen T4Rs 47 09-02-2013 06:08 PM
Sludge anyone? Jacobzky Maintenance/Detailing 16 08-09-2007 07:46 PM
Sludge faster4runner04 4th Gen T4Rs 20 03-03-2006 10:39 AM
Sludge on a 3.4 V6 peter78 Problems & Warranty Issues 5 06-28-2003 10:09 PM
Feedback Buttons provided by Advanced Post Thanks / Like (Lite) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
