09-15-2019, 04:34 AM
Factory Radiator Hose Clamps?
I'm going to be changing out my radiator, thermostat and hoses. I already have all of these (OEM Toyota), but I just realized that I forgot to order new OEM clamps. I've looked through several online catalogs but I don't seem to be able to find the part number for the hose clamps. Does anyone have the part numbers for all four of the ones that I will need? Thanks.
2000 4Runner Limited - 2WD, 3.4L V6, Automatic - Bilstein 4600/Moog 'Tall' Springs, Manik brush bar, PowerStop Tundra Brake Upgrade w/ Stoptech SS Brake Lines, KC Hilites 6" Pro-Sport HID Spread Beam Pair Pack System w/ KC Lexan covers, 4th gen 17" wheels w/ Spidertrax and Rugged Ridge 1.25" spacers, oEdRo LED headlight bulbs, BMW E92 seats, ScanGauge II, Prodigy TBC
09-15-2019, 05:23 AM
Real Name: Carlos V.
From Toyota parts online
Gold 2003 4Runner SR5 V6 2WD A340E
Grabber A/T, Brembo rot, Akebono pads, Optima batt, HKB Volt. booster, Buffalo Bayou recovery
Sony XAV1000, LED interior and reverse, Weathertech, Flux-Turbocharged tire valve caps.
09-15-2019, 02:36 PM
Love those constant pressure clamps, they’re the best though I know some don’t agree.
2002 SR5 Sport 4WD
09-15-2019, 02:57 PM
Thanks! For future reference, where the heck are those in the catalog?
09-15-2019, 03:08 PM
Just replaced my upper and lower hoses during a radiator R&R and use those Toyota clips.
They come in the open position help with a small red clip. All you have to do is slide them on the hose where you want them and pull off the retaining clip with a needle nose
09-15-2019, 03:20 PM
Real Name: Andy ಠ_ಠ
Real Name: Andy ಠ_ಠ
also don't use your fingers to hold the clamp when you pull the retaining clip. unless you want a blood blister.
09-15-2019, 09:05 PM
With OEM hoses, you can still use the old clamps. I never replaced those clamps on all 4 of my toyota's (with OEM hoses) and never had an issue.
09-15-2019, 09:22 PM
Same here.
Have them on my 86 long bed, 95 T100 and 02 Runner.......all original as have never found the need to replace them and no failures.
2002 SR5 Sport 4WD
09-15-2019, 09:52 PM
Replacing them on general principles as they are cheap and then I'll have spares. Also, had bad luck with trying to recycle factory clamps in past, not just with Toyotas. They tend to go missing or otherwise become unusuable sometime between when I take them off and when I put them back on (don't ask).
09-17-2019, 10:38 AM
I replaced the clamps 2 years ago with a new set of OEM clamps when I changed out the upper and lower hoses. They were cheap, so why not. Plus, they look better than the old marred up clamps.
Not sure if there's any truth to this, but I've heard from a tech that the adjustable jubilee clamps create uneven pressure on hoses which can possibly promote a fluid leak.
03-29-2022, 01:00 PM
When I type in the part number noted above from Carlos V, 90467-37005, it says it won't fit 97 4runner. How different could these clamps be from year to year? Also, on the diagram they sent me from Camelback a while ago it lists a different part number for the clamps on upper hose versus lower hose. That also makes no sense to me. I had found a part number earlier of 90080-46352 which the CB website also says won't fit my 97 4runner. Maybe any of them would work, who knows?
03-29-2022, 01:10 PM
So I just talked to Olathe Toyota parts guy and he quoted me P/N 90467-37005 which is the same as Yotashop, so maybe thats the "most correct" radiator hose clamps. Probably way overthinking this...
official vendor
official vendor
I replied to your other post that the 90467-37005 is the correct PN. I have them on my '97.
03-29-2022, 02:36 PM
Thank you! I fail to understand why Camelback, using my VIN number, says those "won't fit".
What is even worse is they just cancelled my whole $350 order for hoses and clamps "because we won't ship to an address different from billing address". WTF! We have a little mobile home in the desert for offroading and hiking and yes, it is different from our billing address. They can't figure out their own internet security?? Bizarre. I understand internet fraud is a problem, but this is crazy. Oh well, I guess will try Olathe or Yotashop now.
***I complained too soon! My bad. Adam and Crystal at Camelback figured out a workaround and got me squared away. Exceptional customer service. I know they are just trying to cut down on fraud where someone steals a card, orders parts to a different address, and there you go. I know it happens and it seems to happen more now that in places like the Northwest, crime is no longer illegal.
Anyway, Camelback provided amazing customer service on this.
Reason: Camelback came through
03-29-2022, 03:02 PM
Real Name: Patrick
Real Name: Patrick
If you have time to wait on shipping you can save a lot by using amayama or partsouq
