Old 09-20-2019, 02:10 PM #16
Scramble's Avatar
Scramble Scramble is offline
Real Name: Scramble
Scramble will become famous soon enough Scramble will become famous soon enough
MY GARAGE
Scramble's Avatar
Real Name: Scramble
MY GARAGE
Thumbs up
DAMAGE INCORPORATED!
____________
'99 4Runner - 2.7L 3RZ, 5 Speed, 4.56 Gears - Lifted, Locked & Loaded - 166k Original owner - http://www.toyota-4runner.org/3rd-ge...ld-thread.html
'99 Limited - E-Locker- Stock (for now) - 233k 2nd Owner http://www.toyota-4runner.org/3rd-ge...ted-build.html
Scramble is offline   Reply With QuoteReply With Quote
Old 09-20-2019, 03:15 PM #17
Crowcifier6 Crowcifier6 is offline
Real Name: James
Crowcifier6 is on a distinguished road
MY GARAGE
Real Name: James
MY GARAGE
3rd gen DAMAGEinc build
Originally Posted by scramble View Post
damage incorporated!
.......go!
98 Base Model 2.7L
Crowcifier6 is offline   Reply With QuoteReply With Quote
Old 09-20-2019, 05:50 PM #18
thezentree's Avatar
thezentree thezentree is offline
Real Name: Robert');DROP TABLE Students;
thezentree will become famous soon enough thezentree will become famous soon enough
thezentree's Avatar
So I know this is a 4Runner forum and all, but uhhh ...what's the deal with that old GM on tons with the ORD decal?
<-- former CK5.com member
2001 SR5 - Just like it rolled off the lot, only worse.
thezentree is offline   Reply With QuoteReply With Quote
Old 09-20-2019, 06:01 PM #19
nedceifus nedceifus is online now
Real Name: Justin Metcalf
nedceifus is on a distinguished road
That would be 8low. Bobbed megacab Burb. Locked, Doubler, triple sticks, 40ís. As seen in 4Wheel&Offroad Sept 2019😁
3rd gen DAMAGEinc build-29d37ef4-5113-4b70-8865-d48e12cdf57a-jpg  3rd gen DAMAGEinc build-d2b03da9-c304-4a81-a1e2-d4e070a15e58-jpg  3rd gen DAMAGEinc build-5a949e41-7118-4e4d-af39-d0e8a41152b4-jpg
nedceifus is online now   Reply With QuoteReply With Quote
Old 09-20-2019, 06:22 PM #20
Iím getting 21.5Ē front & rear from hub to bottom of fenderwell. Are the rear springs supposed to have spacers? Also this decal is a legit upgrade...🤦🏼*♂️
3rd gen DAMAGEinc build-2964b5d7-8033-4c0f-8e33-fa6adba9c617-jpg  3rd gen DAMAGEinc build-a029b1db-4794-49f4-872f-7002cfe55809-jpg
Old 09-20-2019, 06:44 PM #21
Brian.'s Avatar
Brian. Brian. is offline
Brian. will become famous soon enough Brian. will become famous soon enough
Brian.'s Avatar
Nope, no spacers stock, just the cone bump-stop.
Brian. is offline   Reply With QuoteReply With Quote
Old 09-20-2019, 07:46 PM #22
Cool! That means I can go down! Iíll play around with ride height, see what works.
Old 09-23-2019, 12:37 PM #23
Was working on my Spartin install yesterday & got a little zealous with the impact wrench. Broke a bolt on the adjustment ring retainer🤦🏼*♂️. Anyway, it is extracted & I found a replacement. Iím putting my sway bars back on. I saw no noticeable difference in its ability to flex & there was a noticeable wibble wobble during hwy driving. Rearend will be back together tonight. Also picked up a job building sliders on my brothers 4th gen. There will be some rust repair on his frame also. His 4th gen is from Minnesota. Iíll scale the rust off it, patch it as nessassary & then give it a coat of POR-15.
Old 09-24-2019, 12:39 PM #24
phattyduck is just really nice phattyduck is just really nice phattyduck is just really nice phattyduck is just really nice phattyduck is just really nice
Leave the front off and put the rear back on. That should give the most 'balanced' flex. Swaybars for independent suspension is detrimental to flex. Swaybars on a solid axle can 'balance' the compression vs. roll rates of the suspension due to inboard mounted springs.
Maximum travel in the front with stock arms and bump stops is 8.5" or so. 25.25" full extension, 16.75" full compression (Upper ball joint limited on droop, weight of truck on bump stops with no springs for compression). So, set your ride height with that in mind. You can get more droop with new upper arms, but you need to make sure your front shocks can handle it.
'16 Honda Odyssey
Old 09-24-2019, 12:49 PM #25
Cool, Iíll throw the front back on only. Tell me this, if you take tire firmest out of the equation, what ride height is best for the most ďactionĒ out of your suspension? It seems to me that stock would give the best balance of up & down travel. Suppose a person was willing to sacrifice sheet metal to achieve the low stance with a decent size tire.
Old 09-24-2019, 01:08 PM #26
I meant Iíll leave the front off & throw the rear back on.
3rd gen DAMAGEinc build-40449565-f4f9-4220-9bc9-ddbdbc09d2be-jpg  3rd gen DAMAGEinc build-e3cfe313-ade7-474e-82e7-7baf598030d9-jpg
Old 09-25-2019, 10:22 AM #27
Well I ****ed up. I either did not get all of the instructions with my Spartan, or they just have piss poor ones. Anyway. Drove my rig to town today with locker installed. It was basically a spool. Started doing a little more research & found some instructions on Randyís Ring & Pinion web sight that clued me into what is wrong. I left the side gear thrust washers in. There is not enough clearance for the rear to disengage. Anyway, Iíll get that pulled back apart & fixed tonight.
Old 09-27-2019, 10:05 AM #28
Got those thrust washers out from behind my side gears & my locker works as it should.
3rd gen DAMAGEinc build-96a9deb6-fee7-424d-b503-50270ce7c4c4-jpg  3rd gen DAMAGEinc build-382abe07-d573-4101-8dbd-874981ff18a1-jpg  3rd gen DAMAGEinc build-52f695cc-c513-45ee-abe4-948ac70537c2-jpg
Old Today, 10:45 AM #29
Trip report. I had both front & rear sway bars off for a couple of weeks. It was doing a wibble wobble coming off bridges at HWY speeds. We went to WY this weekend & I threw the rear sway bar back on before we left. It was better but not enough. Iíll be putting the front one back on. It would go into a wibble wobble at 70. High winds & a heavy load played a part. We had 4 people & 3 dogs. All of our gear & a cooler weíre on top of the rig. The Spartin is going to go also as soon as I can afford to buy a factory e-locker. Itís just too unruly for street use IMO. Id say after this trip a supercharger, shocks, rear springs, front sway bar, air compressor, & a selectable Locker are on the list!
3rd , arrow , damage , straight , title
>BUILD THREAD< The4kbeast's 3rd-Gen 2000 T4R SR5 (Highlander Edition) 4x4 Build The4kbeast 3rd gen T4Rs 285 07-25-2018 09:37 PM
1998 T4R Build Thread/Rear bumper build 4running11191 4running11191 3rd gen T4Rs 3 09-19-2014 07:07 PM
Snow White build 2006 v8 adventure overland apocalypse build Dubs Chops 4th Gen T4Rs 24 04-25-2014 09:25 AM
Guyduebro's Surf build..De-build Guydudebro 3rd gen T4Rs 3 03-17-2013 08:27 PM
Copyright ©2000 - 2019, vBulletin Solutions Inc.
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
Feedback Buttons provided by Advanced Post Thanks / Like (Lite) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Lite) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
Copyright © 2019
