Originally Posted by 19963.4lsr5
Can you just use the gauge instead of the graph? If so does it act the same?
What are the lower numbers? It that a 10 second graph?
Can you put TPS in there? And B1S1 O2 sensor voltage.
Anything above around 15% or below -15% should code for too rich or too lean.
I'm not sure, it was the default. I'll change them to gauges and test tomorrow. Sorry I've never monitored fuel trim before, haha.
Originally Posted by gamefreakgc
Yeah, if you could change it to a gauge. Maybe the graph is showing a percentage of max, not the actual reading. Your cruising fuel trims look normal at 45 MPH.
Your engine runs a bit hot, but maybe that's just a fluke thing or was during stop and go driving?
Yeah someone had mentioned that, the heat. She usually will top out around 203-205 on non-stop drives. Never seen her go over that even in traffic. I guess I need to get a new thermostat.
I'll swap to gauges in the morning and post some tests!
