Old 09-17-2019, 08:22 PM #1
Greatvoid Greatvoid is offline
Greatvoid is on a distinguished road
Question A/D pillar maximum load / metal thickness.
I had a bit of a brainwave the other day and realized that I might be able to use my camping hammock inside my 4Runner, which would make for a really compact and likely super comfy on-the-road sleeping setup. After fiddling with the seats and testing for length, it looks doable if I hang it from the passenger's side A pillar to the driver's side D pillar. My immediate thought afterward was that the easiest mounting solution is going to be to chop a chain link and weld each of the halves to a pillar to make mount points.
Prior to popping off the molding and having a go at it, I figured I better do a little research though. Anyone have any idea what sort of practical load those pillars can stand? I'm a pretty big dude, but pretty much every way I look at it, those pillars would be taking loading forces from a pretty strong direction. On the other hand, it might not take much deflection to screw with the glass/seals.
Also, anyone know what the metal thickness is on those offhand?
Greatvoid is offline   Reply With QuoteReply With Quote
Old 09-18-2019, 03:42 AM #2
BostonJon BostonJon is offline
BostonJon will become famous soon enough
If you end up welding, be careful not to melt the paint on the outside of the A and D pillars
BostonJon is offline   Reply With QuoteReply With Quote
Old 09-18-2019, 04:11 PM #3
Doc2012's Avatar
Doc2012 Doc2012 is offline
Location: Stationed in Camp LeJeune, home is Conover, NC
Doc2012 has a spectacular aura about Doc2012 has a spectacular aura about
Doc2012's Avatar
Don’t do it.
The pillars are only ~20 ga steel, and weld in a link onto them is not a good idea.
You’ll burn through the pillar(s), and have weak, not very supportive welds.
My suggestion would be to make some kind of bracket and use that.
You can make one from the a-pillar ‘oh shit’ handle, to the one that goes above the passenger head, and use all 4 of those mounting points; then you can make one for the rear. There are two 12mm bolts that are already in the rear top corner, under the headliner.
"We are experts in the application of violence."
-LtCol Christian Cabannis, Camp Letherneck, Afghanistan, 2009. The "Summer of Decision."
Doc2012 is offline   Reply With QuoteReply With Quote
load , make , metal , pillar , pretty
Brake pad thickness fastlanechamp Maintenance/Detailing 3 12-19-2021 04:32 PM
Frame steel thickness? mjotrainbrain 4th Gen T4Rs 5 09-19-2019 03:46 PM
What thickness for a plate bumper T4Rscott 3rd gen T4Rs 26 05-27-2015 11:17 PM
Frame Rail Thickness? MStudt 3rd gen T4Rs 8 03-10-2014 08:58 AM
brake pad thickness disbanded 4th Gen T4Rs 4 10-03-2008 08:04 PM
