Old 09-18-2019, 09:14 AM #1
STI_MECE's Avatar
STI_MECE STI_MECE is offline
STI_MECE is on a distinguished road
STI_MECE's Avatar
Seam Sealer?
I ripped the interior carpet out of my 4runner yesterday. And PO(S) must have spilt coffee or coke and the liquid ran under the edges of the carpet.
and it seems to have saturated itself into this. Its not supposed to be brown, but is this just a seam sealer? I am thinking of cleaning this all up but I want to make sure I have something equivalent in place after i remove it. If its a seam sealer, can anyone recommend something to do a small touch up area like this?
I gotta few surface rust spots in the floor pans as well....any recommendations on that. its really light stuff...just want to fix it now while its out.
and a satisfying picture of a before and after on the rear passenger area.
2000 SR5 2x4 Resto/Maintenance
STI_MECE is offline   Reply With QuoteReply With Quote
Old 09-18-2019, 09:43 AM #2
denlion81 denlion81 is offline
denlion81 is on a distinguished road
MY GARAGE
MY GARAGE
I am not entirely sure, but somehow I got to believe this is not only sealer, but also noise reduction ... eh... stuff?
I am not aware of anything which can replace it.
Btw, on pic before cleaning it looked like there might be rust holes, but after it is not... so, was it just dust with some rust on surface only?
denlion81 is offline   Reply With QuoteReply With Quote
Old 09-18-2019, 09:47 AM #3
brillo_76's Avatar
brillo_76 brillo_76 is online now
Real Name: Jon
brillo_76 has a spectacular aura about brillo_76 has a spectacular aura about
MY GARAGE
brillo_76's Avatar
Real Name: Jon
MY GARAGE
I could be mistaken, but that is a sound deadening material. Not a seam sealant. The Sealent looks totally different. :-)
1997 4X4 V6 5 Speed Sr5 4 Runner (97 5 speed )
1997 4X4 V6 Red limited 4 Runner (97 Limited)
1998 4X4 V6 Sr5 Red 4 Runner (98 Tetanus1 )
1998 4X4 V6 Sr5 Silver 4 Runner (98 Tetanus2)
2001 4X4 V6 Sport Green 4 Runner (01 Green Sport)
brillo_76 is online now   Reply With QuoteReply With Quote
Old 09-18-2019, 09:47 AM #4
dogtail's Avatar
dogtail dogtail is offline
Real Name: Keith
dogtail will become famous soon enough dogtail will become famous soon enough
MY GARAGE
dogtail's Avatar
Real Name: Keith
MY GARAGE
Don't worry about it, nothing to seal. These are just rubber sheets stuck to the floor pan. But if the coffee discoloration bothered you, I guess you could hit with some sort of bleach spray.
*1999 3.4L, 4wd/5spd, swapped motor and trans, heavy use DD, seasonal rust proofing using WD-40 only
*1998 3.4L, 2wd/auto, rust free from south, slated for 4wd/5spd swap from my 2000 parts rig
*2000 3.4L, 4wd/5spd, parts rig, picking the carcass
dogtail is offline   Reply With QuoteReply With Quote
Old 09-18-2019, 10:09 AM #5
STI_MECE's Avatar
STI_MECE's Avatar
awesome good deal. I guess I can pick something up at Orileys today and clean it up....if not oh well.
And no that pic of rear seat is no surface rust, its all just nasty BS from the other owners who left stuff drip down the seats....and add sand to the mix and and letting it soak for a few years and that is what you get.
I am going to take the cargo carpet out today....cant wait to see what that looks like.
Old 09-18-2019, 10:38 AM #6
WeakSauz WeakSauz is offline
WeakSauz is on a distinguished road
Rippin' all the carpet out, eh? Doing a sound damping job?
You will be pleased with the results if you are
2000 SR5 4x4, Auto | Millennium Silver and Moon Mist | Eibach Pro Lift Stage 1- Struts and Coils | Powdercoated Tundra Steelies | Tundra brake upgrade | 255/85/16 BFG KM2 | Gen 1 Roll bar | Shrockworks skids | ARB Onboard Air | Gen 1 Taco Manual Hubs with ABS retained | Alpine Double Din with Apple CarPlay, Full Alpine speaker set and in-dash Amp
WeakSauz is offline   Reply With QuoteReply With Quote
Old 09-18-2019, 10:49 AM #7
MY GARAGE
MY GARAGE
Is there a special material someone would use for that noise reduction?
Old 09-18-2019, 10:55 AM #8
STI_MECE's Avatar
STI_MECE's Avatar
Nope no sound deadening here. Just out with the old in with the new. I embrace the rattles lol
Old 09-18-2019, 11:16 AM #9
Bad Luck Bad Luck is offline
Real Name: Patrick
Bad Luck has a spectacular aura about Bad Luck has a spectacular aura about
Real Name: Patrick
I'm reading this as you are asking for noise reduction material recommendations.
This: https://www.amazon.com/dp/B00URUIKAK...v_ov_lig_dp_it with this on top if you want extra noise/heat insulation:https://www.amazon.com/dp/B07FYLM47D...v_ov_lig_dp_it
Roller:https://www.amazon.com/dp/B015WJH4ZW...v_ov_lig_dp_it
Both products are self adhesive so no need for spray.
Old 09-18-2019, 11:32 AM #10
MY GARAGE
MY GARAGE
Thanks
Old 09-18-2019, 12:21 PM #11
phattyduck is a glorious beacon of light phattyduck is a glorious beacon of light phattyduck is a glorious beacon of light phattyduck is a glorious beacon of light phattyduck is a glorious beacon of light
That is the color of the OEM material there. It is a bitumen-based (tar) sound deadener. That's the factory stuff, just with the paint rubbed off of it. Nothing to clean or change.
'16 Honda Odyssey
area , carpet , ran , sealer , seam
Liftgate seam picture? Schrek 5th gen T4Rs 2 06-16-2018 02:42 PM
Recommendation for M Sealer OldSchool1959 Maintenance/Detailing 0 02-23-2014 04:54 PM
Headlight sealer to prevent yellowing? TEQ.FZJ 5th gen T4Rs 8 02-19-2014 07:58 PM
seam a bit pricey to you? Iroke17 Classic T4Rs 7 02-08-2012 07:04 PM
dose this seam like a good idea? Iroke17 Classic T4Rs 14 09-14-2011 10:39 AM
Copyright ©2000 - 2019, vBulletin Solutions Inc.
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
Feedback Buttons provided by Advanced Post Thanks / Like (Lite) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Lite) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
Copyright © 2019
