Old 09-20-2019, 12:44 PM #31
gamefreakgc's Avatar
Real Name: Jerod
gamefreakgc is a splendid one to behold gamefreakgc is a splendid one to behold gamefreakgc is a splendid one to behold gamefreakgc is a splendid one to behold gamefreakgc is a splendid one to behold gamefreakgc is a splendid one to behold gamefreakgc is a splendid one to behold gamefreakgc is a splendid one to behold
Real Name: Jerod
Drove it this morning for a good 30 minutes. Voltage reported between 12.4 - 13.0V via OBD-II, which from my testing yesterday means about 13.9 - 14.5V at the battery. It dropped momentarily to 12.0V when my fan kicked on at idle but came back up quickly. Looks like my positive battery cable connections was the culprit after all! I learned a lot from all this and even though the cable "looked fine" with no corrosion, there was enough dirt and grime that found its way in to make the connection deteriorate.
'98 4Runner SR5 - 4x4 JDM 5VZ-FE Supercharged - 233K miles.
326WHP 347TQ
Old 09-20-2019, 01:14 PM #32
19963.4lsr5 is a name known to all 19963.4lsr5 is a name known to all 19963.4lsr5 is a name known to all 19963.4lsr5 is a name known to all 19963.4lsr5 is a name known to all 19963.4lsr5 is a name known to all
Iím going to do the voltage drop test on my rig between the Alt charge post, Underwood junction box, and battery myself before I call my aftermarket voltage regulator junk.
Old 09-20-2019, 01:57 PM #33
Kanoe's Avatar
Kanoe Kanoe is offline
Kanoe is just really nice Kanoe is just really nice Kanoe is just really nice Kanoe is just really nice
Kanoe's Avatar
I wonder what is up with that. My Ultraguage measures within .1 or .2 of battery voltage.
You could put your DVM on the 12V pin of the OBD2 port to see if it is a voltage drop in your wiring or if it is a misreporting by the device you are using. What are you using on the OBD2 anyhow?
-1993 Corolla Wagon 7AFE
-2001 Echo D.D.
Kanoe is offline   Reply With QuoteReply With Quote
Old 09-20-2019, 02:35 PM #34
Real Name: Jerod
Real Name: Jerod
It could very well be the bluetooth reader. It's never been that high (13.1V is the highest I've ever seen in 5 years of having it), it's the BAFX cheapo reader off Amazon so I'm not expecting the world from it. However, it does seem to rise and drop in proportion to the battery voltage accurately.
I have no low voltage issues anywhere in the cabin so I haven't really worried about it much. Headlights don't dim or anything like that so I think it's probably just the reader. I did order a cigarette lighter voltage reader though which I'm interested to see if that's more accurate: https://smile.amazon.com/gp/product/...?ie=UTF8&psc=1
326WHP 347TQ
Old 09-20-2019, 03:34 PM #35
Redo your pcm grounds on the intake manifold. Or check the crimp voltage drop to the negative battery terminal. The ground crimps could be corroding. If so redo the crimps and solder the crimps after crimping to remove any chance or corrosion later.
For grounds I use non insulated crimps.
Old 09-20-2019, 04:51 PM #36
phattyduck has much to be proud of phattyduck has much to be proud of phattyduck has much to be proud of phattyduck has much to be proud of phattyduck has much to be proud of phattyduck has much to be proud of phattyduck has much to be proud of phattyduck has much to be proud of phattyduck has much to be proud of
Startup: 14.2V
Idling with all accessories on: 13.2V-13.9V. Drops to 13.2V only when fan kicks on with ALL accessories on. That includes light bars and all that so a lot of current being drawn.
1500 RPM with all accessories on: 14.0V
These are all perfect numbers. The voltage reported via OBD-II should be what the ECU is receiving - you likely have bad grounds or power to the ECU, which is probably worth checking out! Check grounds, re-seat connectors, relays and fuses, etc.
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Old 09-20-2019, 05:11 PM #37
RAD4Runner's Avatar
RAD4Runner RAD4Runner is offline
RAD4Runner has a spectacular aura about RAD4Runner has a spectacular aura about
RAD4Runner's Avatar
I see a lot of guess work here. START WITH SIMPLE AND FREE THINGS FIRST.
The one thing in common with those alts is the wiring. If the third alt fixed the problem, it was because disconnecting and re-connecting connector rubs off oxidation on the pins.
Toyota components are bullet-proof. Bad wiring usually causes problems. had what looked like a serious problem last week, only to find out it was a bad "S" pin connection. Fixed by cleaning and tightening connector pins.
Isn't there supposed to be battery voltage fed TO the alternator on one or them to make the alternator work?
... I have read about broken wires right on the connector, maybe a good visual will turn up something.
Yes this^^^
S- wire senses battery voltage. If this is broken, you would get over-voltage
IG - wire "excites" the alternator. If this is broken you will not get charging, low charge if high IG is almost broken (high resistance).
L - is merely fault light signal it will not prevent alternator from doing its job. It should be close to 12V when system is working well. Close to ero when there is a system fault.
86 4Runner, 22R-Eliable, 5-Speed Manual, dlx. WHAT'S YOURS?
If you want us to help from afar please let us see, hear, feel what you're dealing with.
A picture paints a thousand words.
Toyota components are bullet-proof. Issues often arise from poor wiring, assembly and/or maintenance. Suspect those first.
Next only to our senses, the multi-meter is the most important electrical diagnostic tool. Spend $6 at Harbor Freight or $$$ blindly replacing parts.
RAD4Runner is offline   Reply With QuoteReply With Quote
Old 09-20-2019, 06:05 PM #38
Real Name: Jerod
Real Name: Jerod
Looks like I got me some grounds to clean!
I will take a look at it and clean. I don't remember ever cleaning it and my engine bay gets grimey with oil + dust.
By chance do you recall where the ECU ground point is? I think I remember it being behind the passenger's side kick panel but I might be mixing it up in my head with something else.
326WHP 347TQ
Old 09-20-2019, 07:59 PM #39
I coat my terminals both battery and all my grounds in a conductive grease.
I use this stuff. If it can keep aluminum ground lugs in the bottom of our manholes at work clean between our yearly inspections of the high voltage distribution it will work under the hood of a car a long time.
One 15-29 dollar tube of this stuff will last two generations.
Old 09-21-2019, 12:34 AM #40
Real Name: Jerod
Real Name: Jerod
You called it, it's my OBD-II reader. I get a solid 12.5V at the port itself with key ON. Time to try and explain to the wife why I need another car gadget...
On the plus side, the cheapo cig lighter voltage reader read at 12.4V. I'll use that from now on I think.
326WHP 347TQ
Old 09-21-2019, 11:40 AM #41
This is mine. I also have a usb Charger that displays voltage if nothing is being charged.
Old 09-21-2019, 05:26 PM #42
Hot up to to temp Alternator.
Headlights, AC with fan in speed 3, in gear with foot on brake idling at 600-650rpm I had 41a coming out of the Alt and 2.5a coming out of the battery and battery voltage at the posts was 12.7v. My cig lighter shown 12.3 at the same time.
In park idling at 750rpm the post voltage was 13.6 and Alt was pushing 51 amps.
I had .1v drop between the Alt output (12.8v) post and the battery (12.7v). Thinking about it, I forgot to measure the Alt output at the Underwood junction box.
Iím using a Fluke AC/DC clamp on amp meter.
Old 09-21-2019, 08:39 PM #43
Real Name: Jerod
Real Name: Jerod
I’m using a Fluke AC/DC clamp on amp meter.
I drove mine around today for a good 45 min at at idle with A/C brake, e-fan on etc. I was at 13.4V at the lowest, 13.8V at the highest. But that's why I did the big 3 plus a bigger alternator, more power at low RPM's so I don't wear down my battery.
I'm not sure if your voltage readings are bad, or just need to clean up the positive side like I did. Some online sources said a voltage drop of 0.1V or higher indicates a problem. But I've done 0 reading on a stock DENSO alt so maybe that's normal.
326WHP 347TQ
Old 01-19-2020, 12:28 PM #44
So I finally logged onto T4R through my laptop and I appears I missed some things that TapTalk does not report to me.
What Alt did you upgrade to? A GM or a hot-rodded Denso?
Now that its 22 degrees I'm pushing more amps at 600rpm. But I wish There was a regulator that had a higher standard voltage. My GM alts as well as my RAM buth never go below 14.2v no matter the outside temp. Our Denso's seem to revert to 13.8 as soon as under hood temps get above 90f.
Old 01-19-2020, 12:59 PM #45
brillo_76's Avatar
Real Name: Jon
brillo_76 is a splendid one to behold brillo_76 is a splendid one to behold brillo_76 is a splendid one to behold brillo_76 is a splendid one to behold brillo_76 is a splendid one to behold brillo_76 is a splendid one to behold brillo_76 is a splendid one to behold brillo_76 is a splendid one to behold
brillo_76's Avatar
Real Name: Jon
Yes I check a few times a week via a laptop so I dont miss things as TapTalk doesn't always report notifications.
13.8 is a Toyota thing. :/
5 3rd gens listed in the build thread
Brillo's Bucket Fluid Exchanger: https://www.toyota-4runner.org/3rd-g...ml#post3358086
battery , charging , low , put , started
Charging a LiFePO4 house battery from alternator 4RExplorer 5th gen T4Rs 7 05-14-2019 09:39 PM
Battery Charging Issue BucksCo 3rd gen T4Rs 8 01-18-2019 10:58 PM
Need some help diagnosing battery/charging issue pudzley 4th Gen T4Rs 8 12-01-2017 01:39 PM
PLZ HELP! Battery not charging, alternator tests good. swapmeet 4th Gen T4Rs 7 03-15-2015 07:54 PM
Battery/Charging Issue Clemsonfan15 3rd gen T4Rs 8 05-15-2011 03:52 PM
