Old 10-03-2015, 01:21 PM #1
meekie4 meekie4 is offline
meekie4 is on a distinguished road
Changed alternator, still not charging.
Hey guys, my low voltage light has been on on on the dash and my car isn't charging the battery anymore. I swapped in a carquest alternator and that fixed the issue for about a week then the light returned. So then I went to a junkyard and picked up another alternator and again, it worked for a short while and now I'm back again with low voltage light on.
I have the 'big 3' wire upgrade done and I recently went through the grounds that I knew about and cleaned them up. (Fender, frame, and engine bay ground)
The battery is just over 2 years old and my runner is a 1996 3.4
My questions are: does the alternator have a specific ground running off of it? If it does where is it located.
What else could I run through to find what's causing my electrical problem?
And any other advice on the subject is helpful.
Thanks
meekie4 is offline   Reply With QuoteReply With Quote
Old 10-03-2015, 01:46 PM #2
cashmoney cashmoney is offline
cashmoney is on a distinguished road
Have you checked the voltage with a meter?
1989 Toyota 4runner
cashmoney is offline   Reply With QuoteReply With Quote
Old 10-03-2015, 08:49 PM #3
Just tested the battey fully charged.
12.83 volts with the car off
12.13 with the car running
Tested voltage produced at the alternator
19.5 volts from the positive lead.
That shouldn't be that high?
Old 10-03-2015, 09:17 PM #4
nely nely is offline
nely is on a distinguished road
If the power at the alt is 19, but 12.13 at the battery there's a broken wire in between the alt and battery
nely is offline   Reply With QuoteReply With Quote
Old 10-04-2015, 10:01 AM #5
MStudt's Avatar
MStudt MStudt is offline
official vendor
MStudt is a name known to all MStudt is a name known to all MStudt is a name known to all MStudt is a name known to all MStudt is a name known to all MStudt is a name known to all
official vendor
MStudt's Avatar
Could also be a parasitic drain. Are you able to drive the your 4runner at all without it stalling due to your battery being dead? If so then your alternator is not the issue since it's able to keep up with the charging while driving. If you're coming out in the morning to a dead battery then you have a parasitic drain.
MStudt is offline   Reply With QuoteReply With Quote
Old 10-04-2015, 10:10 AM #6
Buckaroo's Avatar
Buckaroo Buckaroo is offline
Buckaroo will become famous soon enough
Buckaroo's Avatar
The voltage across the battery terminals with car running should be at least 13 volts. As Nelly suggested, it could be high resistance in the wire from the alternator to the battery given you have thrown multiple alternators at the issue. With the car running, check DC voltage with one meter lead on the end of the wire at the alternator and the other lead on the end of the wire at the positive terminal of the battery. If you see more than 0.5V on the meter (ignore the +/- sign), the wire has too much voltage drop and should be replaced.
Buckaroo
2000 T4R SR5 V6 (Retired) & 2005 T4R Limited V6
2002 & 2017 XLE Camry
2004 Honda Accord
2017 Tundra Limited DC 5.7L TRD 4WD
2024 Honda Pioneer 700-2 Deluxe
Buckaroo is offline   Reply With QuoteReply With Quote
Old 10-05-2015, 01:02 AM #7
I looked at the voltage produced at the alternator (19.6v) then at where it connects into the fuse box (11.5v)
I would have never looked at the voltage to the fuse box side if you guys didn't recommend taking a look at that wire. Turns out it was a bad connection/crimp on my wire and got that taken care of. Now I'm at 14.3 v at all connections, no more battery light and I went over all my wire connections. Thanks again you guys for the help.
Old 10-18-2015, 12:32 PM #8
RuLost2's Avatar
RuLost2 RuLost2 is offline
RuLost2 is on a distinguished road
RuLost2's Avatar
Meekie or Buckaroo, can either of you point out the wires that you are talking about?
My battery light came on after I blew/replaced the TAIL 10A fuse under the dash. There are no other electrical issues. The battery is reading below 12v now, but isn't having trouble starting or running. I am not driving it. So I took the alternator off and had it tested, it passed 3 times at two different part stores. I tried a brand new alternator and it didn't clear the fault.
(the lights for the a/c controls and radio preset buttons were out, that is when I checked and found the blown fuse)
EDIT: I wanted to add that I cannot reprogram the automatic door lock behavior. I run the sequence for lock/vehicle speed and it just unlocks, when it is supposed to unlock/lock/unlock to verify reprogramming. Not sure if the lack of power makes it unable to reprogram.
RuLost2 is offline   Reply With QuoteReply With Quote
Old 10-19-2015, 07:33 AM #9
Buckaroo's Avatar
Buckaroo's Avatar
Two wires coming off the alternator. The one carrying the alternator output is the heavier wire of the two. It should run back up to the battery positive lead and, I think goes through a fusible link on the way.
I don't know why your battery light came on after changing the TAIL 10A fuse. Perhaps check the IGN 10A fuse and make sure that it is good/not loose.
Buckaroo
2004 Honda Accord
Old 10-19-2015, 09:23 AM #10
IBallEngineer's Avatar
IBallEngineer IBallEngineer is offline
IBallEngineer will become famous soon enough IBallEngineer will become famous soon enough
This is the EWD for an 02, it should give you an idea of the possible bad connections. The Large wire that goes through the 120A fuse can be checked by checking voltage at the alternator with the engine off. It should be whatever the Battery has with the engine off. If not your problem is in that circuit.
Next the two fused ignition circuits, AND the Stator circuit which is also battery voltage.
http://tacoma.site40.net/4Runner_96-...emci/014cs.pdf
1989 FJ62 5.3 Chevy, FZJ80 Axles, 4.88's with ARB.
2000 2wd runner, 4 cylinders, yes it IS slow.
1999 4WD SR5 Desert Dune 3.4 351K and counting.
2000 4WD sport 3.4 Elocker <--My son's but I still end up paying.
2001 2WD SR5 3.4 <-- My daughter's...see preceding line.
IBallEngineer is offline   Reply With QuoteReply With Quote
Old 10-20-2015, 04:37 PM #11
RuLost2's Avatar
RuLost2's Avatar
Thanks everyone. I chased wires for a while and couldn't find anything wrong. I checked again and the battery was 12.5v and alternator was pushing 13.9v with the light still on. So frustrated but not defeated, I checked ALL fuses again, and even though it was "good," I changed the ALT-S fuse... and POW! Light goes out!
Still cannot get the door lock reprogram to accept, but that is trivial to making sure the charging system is good.
Thanks again.
Old 10-20-2015, 05:58 PM #12
Thanks again.
Well obviously it wasn't "good". How were you checking it? By the way the Alt-S fuse is the Stator circuit I mentioned in my first post.
Old 10-21-2015, 05:55 PM #13
RuLost2's Avatar
RuLost2's Avatar
I pulled the fuse and checked it with a multimeter. Correctly. I pulled every single one. I am not a fan of electrics anyway, so I am just glad that the deamon is gone. You called it with the Stator circuit. Thanks.
Old 10-21-2015, 08:07 PM #14
xspsi6 xspsi6 is offline
Real Name: Chris
xspsi6 is on a distinguished road
Real Name: Chris
I had an alternator over charge at just over 17 volts and had the batt light come on although this is not your problem I just wanted to throw it out there that over charging will trigger the light as well.
2001 sr5
1999 limited
1995 Mitsubishi evo 3
next up a 2000 land cruiser!
xspsi6 is offline   Reply With QuoteReply With Quote
Old 10-21-2015, 10:13 PM #15
Lug1 Lug1 is offline
Lug1 is on a distinguished road
I'll jump in, too.
The battery/no charge light is turning on intermittently.
At one time, the battery light turned on, it was a very rainy day and I was out for a 110 mile trip. It was on for the duration of that ride, until I got home.
Now, the battery/no charge light is turning on intermittently. Never on more than 15-20 minutes, and then goes away.
Does that indicate that my alternator is slowly going ?
I did not measure the voltage anywhere besides at the battery, and it was at 13.8V, with some load (lights, fan).
how about the alt' belt - I'm not sure how to check for correct tension. I tried tightening it up, but, the movement of the tightening bolt does not really seem to add any tension to the belt - is there any chance it's the belt tension ? (belt has less than 10K miles in use).
I should be getting the multimeter by mail in a couple of days will be able to run more tests.
'99 4Runner, 3.4L V6, manual transmission, 270K miles on 04.01.16
All stock, bumper to bumper. I have kids, wife and a mortgage. No time, no money.
Lug1 is offline   Reply With QuoteReply With Quote
What Volts does your Alternator show while charging?? ejason 5th gen T4Rs 6 05-14-2015 02:18 PM
4.7 Alternator not charging help PLZ! Need ideas. swapmeet 4th Gen T4Rs 17 03-31-2015 11:34 AM
PLZ HELP! Battery not charging, alternator tests good. swapmeet 4th Gen T4Rs 7 03-15-2015 07:54 PM
Alternator charging post snapped(hopefully that is the right name.) thejonnyjones 3rd gen T4Rs 2 02-18-2014 07:20 PM
Charging issues.. Rebuilt alternator and still no charge... Ameritimer Problems & Warranty Issues 1 03-30-2012 10:31 AM
