Old 09-20-2019, 02:57 PM #16
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
Originally Posted by AR314 View Post
What exactly happened? What model/year is your 4Runner?
Sorry. That would probably be helpful, huh?
2000 Limited. All 5 lights came on solid for a few minutes while driving as if it was in 4wd, but the was no bind that I could tell. It went off on it's own the first time in the same trip. A couple weeks later all 5 lights came on solid again and stayed that way for a few trips probably half hour of driving total then went out once I put it into 4Lo, then 4hi locked, then 4hi unlocked, then 2hi.
Like phattyduck stated the j shift multimode shifter doesn't control the 2wd/4wd/center diff lock. It just moves the lever to different sensors which sends a signal to the 4wd ecu to engage the front axle and move the transfer case actuator. However, your j-shift multimode shifter does manually move the high/low shift forks in the transfer case.
Old 09-20-2019, 05:08 PM #17
AR314 AR314 is offline
AR314 is on a distinguished road
So if the switch somehow shorted out it could conceivably cause the car to go from 2WD to 4WD. Ever hear of that happening?
AR314 is offline   Reply With QuoteReply With Quote
Old 09-20-2019, 05:20 PM #18
Real Name: Patrick
Real Name: Patrick
In theory it could if the switch shorted closed.
4wd , indicator , light , month , scenario.4wd
Check engine light, slip indicator light & flashing 4 Lo light croat5280 5th gen T4Rs 19 06-11-2020 05:16 PM
Indicator light mdjh51 5th gen T4Rs 3 01-01-2019 11:24 PM
Slip indicator light VS VSC light tman100z 3rd gen T4Rs 4 02-11-2015 07:55 AM
4WD indicator light louie the fly Classic T4Rs 1 08-27-2008 12:10 PM
A/C indicator light mtngoat 4th Gen T4Rs 2 04-23-2008 09:30 AM
