Old 09-10-2020, 12:51 PM #76
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Originally Posted by jross20 View Post
Shouldn't a good coat of paint be enough? If the water/air cannot get to the steel then it shouldn't rust. Right?
In non rust areas yes that perfect. In Rust belt areas... not enough. :-(
Its the oxygen that gets to the steel that's the issue. I can show you steel that was painted when new painted correctly etc and still rots out around here without any salt / winter help. Its part environment too as we have major fluctuations that cause the steel to expand and contract rapidly thus acceleration of rust. Its just something we have to deal with and why you will not see a pile of 15 -20 year old vehicles on the road as they don't survive the rot in these areas. :-(
Old 09-23-2020, 08:38 AM #77
jerbrun0515's Avatar
jerbrun0515 jerbrun0515 is offline
jerbrun0515 will become famous soon enough
Originally Posted by sugjavier View Post
This will fit then right?
50 - USA UNDERCOAT RUSTPROOFING PLUGS CAPS BUTTONS FLUID FILM PFC Wool WAX | eBay
Dimension of the Plastic Plug Buttons :
.02 - .07" : Thickness
1/2" : Diameter
I'm getting my underbody professionally detailed and having them put POR15 everywhere first, then spray a shit ton of Fluid Film.
I don't wanna have to do it again, at least for inside the frame, so I'd like to seal up the frame holes.
Does anyone know how many darn holes are there???
Also if the holes are plugged, is there really no other way water/moisture can get inside?
How did these grommets/plugs work out for you? I am shopping around and still wondering whether 1/2" or 5/8" is better. Also found these.
Amazon.com: Rubber Hole Plug for 5/8" Opening - 3 Pack Grommet Without Hole: Home Improvement
jerbrun0515 is offline   Reply With QuoteReply With Quote
Old 09-23-2020, 08:55 AM #78
WeakSauz WeakSauz is offline
WeakSauz has a spectacular aura about WeakSauz has a spectacular aura about WeakSauz has a spectacular aura about
In Georgia, absolutely. I'm in NC and just stick with a little WD40 sprayed inside the frame holes occasionally and an awesome coat of paint on the outside. No rust at all here
2000 SR5 4x4 | Geared, Locked and Fully restored OEM+ build.
Forged and Cammed 1UZ Single Turbo, Standalone ECU + Built R150 in process. Why, you ask? Because it makes no sense in this platform, and I love it!
WeakSauz is offline   Reply With QuoteReply With Quote
Old 09-23-2020, 09:02 AM #79
jross20's Avatar
jross20 jross20 is offline
jross20's Avatar
They make this frame coating in a can with a special nozzle on a tube. You can feed it into the frame rails and spray all over!
Found it, it's made by Eastwood. I used it a while back to fix some rust spots on the inside of that tube on the back of the frame. The one that holds the rear spring seats.
Old 09-23-2020, 11:24 AM #80
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
I use 1/2 inch grommets in the holes I drill for rust inhibiting solutions
Old 09-23-2020, 09:16 PM #81
sugjavier sugjavier is offline
sugjavier will become famous soon enough
Haven't bought it but will now and let y'all know. I'm getting mine rustproofed with POR15 then Fluid film the week of October 21st. I'll ask them to take some nice pics before they take it down from the hoist.
2001 Toyota 4Runner Limited. 231k miles.
sugjavier is offline   Reply With QuoteReply With Quote
Old 09-23-2020, 09:21 PM #82
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Maybe people had better luck with Eastwood products then I did. Still rusted underneath it. However, we are talking northeast salt belt area for my rigs. So rust is extremely heavy and extremely scaly.
Old 09-23-2020, 11:35 PM #83
T4R2014's Avatar
T4R2014 T4R2014 is offline
T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold
T4R2014's Avatar
Anyone plug up those large rectangular-ish holes on the frame? Probably the main source for dirt building up in the frame. FZJ80s have plugs in them from factory. Maybe those plugs work.
Old 09-23-2020, 11:42 PM #84
jross20's Avatar
jross20's Avatar
I wonder if that would trap stuff? I was thinking about jamming a leaf blower into one of the frame openings in the back with the rear bumper removed. Thought it may be good to blow any dirt out before applying anything
Old 09-24-2020, 02:18 AM #85
Kanoe's Avatar
Kanoe Kanoe is offline
Kanoe is just really nice Kanoe is just really nice Kanoe is just really nice Kanoe is just really nice
Kanoe's Avatar
Or use a garden hose poked up the back. I do mine 1-2 times a year. A huge amount of dirt builds up right where the rear lower control arm bracket attaches in the curve there. No coincidence this is where they rust out either.
-1993 Corolla Wagon 7AFE
-2001 Echo D.D.
Kanoe is offline   Reply With QuoteReply With Quote
Old 09-24-2020, 08:55 AM #86
Sarki Sarki is offline
Sarki has a spectacular aura about Sarki has a spectacular aura about
Life in the northeast, the battle against rust continues........placed an order for this Pro Kit yesterday.
After lots of research decided to give Woolmax a try. Also picked up a gallon of Fluid Film but will try out the Woolmax this season.
After speaking with people who have used both they switched to the Woolmax as a bit thicker so less overspray and they thought it held up through the winter a bit better than FF.
Both seem like great products and I suspect either will help keep the rust at bay.
If anyone thinking to buy this stuff skip Amazon and go directly to Kellsport Products website as priced lower and great service.
POR-15 or just Fluid Film-ea36a986-bb1c-49cd-845d-72023355dae8-jpg
2002 SR5 Sport 4WD
Sarki is offline   Reply With QuoteReply With Quote
Old 09-24-2020, 09:08 AM #87
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Yes. I do I remove all the holes in the frames as a repair them. I do it by welding in internal steel plates and weld the holes shut. It's the source of the internal frame rot.
Excellent thought on plugs. I never found ones that work. Rubber or silicone ones would be the best or something oil resistant.
I am surprised the aftermarket or someone hasn't made plugs for our frames.
Old 09-24-2020, 09:10 AM #88
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
I am curious how wool wax holds up. I am experimenting with corroseal.
Old 09-24-2020, 09:25 AM #89
Fingers crossed but from what I have read it has proven to be very effective....time will tell.
2002 SR5 Sport 4WD
Old 09-24-2020, 12:10 PM #90
jross20's Avatar
jross20's Avatar
Randon idea here, anyone else ever refreshed a mosin nagant before? Remember that fat thick ass grease they were coated in?
Cosmoline.
So...what if you cleaned out the frame rails, applied a new coating, and the just literally pumped them full of cosmoline? That shit is so thick it last for decades. It kept my mosin rust free for 70+ years so I'm sure it would work for our trucks
film , fluid , frame , por-15 , rust
The end-all Fluid Film thread IL_Fletch Maintenance/Detailing 26 01-01-2024 06:01 PM
Fluid Film Applicator Last Man Standing 3rd gen T4Rs 3 08-13-2019 10:37 PM
Fluid film my frame? Bbanks97 3rd gen T4Rs 24 01-07-2019 03:07 PM
Fluid film prep ? jminz 4th Gen T4Rs 4 04-05-2018 03:12 PM
Fluid Film PSA A10GAC General Discussions 1 08-27-2016 01:25 PM
