Old 09-25-2020, 11:40 AM #91
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Originally Posted by jross20 View Post
Randon idea here, anyone else ever refreshed a mosin nagant before? Remember that fat thick ass grease they were coated in?
Cosmoline.
So...what if you cleaned out the frame rails, applied a new coating, and the just literally pumped them full of cosmoline? That shit is so thick it last for decades. It kept my mosin rust free for 70+ years so I'm sure it would work for our trucks
Yes, That is my next move if my FF and Corroseal do not work. I was only staying away from Cosmoline because of its costs and I didn't feel like pumping a frame full of it.
My plating via inside and sealing the frame rail holes are making significant improvements.
The reason of FF inside is that it can flow and will even wick vertically. Cosmoline will not do this as its too heavy and think.
Another excellent coating would be liquid bees wax as well. :-)
Old 09-25-2020, 03:22 PM #92
Kanoe's Avatar
Kanoe Kanoe is offline
Kanoe is just really nice Kanoe is just really nice Kanoe is just really nice Kanoe is just really nice
Kanoe's Avatar
I personally don't want to use anything too thick and heavy inside the frame. Anything thick and sticky will collect and hold dirt in there. I know Brillo you are plugging the holes so maybe in your case it would work.
I have had good luck with a lighter spray (FF or wd40) inside the frame along with seasonally blasting the frame internals out with a garden hose. Keeps it nice and clean in there and nothing to trap moisture.
I think the cleaning is the most important part of the plan. I'm pretty sure most people don't appreciate the amount of dirt that builds up in the frame. Once the bottom drain holes plug, the dirt just keeps building up.
-1993 Corolla Wagon 7AFE
-2001 Echo D.D.
Kanoe is offline   Reply With QuoteReply With Quote
Old 09-25-2020, 03:34 PM #93
Just like the rear shock/spring mount plate...
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Old 09-25-2020, 03:45 PM #94
jross20's Avatar
jross20 jross20 is offline
jross20's Avatar
Yeah but I'm talking about some seriously thick ass grease, this stuff is nuts. Just fill the frame rails so it's nigh impossible for crap to get in there to start. And even if it does, cosmoline inhibits rust I believe.
Old 09-25-2020, 06:00 PM #95
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
@jross20 theory does sound decent. Cosomoline is a rust inhibitor and extremely thick. Would stay in the frame rails. Would you have to plug the frame holes? Probably.
I am still experimenting yet. So far in sealed frames. FF seems to work extremely well. Alot better then the Eastwood products. Alot better then standard paint.
I do know sealing out the frame holes is a major step to saving the inside big time.
Keeping the frame cleaned out of dirt abs and debris is excellent as well.
I know more after a few more years. As I have endoscope and can look into areas that I have done.
Old 09-25-2020, 10:13 PM #96
jross20's Avatar
jross20's Avatar
I just borrowed a camera snake thing from my uncle, going to inspect the frame tomorrow
Old 09-26-2020, 03:04 PM #97
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Its interesting what they look like inside. The South should be slight if any surface rust. Rust belt areas are a completely different story as you see from us that live in those areas. My arch photo on this thread shows what happens if the owners just drive them and do nothing.
Old 09-26-2020, 11:18 PM #98
jross20's Avatar
jross20's Avatar
Alright so the camera was a bit old and I couldn't see shit inside....
But I from just looking with a flash light, it looks black inside. Don't see any rust.
Old 09-27-2020, 07:37 PM #99
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Could be if not I rust belt.
Old 09-27-2020, 08:05 PM #100
Kanoe's Avatar
Kanoe's Avatar
Get your finger inside the square holes and feel the condition of the bottom, especially near the rear lower control arm mount. That'll be the place to find it if you have it.
-2001 Echo D.D.
Old 09-27-2020, 10:58 PM #101
jross20's Avatar
jross20's Avatar
Alright I'll have to try that next time I get down there.
Here is some of my work from today
Old 09-28-2020, 03:14 PM #102
Kanoe's Avatar
Kanoe's Avatar
That looks nice and clean. I wouldn't expect to find much rust on that one. Nice job!
-2001 Echo D.D.
Old 09-28-2020, 03:31 PM #103
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
@jross20 . Just curious what's on that frame? Just paint or some rubberized undercoating. I can see areas where the surface painted surface changes and was just wondering.
Old 09-28-2020, 03:39 PM #104
jross20's Avatar
jross20's Avatar
Oh this was after cleaning with acetone and then 2-3 coats of chassis paint. Before it was just an ugly black-gray. Only tiny tiny spots here and there with surface rust.
It's semi gloss chassis paint from summit racing. Their own brand. So far whatever I've painted with it has stayed nice and black. There is some strange stuff on the frame already, I wasn't sure what it was.
Old 10-30-2020, 10:01 PM #105
sugjavier sugjavier is offline
sugjavier will become famous soon enough
Originally Posted by sugjavier View Post
Haven't bought it but will now and let y'all know. I'm getting mine rustproofed with POR15 then Fluid film the week of October 21st. I'll ask them to take some nice pics before they take it down from the hoist.
The plugs I bought from ebay didn't work. It was so tight I couldn't plug the circle holes lol.
Anyways here's some after pics I took after driving it home after the motorcity auto spa place did a wonderful job detailing my car full interior and exterior, I provided them a gallon of fluid film, angle grinder with wire brush cups, fluid film gallon kit.
They did the underbody detail and painted it POR15, then sprayed it all with fluid film after. Ready for the winter!!!
They are supposed to text me after pics while it was up in the hoist so I'll post better ones once I receive them.
POR-15 or just Fluid Film-rsz_1rsz_20201030_164833-jpg  POR-15 or just Fluid Film-rsz_1rsz_20201030_165040-jpg
2001 Toyota 4Runner Limited. 231k miles.
sugjavier is offline   Reply With QuoteReply With Quote
film , fluid , frame , por-15 , rust
The end-all Fluid Film thread IL_Fletch Maintenance/Detailing 26 01-01-2024 06:01 PM
Fluid Film Applicator Last Man Standing 3rd gen T4Rs 3 08-13-2019 10:37 PM
Fluid film my frame? Bbanks97 3rd gen T4Rs 24 01-07-2019 03:07 PM
Fluid film prep ? jminz 4th Gen T4Rs 4 04-05-2018 03:12 PM
Fluid Film PSA A10GAC General Discussions 1 08-27-2016 01:25 PM
