Old 10-31-2020, 09:51 AM #106
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Looks good..
Old 10-31-2020, 11:26 PM #107
Niteghost Niteghost is offline
Real Name: Ty
Niteghost is on a distinguished road
Real Name: Ty
Went through and read all this I see POR 15 mentioned more than the KBS system. Currently trying to decide between the two? Any reason to pick one over the other?
2002 4Runner Sport -->Build Thread <--
2017 4Runner TRD ORP
2002 Toyota 4Runner - Sold
Niteghost is offline   Reply With QuoteReply With Quote
Old 11-01-2020, 06:11 PM #108
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
POR 15 is the older formula. I used both and I perfer KBS seal over the POR15.
Reasons:
1] Newer formula with UV light protection in the paint.
2] costs less then POR 15.
Just make sure you prep the metal correctly or it will rust underneath the paint coating.
That's my opinion anyhow.
Old 11-02-2020, 10:17 AM #109
Real Name: Ty
Real Name: Ty
Internal frame
1.) Power wash and clean all the dirt and debris you possible can get out of the frame you get out.
2.) Being scaling will be taking place. you need penetrating oils etc on the steel. FF will cover steel but will not penetrate the scale. (FF is good for a Top coat on a rusted frame especially if scaling is occurring)
3.) Use penetrating oils or fluids to coat the inside of your frame. A million choices here. Examples: Used Transmission fluid, WD-40, PB Blaster. Anything that penetrates and will seal the oxygen off the steel. So rusting will slow down and stop.
4.) Topcoat with FF or anything similar that will creep around inside the frame. Cosomoline, Woolswax whatever works for you.
External frame and underside:
1.) Power wash and clean all the dirt and debris off.
2.) Descale everything you can. Wire wheel etc. Get all the scale off and loose rust.
3.) This phase I am still experimenting on. Use a good Rust inhibitor on the steel to seal it off. Do not just primer and paint. it will just rust through that in the rust belt. I don't care what kind of paint its not going to seal it good enough.
Right now I am experimenting with Corroseal as my rust inhibitor layer. As its a metal etcher and sealer as one. I will not know how it holds up for a year or 2.
Even KBS seal will rust through if the metal wasn't peeped properly. They all will.. That part of the key is getting the metal clean and prepped to seal properly which is extremely hard to do upside down and underneath a car..;-)
4.) The topcoat can be whatever works for you paint, FF film wool-wax. Comeliness.
Note: (FF will not stay in fender wheels or areas that see a lot of pressure washing style actions) So either touch up every year or find something that better for that area. :-)
Thanks Brillo, I was actually going to follow what you said over in the "Frame Rust Prevention" Thread.
Old 11-02-2020, 02:55 PM #110
rickashay's Avatar
rickashay rickashay is offline
Real Name: Addison
rickashay is a splendid one to behold rickashay is a splendid one to behold rickashay is a splendid one to behold rickashay is a splendid one to behold rickashay is a splendid one to behold rickashay is a splendid one to behold rickashay is a splendid one to behold
rickashay's Avatar
Real Name: Addison
I live in Canada and have been building Toyota trucks for close to 15 years. I am very OCD and rust is not an option.
I have been using Fluid Film for about 12 years and every November I buy 2x spray cans of fluid film and have typically enough to coat the frame and suspension components. If it's a bad winter with a lot of freeze/thaw cycles I will often re-coat with a single can in January or february. This method has worked great and I am proud to say that my Toyota's are always rust free. Downsides are that your frame remains kind of "greasy" for ever but usually by the spring most of it has washed away.
I have also coated several of my frames with POR15, and although I think it is a decent product, I would not rely on it to keep rust away. For rust prevention alone, my vote still goes to fluid film. My $0.02
rickashay is offline   Reply With QuoteReply With Quote
Old 11-02-2020, 04:43 PM #111
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Like I stated many times. Its your rig and do as you wish. :-) Many ways to accomplish the same thing. The goal is to not have the frame rust. ;-) I just offer opinions based on what I have done and seen. The interesting part is that the Rust prevention varies widely because of the environment your in.
So what works in AZ may not work in FL. What works in PA maybe different then WA and what works in Maine maybe great for Canada.. ;-)
Plus what the condition of the steel is when you start treatment plans vary the results as well. :-)
Old 01-07-2022, 12:48 PM #112
Hitmanhink Hitmanhink is offline
Hitmanhink is on a distinguished road
Wow great thread! Lots of good feedback here. I’m bringing my ‘05 from CA over to NY next month and definitely want to get this thing as protected as possible. Good to know about the potential challenges with welding, but I don’t foresee that being a necessity. Since my rig is coming from CA there’s not much rust but some on the exhaust and some minor spots elsewhere. I’m trying to decide if I should start with Por15 straight off the bat, even though there’s not much rust, but then follow up with FF as annual maintenance.. that kinda seems to be the overwhelming positive response for those of you commenting from the Northeast part of the rust belt. Anybody have issues starting with Por15 then using FF on top of that?
Hitmanhink is offline   Reply With QuoteReply With Quote
Old 01-07-2022, 01:46 PM #113
Sarki Sarki is offline
Sarki has a spectacular aura about Sarki has a spectacular aura about
If there’s no rust and coming from west coast I would say you’ll be fine just going with an annual application of Fluid Film, WD-40 or whatever product you choose.
I don’t see the need for POR-15 or similar since you’re starting with a clean rust free vehicle.
2002 SR5 Sport 4WD
Sarki is offline   Reply With QuoteReply With Quote
Old 01-07-2022, 02:35 PM #114
whyzee125 whyzee125 is offline
whyzee125 is on a distinguished road
I would use Eastwood Epoxy primer rather than POR-15. POR is a good product but very finicky and often comes off in flakes, taking the fluid film on top of it with it if the application is not done just right. Fluid film is very effective but since you've got some bare spots, I'd hit the whole undercarriage with the Epoxy primer in a can, then paint with topcoat of your choice, then fluid film. It will look a ton better plus offer better protection.
Originally Posted by LittleCaesar View Post
At 5'7", I'd need a rocket up the wazoo to get in it.
But it looks good. I can't wait to see it being driven.
whyzee125 is offline   Reply With QuoteReply With Quote
film , fluid , frame , por-15 , rust
The end-all Fluid Film thread IL_Fletch Maintenance/Detailing 26 01-01-2024 06:01 PM
Fluid Film Applicator Last Man Standing 3rd gen T4Rs 3 08-13-2019 10:37 PM
Fluid film my frame? Bbanks97 3rd gen T4Rs 24 01-07-2019 03:07 PM
Fluid film prep ? jminz 4th Gen T4Rs 4 04-05-2018 03:12 PM
Fluid Film PSA A10GAC General Discussions 1 08-27-2016 01:25 PM
