09-21-2019, 12:11 PM
Real Name: Eddie
Real Name: Eddie
Help With 3RD Gen Transmission Drain Plug Gasket
Hello All,
My local Toyota parts guy (who is an all around good guy) insists this is the right part, but looking at Timmy's vid and the drain plug itself, makes me think otherwise.
Can a member(s) confirm this is the right gasket for the tranny?
Also, and if it not correct, if you post a pic of the correct part, that would be a big help.
I'm certain I have the right part #, but the part is just not right.
Thank you.
Eddie
2001 T4R SR5 - 180k miles and counting.
09-21-2019, 05:59 PM
Apples and oranges but that is the style I get from the dealer for my 93 corolla. I would think 4Runner would be similar. Mines a manual so can’t be certain.
-1993 Corolla Wagon 7AFE
-2001 Echo D.D.
09-21-2019, 06:54 PM
I can't confirm yours is correct, but here is the crush washer I used recently on my transmission. No leaks and it fit perfect. The other side is smooth. This is aftermarket from Amazon.
09-21-2019, 08:35 PM
Real Name: Jerod
Real Name: Jerod
Trans pans have crush washers? I've never used one lol.
09-21-2019, 08:48 PM
Real Name: Jon
Real Name: Jon
I thought mine was copper washer.... (could be wrong though)
GASKET (FOR TRANSFER OIL PAN); GASKET, DRAIN PLUG (ATM); GASKET, TRANSMISSION DRAIN PLUG
This Fits Your 1998 TOYOTA 4RUNNER SR5-V6(-0008),SR5(0008-) 3400CC EFI, AUTOMATIC 4-SPEED
Part Number: 3517830010
Supersession(s): 3517850010; 9034110078
The picture of this part looks like what you have there.. Do the part numbers match..;-)
Those type though are the single use one.. Copper crush washers are resuable
09-21-2019, 08:57 PM
Looks correct, it's a small drain hole.
98 SR5 4X4 5spd, desert dune metallic, Toytech Eibach 3" lift, 1" body lift, RAD Rubber Designs splash guards, 4XInnovations bumpers, Doug Thorely Headers, Magna-flow converter, JBA muffler & tail pipe, RCI skid plate, SPC UCA's & rear LCA's, front sway bar links on rear, gen II rear links on front, Tundra brakes, '02 headlights, tail lights & sidemarkers, BFG 255/85R16 Mud Terrain T/A's 241,000 miles.
09-21-2019, 11:35 PM
Real Name: Eddie
Real Name: Eddie
Thanks for everyone's replies. Very helpful and I can now change my fluid knowing I have the correct gasket.
Eddie
09-23-2019, 12:50 PM
Real Name: Jerod
Real Name: Jerod
Originally Posted by brillo_76
Yes. They have a crush washer on them. Just like your Diffs and oil plugs too..
I replace the oil crush washer every oil change and buy them by the 10 pack because they fit all toyota oil plugs..
Oh, I've got a bunch of those too. I'll throw one on there next time I change the trans fluid (in like 5 years lol).
09-23-2019, 06:50 PM
Real Name: Jon
Real Name: Jon
Yes. For some reason I am thinking the original is copper from the factory. Now those newer crush are single use if they actually crush (have a lip that crushes in). Just like the original front end washer was a non reusable crush washer. I just try to keep my copper ones as they are so much better and multi-usable..
09-23-2019, 07:21 PM
I get aluminum ones from the local motorcycle shop.
Can reuse them many times.
09-23-2019, 08:00 PM
Real Name: Jon
Real Name: Jon
Is it pure aluminum washer or is one that has a lip that crushes down to seal..
Basically a flat washer that is copper and aluminum can be used many times but some of these are non flat ones. I wouldn't reuse too many times.. But worse case, you could always change if it starts leaking..
09-23-2019, 08:18 PM
It’s flat.
09-25-2019, 02:15 PM
Real Name: 3 Bears
Real Name: 3 Bears
just remember not to over tighten, these plugs like to strip the pan.
same with pan to tranny, those like to strip too.
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
