Old 09-21-2019, 06:25 PM #1
eurasiaoverland eurasiaoverland is offline
eurasiaoverland is on a distinguished road
Heater not coming on fully
Hi All
I have a 96 Hilux Surf (JDM 4Runner). I'm not sure about the US Market models, but my Surf has an electronically actuated heater control, which does not fully open the heater valve on the firewall.
I've checked the cable, and it looks fine, it isn't getting hung up anywhere and is held correctly in place. The servo motor works.
I'm beginning to think that it's time to replace my heater valve.
Has anyone else had this problem?
Thanks
EO
1993 Hilux 2L diesel manual - in storage.
1996 Hilux Surf 3RZ-FE manual - overland vehicle (and rolling restoration).
1989 Landcruiser BJ60 - undergoing full restoration and engine transplant.
Over 250,000 kilometres around Eurasia in Toyota trucks: http://eurasiaoverland.com/
eurasiaoverland is offline   Reply With QuoteReply With Quote
Old 09-23-2019, 10:49 AM #2
AntleredRuin AntleredRuin is offline
Real Name: Daniel
AntleredRuin will become famous soon enough
Real Name: Daniel
When you say 'electronically actuated heater control', do you mean that you have the full digital screen, vs the knobs or dials? Not sure about the Hilux Surf (especially the 96 model) but I had a similar issue on my 99 Limited T4R with the digital climate control.
You're saying the server motor works? Did you check the white nylon gear in the servo? Those are known to strip and thus fail to fully open the heater flap. The nylon gear doesn't make a full spin, maybe only 90 degrees or so, so I was able to simply remove the gear and flip it 180 degrees so the non chewed-up end was making contact with the adjoining metal gear.
AntleredRuin is offline   Reply With QuoteReply With Quote
Old 09-23-2019, 07:01 PM #3
jgue467's Avatar
jgue467 jgue467 is offline
jgue467's Avatar
Has anyone else had this problem? ...
Yes - my '01 had it replaced at 294K, works better now. Luck and enjoy the Runner.
Old 09-25-2019, 03:44 PM #4
Found my problem - the servo motor is fine (good tip to keep in mind though). The cable is stiff - the wound steel core musthave corroded slightly and becomes very stiff in the plastic shielding. The valve is perfectly fine.
I've got a new cable on order; if it is no longer in production (as a few less critical Surf-only parts have already been discontinued), I will trim back some of the plastic shielding and work some silicone spray lube into the cable. Interestingly, it seems to be the send of the cable which is in the cabin (not in the engine bay) which iscausing the problems.
Thanks!
EO
fully , heater , surf , time , valve
96 4Runner SR5 white smoke coming from exhaust, black soot/liquid coming out, stalls beefsix Problems & Warranty Issues 7 05-24-2018 03:44 PM
How do you fully disassemble CV's? yotatake2 3rd gen T4Rs 2 05-12-2016 05:51 AM
Floor fan not fully engaging? Morphyne 4th Gen T4Rs 0 01-04-2012 06:58 PM
smell coming and lots of heat coming from manual shifter compartment desertrover Problems & Warranty Issues 0 10-18-2010 08:07 PM
Hi-po fully synthetic oil OK for 3VZ-E V6? headwerkn Classic T4Rs 1 07-07-2007 10:28 AM
