Old 09-23-2019, 10:17 PM #16
3bears 3bears is offline
Real Name: Joshua 3 Bears
3bears has a spectacular aura about 3bears has a spectacular aura about 3bears has a spectacular aura about
my 2000 often has 3 coolers. one factory oil cooler as shown above, one tranny cooler and filter in line, and a cooler in the back with cold "wrench lubricant"
2000 SR-5 V6 Auto . Desert Dune, Spectre intake, Borla muffler, Magnafine tranny filter, B&M cooler, Talls, KYB, Airlift 1000, DRL delete, Big 3 wire, full rack, TBU, Swapped in Elocker, some LEDs, PIAA headlights, , Amsoil
Old 09-23-2019, 10:25 PM #17
19963.4lsr5 is a jewel in the rough 19963.4lsr5 is a jewel in the rough 19963.4lsr5 is a jewel in the rough
When I rebuilt my 97 engine I soaked the oil cooler in a sealed can of acetone for probably 2 weeks. Before the acetone dunking I shot 2 cans of carb cleaner through the oil side.
Then I rigged up a pump and hoses and circulated mineral spirits through the oil side of the cooler until the fluid was clear.
Old 09-23-2019, 10:25 PM #18
BoomerBob's Avatar
BoomerBob BoomerBob is offline
BoomerBob will become famous soon enough BoomerBob will become famous soon enough
BoomerBob's Avatar
Originally Posted by 3bears View Post
since some markets and applications use this as the oil filter location, I wonder if with the right nipple you can just thread in another filter to act as a block off.
think I read that somebody actually did that and runs two filters
That makes sense. It would be good to know what filter/part number fits that back one. Unlike the front oil filter; the back one would take a filter with a male type screw in or possibly just an adapter to use the same as the front.
2001 2wd - Daily Driver
BoomerBob is offline   Reply With QuoteReply With Quote
Old 09-23-2019, 10:32 PM #19
BoomerBob's Avatar
BoomerBob's Avatar
I'd like to hear more about the back cooler and what the cold wrench lubricant is. Is this an engine oil cooler separate from the one on the drivers side that we are talking about in this thread?
On my 01 I don't have the engine oil cooler but I do run an external Hayden trans cooler with inline Magnafine filter. I think I'll do the same thing with the 98 simply to avoid the dreaded strawberry milkshake that trashes the transmission. Overheating the trans isn't an issue for the type of duty both these rigs see under my ownership so I don't put the trans cooler inline with the radiator.
Old 09-23-2019, 10:33 PM #20
I bet the male thread adapter is available, the male fitting on our blocks for the stock filter is not cast into the block but threaded in.
well don't know for sure on this engine, but is on most things ive worked on
was it sleepydad that wrote up something about this months back ?
Old 09-24-2019, 08:45 AM #21
BoomerBob's Avatar
BoomerBob's Avatar
I did a search and couldn't find anything on an adapter for this to convert the cooler into a secondary filter but it would be good info to have if someone has better search skills on this forum.
Old 09-24-2019, 12:18 PM #22
phattyduck is a splendid one to behold phattyduck is a splendid one to behold phattyduck is a splendid one to behold phattyduck is a splendid one to behold phattyduck is a splendid one to behold phattyduck is a splendid one to behold phattyduck is a splendid one to behold
Yes, it does. All US delivered 5VZ's have an oil cooler in that location. If it doesn't, you don't have the OEM setup on there.
'16 Honda Odyssey
Old 09-24-2019, 01:06 PM #23
wrench lubricant = beer
Old 09-24-2019, 01:13 PM #24
BoomerBob's Avatar
BoomerBob's Avatar
You're right; it does. I just looked. I didn't think it did because the shop owner that swapped the long block was asking about the second oil filter hole on the new engine but he must have realized it later when doing the swap then didn't tell me. I did the heads/head gaskets but didn't notice it at the time. Must have been concentrating on other things.
Thanks!
Old 09-24-2019, 11:21 PM #25
Cwarrenm Cwarrenm is offline
Cwarrenm is on a distinguished road
I don't mean to hijack this thread but I just did a flush/refill of my coolant today and noticed after I was done that I seem to be leaking quite a bit of oil from the oil cooler... Do I have to drain my coolant again before I replace the seals? I imagine I'll have to drain the oil too. Bummer.
Cwarrenm is offline   Reply With QuoteReply With Quote
Old 09-24-2019, 11:39 PM #26
Yep drain coolant. Some oil will come out removing the cooler but it shouldn’t hurt anything.
Old 05-30-2020, 04:16 PM #27
Ruiner's Avatar
Ruiner Ruiner is offline
Ruiner is on a distinguished road
Ruiner's Avatar
Originally Posted by BostonJon View Post
Hey everyone - replaced my oil cooler seals today. When I took the 24mm bolt off the cooler, about 1/4 pint of milky oil came out. However, when I drained the coolant before I started, the coolant was totally clear. Is it possible to have coolant in the oil but no oil in the coolant?
Interestingly, the PO must have used some kind of radiator stop leak because the coolant passage in the oil cooler was completely blocked with what seemed like a powdery substance. I suppose I haven’t had any oil cooling for a while now
my oil cooler just gave up and there's oil all under neath. I also have coolant in the oil but no oil in the coolant. I haven't pulled it off yet since I'm waiting on the delete plate to go in its place. Did yours end up being the cooler or was it the head gasket?
Ruiner is offline   Reply With QuoteReply With Quote
Old 06-01-2020, 09:34 PM #28
BostonJon BostonJon is offline
BostonJon is on a distinguished road
Sorry I never came back to this to post a conclusion. I know that’s a no-no on these “help me because...” threads.
I had forgotten that I had put a bottle of Ceratec in the oil after an oil change. That stuff has a creamy orange color to it which is why my oil looked a little milky. So thankfully no cause for alarm in my situation.
BostonJon is offline   Reply With QuoteReply With Quote
Old 06-01-2020, 11:15 PM #29
I have used that on two vehicles. It’s good stuff.
coolant , cooler , drained , oil , started
V6- coolant not siphoning back from coolant overflow (not overheating) djtc 4th Gen T4Rs 19 08-28-2015 09:11 AM
pink coolant and green coolant Larry Maintenance/Detailing 30 11-17-2014 11:09 PM
Dealer Coolant Flushed with Wrong Coolant? peebee 4th Gen T4Rs 34 08-23-2014 03:33 AM
Coolant Leak- Drivers side coolant manifold? Shibby! 3rd gen T4Rs 19 12-28-2012 09:37 PM
22RE headgasket 'reversal' - coolant in oil, then oil in coolant kompression 3rd gen T4Rs 0 09-20-2005 12:23 AM
