Originally Posted by nissanh
Sounds like a loose bolt/nut, Do you have the metal plate ("t" shaped) and "W" shaped spring holding the brake pads tight?
Tbh I can’t recall since I did the TBU 4 years ago. The pads are still at around 70%. I think given the time since they were installed, I should probably replace my brakes soon, so I’ll be sure to check. I have always put the shims and anti-squeal clips in, and I didn’t see either one of those parts hanging loose.
