Old 09-24-2019, 07:48 PM #16
sleepydad's Avatar
Real Name: Andy ಠ_ಠ
sleepydad's Avatar
Real Name: Andy ಠ_ಠ
Originally Posted by Bad Luck View Post
Is it worth the effort to do the roof in your opinion?
if you have the headliner down then yes, if not then don't pull down the headliner just to sound deaden.
I have a noisy rack so it did cut down wind noise for sure.
I also did the top of the moon roof sliding cover and that also helped. with the cover open you can really hear the wind noise.
I should also add I re-did the headliner and paved over with spray adhesive and the foam backed head liner material. I'm sure this also helped the roof rack wind noise.
when I think back all the things I have done to this poor truck.
Old 09-24-2019, 08:00 PM #17
gamefreakgc's Avatar
Real Name: Jerod
Real Name: Jerod
Agreed, pulling the headliner is not easy and the large clips will break or worse, the headliner itself can crease and tear. I don't recommend pulling it unless you have to such as for a sunroof repair.
326WHP 347TQ
Old 09-25-2019, 11:02 AM #18
WeakSauz WeakSauz is offline
WeakSauz has a spectacular aura about WeakSauz has a spectacular aura about WeakSauz has a spectacular aura about
+1 to the above guys...
Do not pull the headliner to sound deaden the roof, unless you're refinishing or replacing the headliner.
It is delicate. It will crease permanently if you sneeze at it the wrong way.
2000 SR5 4x4 | Geared, Locked and Fully restored OEM+ build.
Forged and Cammed 1UZ Single Turbo, Standalone ECU + Built R150 in process. Why, you ask? Because it makes no sense in this platform, and I love it!
WeakSauz is offline   Reply With QuoteReply With Quote
Old 09-25-2019, 12:38 PM #19
raKnizek's Avatar
raKnizek raKnizek is offline
Real Name: Alex
raKnizek will become famous soon enough
raKnizek's Avatar
Real Name: Alex
Originally Posted by sleepydad View Post
I also did the entire truck including the doors. huge pain. I also did a lot of the internal plastic. rear door inside plastic cover made a big difference.
mine was 100% dynamat
if you still have some left and want a nice little bump, do the cup holders. it's amazing how much more solid dynamat can make thin plastic feel like it's 2x thicker.
agree you can't get rid of the wind noise because the windows are single pane. I also did the roof because I had the headliner down as well. it did help a bit.
I guess the reward is shutting the door with that solid feeling. in the end I'm glad I did it but not sure I would do it again.
Good idea on the cup holders. I am all about that solid feeling. I may consider doing the roof at some point especially if I ever add a roof rack of some kind
2000 SR5 3.4, Manual, 4x4
Icon 2.5 extended coilovers & 2.0 rear, JBA UCAs
265/75R16 General Grabber X3 on LC80s
Full Skid Plates
raKnizek is offline   Reply With QuoteReply With Quote
Old 09-25-2019, 12:40 PM #20
raKnizek's Avatar
Real Name: Alex
raKnizek's Avatar
Real Name: Alex
Originally Posted by 4runnerfiend View Post
did mine as well. minus the roof. what a pain, however I am happy with the result. again it feels more solid. it was more worth it for me because I got to really clean the carpet and seats really well. all the panels in the back were coated with dust. Vehicle feels and smells.. newer haha 285 k I'll take what I can get
I was surprised how much dust was behind all the panels and doors even at 120kmi
Full Skid Plates
Old 09-25-2019, 12:43 PM #21
raKnizek's Avatar
Real Name: Alex
raKnizek's Avatar
Real Name: Alex
Appreciate all the heads up on headliner. Glad I just happened to make the right choice on that...
What do you mean by "paved over"?
Full Skid Plates
Old 09-25-2019, 03:29 PM #22
sleepydad's Avatar
Real Name: Andy ಠ_ಠ
sleepydad's Avatar
Real Name: Andy ಠ_ಠ
2000 limited SleepyDad build - Toyota 4Runner Forum - Largest 4Runner Forum
so I did a test run on a headliner where I pulled the old felt off. then I did a different headliner by leaving the existing felt on. aka paved over the existing felt.
leaving the existing felt on the headliner works much better.
Old 09-25-2019, 03:37 PM #23
sleepydad's Avatar
Real Name: Andy ಠ_ಠ
sleepydad's Avatar
Real Name: Andy ಠ_ಠ
it's crazy how much of a difference just little stuff like this makes in the feeling of the plastic.
I stuck some of that recycled cotton insulation into the void.
Sound Deadening Write-up
Old 10-05-2019, 08:28 AM #24
raKnizek's Avatar
Real Name: Alex
raKnizek's Avatar
Real Name: Alex
This is a cool idea. I ran into issues reassembling my cup holder/center console. The bottom surface of the cup holders sat too closet to the carpet underneath that any added material, either under the carpet or on the cup holder caused it not to fit. I actually had to go back and cut out some of the MLV I put there so I could get it back together.
Full Skid Plates
Old 05-16-2021, 11:58 AM #25
raincoyote's Avatar
raincoyote raincoyote is offline
raincoyote is on a distinguished road
raincoyote's Avatar
Thumbs up
I just read through this entire write-up, and I have to thank you. Most of the sound deadening threads are naturally related to audio, but you attacked it from the same POV that I am in that I just want a more luxury feel to the cabin. I also have realized that this is one DIY that I'm not doing myself just because it looks like it's a complete PITA so I'll be paying for install on this. Great thread!
raincoyote is offline   Reply With QuoteReply With Quote
Old 10-18-2022, 01:19 AM #26
CougarHound's Avatar
CougarHound CougarHound is offline
CougarHound is on a distinguished road
Don't your door latches stick cause of the foam? I did this to my doors but now my front door latches stick sometimes. Especially when it's cold. I took every effort to make sure the latch mechanism is unobstructed and free to move. I kinda regret all of that time and money I spent tbh. It was definitely a pain for marginal improvement. I also broke the door clip retainer trying to get the MLV in. I gave up on that and just used the CLD tiles and called it a day.
CougarHound is offline   Reply With QuoteReply With Quote
Old 10-18-2022, 08:04 AM #27
jgue467's Avatar
jgue467 jgue467 is offline
jgue467's Avatar
All I know is my '01 Runner has far better sound deadening from the factory than my '15 Sequoia or '13 Kia (all models), have no idea how newer Runners are but if my Sequoia is any indication....
door , foam , noise , rear , sound
Sound Deadening Project Write Up DreamsOfDirt 5th gen T4Rs 72 01-31-2022 05:28 PM
Sound deadening -- WOW!!! GrantK 5th gen T4Rs 22 12-24-2012 01:52 PM
4th gen sound deadening drapaki 4th Gen T4Rs 5 01-02-2011 06:30 PM
Sound Deadening chayos00 Engines / Suspension / Wheels / Tires / Audio / Accessories 11 10-29-2009 02:39 PM
Sound Deadening Help!! Tego Engines / Suspension / Wheels / Tires / Audio / Accessories 3 07-23-2009 05:44 PM
