Old 09-29-2019, 01:27 PM #16
BoomerBob's Avatar
BoomerBob BoomerBob is offline
BoomerBob will become famous soon enough BoomerBob will become famous soon enough
BoomerBob's Avatar
Originally Posted by redhot View Post
I did some more research and yes that's the conclusion I came to also. The added feature the MX offers that's I was interested in was the transmission temp because mine is an automatic but with 97 I found out that data is not available. The the later 3rd Gens and I'm not sure what year it starts but transmission temp is available so the MX could be something to consider if someone has an 02 (and possibly an 01 I don't really know) but it seems it require a bunch of manufacturer codes. I found the codes on the scangauge site (a competitors product for those not familiar). So I'm ordering the EM plus for my 97.
I'd research before buying the MX though even if you have an 02, seems it could get complicated setting it up.
You're right about the MX model not being able to read the trans temp before 1999 models but if you buy the MX you can always transfer it to a newer T4R or other car/truck later on since it simply unplugs. The programming of the codes is straight forward.
This is the code for the 99 and later trans temp.
TData: 686AF101B40000
TCtrl: 85
RCtrl: 00
RPos: 2808
Mtch: 41B400
X: 0009
/: 0005
+: FFD8
Out Format: 00
Ave: 00
Left/Right: 31
You can read more about it at the link below.
Ultragauge 1.3 MX Question - Trans Temp??
2001 2wd - Daily Driver
BoomerBob is offline   Reply With QuoteReply With Quote
Old 09-29-2019, 01:49 PM #17
redhot redhot is offline
redhot is on a distinguished road
TCtrl: 85
RCtrl: 00
RPos: 2808
Mtch: 41B400
X: 0009
/: 0005
+: FFD8
Out Format: 00
Ave: 00
Left/Right: 31
True, but I don't plan on getting rid of my 97 anytime soon. I put a 99 engine in it 2 years ago that had 19K original miles on it so I plan on driving it a long long time. Of course, one never knows what will happen some dumbass could run into you or cause a wreck and total it etc.
Also, there are a few features the MX doesn't have that the EM does have. Really the trans temp was the dealbreaker for me. Now, later on down the road if I like this product (which I think I will) I may get the MX for another vehicle I have. Thanks for the info!
redhot is offline   Reply With QuoteReply With Quote
Old 09-29-2019, 04:58 PM #18
BoomerBob's Avatar
BoomerBob's Avatar
Which features does the EM have that the MX doesn't that you like?
Old 09-29-2019, 05:21 PM #19
Well, to be honest the extra features don't really interest me much but this is what it offers that the MX doesn't for anyone who may be interested.
* Readiness Monitors
* Performance Measurements
* Additional Wide O2 Sensor support to track Stoichiometric AFR via Lambda
I guess my whole thing with the MX is it seems the EM Plus would be much easier to set up. With the MX I have to enter that code stuff it seems for many of the parameters. Are you saying like it's not that big of a deal? Maybe you'll talk me into buying the MX. Can I add or change the name of a gauge like assuming my vehicle did have trans temp could I label the gauge "Trans Temp" etc?
This is the list of codes I found.
>> X-Gauge Categories >> ISO – VPW
Old 09-29-2019, 05:34 PM #20
Now you've got me leaning toward the MX again. I tried ordering one but it won't let you add it to your cart unless you select a"programming option" for certain vehicles and of course our 4Runnners aren't on the list.
So it seems the only way to order one it to select a different vehicle then I assume I have to remove the programming that it would come with and program for 4Runner. Seems like a royal pain.
*** EDIT - I see now I can do a factory reset so I think I'll order the MX. Hope it's the right choice.
*** EDIT EDIT - Went to order and the MX is $10 more. I swear they were all the same price yesterday when I looked at them. Anyone know?
OKay, went ahead and ordered the MX. I guess I just didn't notice the price difference but with shipping and all it's just under $100. I really like this for the custom alarms you can set for temps etc. Should be worth the money.
Old 09-30-2019, 02:26 AM #21
BoomerBob's Avatar
BoomerBob's Avatar
There are no wrong choices. If you have a pre-99 then you just won't have that option on the trans temp. If it's something you feel is important to have; you can always get a separate gauge for that if the pre-99's have a trans temp sensor or a way to install one.
My personal favorite gauges are the coolant temp, intake temp, Instant MPG, average MPG, and MPH. With the alarms set on the coolant and trans temp (now that I know where the upper norms are) I can feel more confident in having time to shut it down if something goes wrong under the hood when I'm not looking at the gauges. The intake temp give the actual outside temp when you first start the rig but then so does the coolant temp. The MPH is a couple of MPH different than my dash gauge and more accurate when compared to NAV readings.
At some point I'm going to get one of these for my old 99 Mustang GT. It won't have as many options as the T4R but it will still be worth it.
Note: For those who do have to change the trans temp code; it's a little awkward until you get the feel for how it wants you to work it. Kinda like getting used to the computer mouse. Before you know it you're doing it by second nature like typing.
FWIW: I too struggled with which one to get. I even ordered the EM first then asked them to cancel it so I could order the MX. I guess I wasn't confident because I had no experience with them at all. Now that I do; it's a no-brainer to get the one that can do a bit more... just in case. One of the hardest things to do at first was deciding which gauges I wanted on the first page which is mostly what I'll be looking at. Probably a good idea to write down which gauges you want for each page and in what order so you can more easily set them up that way. With 7 pages you will quickly run out of things you want to set up. A lot of it is more info than I care to see. TMI. I found that 6 items per page worked best for me. The top two (1 and 2) are in larger text than the bottom 4. With 8 items they are the same size text.
Old 09-30-2019, 11:15 PM #22
Thanks for all the info! Yeah I'm going to look into some way to do trans temp monitor. I take my 4Runner on 1000 mile trips straight through only stopping for gas and restroom. This is like 14 to 15 hours of driving and I know the transmission gets hot especially when going up long steep grades etc. Would be real nice to be able to monitor the temperature to know where it's at. I wish the 97 had this so the Ultragauge could handle it all but oh well. I'll start researching how to do it unless anyone here knows?
Old 10-01-2019, 08:26 AM #23
thegipper's Avatar
thegipper thegipper is offline
thegipper is a jewel in the rough thegipper is a jewel in the rough thegipper is a jewel in the rough
thegipper's Avatar
You can buy an aftermarket tranny temp gauge. You would mount the sensor on the tranny pan or inline on the send line that goes to the radiator (where most people install it). I've had mixed results with glowshift gauges but others haven't had any issues. I believe autometer also makes good gauges but cost a bit more.
1999 SR5 4x4 Auto for parts
2011 Camry SE V6
2011 Highlander Limited
thegipper is offline   Reply With QuoteReply With Quote
Old 10-05-2019, 06:34 PM #24
rexassian rexassian is offline
rexassian is on a distinguished road
Update to my original problem, new valve is in, I took it wheeling today, had no issues with heat (it was 90+ outside) nor with any head warpage.
So first what I did was bypass the old valve with a 4" long 3/8" MIP brass pipe from whole despot and flushed the fluid. That looked fairly clean which makes sense since the PO did the water pump and timing belt about 10k miles ago. I got the engine up to temp (about 190) several times and burped the fluid and the drained, just like Tim's video.
I then swapped in the new valve but I dropped the mount by about an inch. I have a 1.5" body lift so I'm guessing that plus wheeling caused more stress on the old part where the engine hose comes into the valve. I just used a basic flat bracket and a stainless screw and lock nut to attach the bracket to the valve first, be sure to bend the tab out of the way. Then attached the whole thing to the firewall using the existing bolt.
See picture links below, everything is running great, I drove an hour to go wheel, idled and wheeled for about 3 hours, then drove back home. Thanks to endive for all the help.
BTW, I'm cheap, so I got a basic Bluetooth obd2 dongle and set up an alarm on torque app to keep a closer eye on the coolant temps. The scan gauge sounds nice but I don't need that and don't need the additional features. My runner is manual transmission so I don't have to monitor trans temps.
bypass pic
bracket pic
bend tab out of the way
all our back together
rexassian is offline   Reply With QuoteReply With Quote
broke , common , coolant , engine , valve
Radiator hose popped off, engine overheat draymondgreen69 3rd gen T4Rs 21 12-22-2018 11:56 AM
Coolant Reservoir Bubbles / Near Overheat 3rdGen2002 3rd gen T4Rs 14 06-12-2018 10:46 AM
Broke Air Pump Check Valve TerraCrawler 5th gen T4Rs 7 07-10-2017 07:29 AM
Transmission D or 4? Overheat trans or lug engine hoggy 4th Gen T4Rs 5 09-13-2007 08:06 AM
Valve Stem Broke, Need advice... ASTIGTOITS 4th Gen T4Rs 0 07-17-2007 12:50 AM
