Sent from my SM-J337V using Tapatalk |
Yes I am 100% sure my pipes are 43 inches. Unless your pipe is sticking out 1.5 inches past mine on both sides. I honestly don't know what to say. https://uploads.tapatalk-cdn.com/201...0f4e8e3bfa.jpg
Thanks for your looking into this and the picture. It appears that my note was off.
Upper Rear Control Arm
Anyone got any advice for fixing this? This is the rear control arm bracket connection with the axle. Haven't found many other people online with this issue.https://i.imgur.com/9Mlr6D7.jpg
2 Attachment(s)
Glad I found this thread! My 99 4Runner has rust-cancer on the rear portion of the frame rails. The left side area where the hitch mounts to the frame is very bad, as well as where the left frame mounts to the rear body mount. The right side isn't quite as bad, but it's not far behind. The rust on the left side is bad enough now that the body has separated from the frame/cab mount. Shaking the hitch causes a "clunk" where the rusted remanence of the cab mount hits the body. There is absolutely no way I'd tow anything without fixing this first, and I know I'll be towing about a 2000lb load in a couple months (i.e. I need to get on the fix right away).
I'm thinking of buying the ART-221-S and ART-222-S to repair the frame sections and body mounts on both the left and right sides. From what I can tell, this looks like it would produce an acceptable fix. I don't seem to have much noticeable frame rust forward of the spare tire cross member, but the inner section of the left frame from the spare tire cross member to the frame rear end is almost totally gone from rust. Just thinking out loud and sharing. Anyone else fighting rust in this same area and successfully repair theirs? Does this seem like a good plan? I've done a little welding in the past, but a good friend of mine (I'm lobbying to help) is a very experienced welder and has good MIG welding equipment. |
You probably can still buy that body mount oem off toyota as well. My perfered method is to clean the frame completely out and weld the replacement plates on the inside of the frame. As they rot from the inside out. :( Lots of folks like the rust repair kits as well. :) Sent from my SM-A505U using Tapatalk |
Yes take a look at my build thread as most of my information are frame fixes.. You need to descale all of that rebuild the frame section itself. Then put a new or used body mount bracket welded in the old ones place. A 2nd option would be to find another section of the frame at a junk yard etc that's good slice it off. Then cut your bad section off putting plates on the inside frame rails then weld it all back together.. :-) |
Frame Rust
1 Attachment(s)
I've got a pretty big hole and a smaller hole next to it on my 2001 4Runner with 240k miles. Worth repairing? Or even safe to drive right now?
4 Attachment(s)
Here are some pics of mine. Not the prettiest weld job but it got the job done. Painted after these pics. |
Search Engine Optimisation provided by
DragonByte SEO (Pro) -
vBulletin Mods & Addons Copyright © 2024 DragonByte Technologies Ltd.
User Alert System provided by
Advanced User Tagging (Lite) -
