Old 11-14-2022, 03:56 PM #31
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Originally Posted by STLclone View Post
I've got a pretty big hole and a smaller hole next to it on my 2001 4Runner with 240k miles. Worth repairing? Or even safe to drive right now?
In my state, any rust hole in a frame is instant inspection fail. Now That can be fixed. As I am fixing an arch hole now in my passenger arch.
My method is internal plating of boxed frames. You have to be careful when how much steel is rotted away though. This is why everyone recommends the external plating from safety cap which is a good method except for 2 things. Cleaning the inside of the frame out and coating it with rust prevention liquid of your choice. If folks would clean out the rust and scale out of their frames then coat and paint or coat it with a rust prevention liquid this would slow down the internal rotting of the metal and make it last longer.
My one frame I did was experimental and thrown together in 2015. Because I did nothing but just plate it in 2015, I have to go back in areas to fix it again. Along with fixing other areas that were fine in 2015. So I am done with external plating unless there is no other way to fix it and is some cases there inst.
You mostly have 5 to 7 years left if your rig is in the rust belt if you do nothing to slow down and stop the rust with external plating. As the steel will continue to rot away inside and will be up to your weld lines by then.
Well that is what my experiment showed here in western pa on my Tetanus 1.
autorust , finally , kit , market , ordered
Simple Frame Rust Repair/Prevention. shootmymime 3rd gen T4Rs 81 11-03-2021 03:39 PM
Need Advice: Frame Damage From Accident and Frame Rust Whammy 4th Gen T4Rs 11 08-29-2018 07:46 PM
Remove body from frame? Lower control arm rust repair LookAtThatDog 3rd gen T4Rs 15 07-12-2017 01:21 PM
1996 4runner frame repair and swap. Bad_Vision 3rd gen T4Rs 8 12-31-2016 04:19 PM
Frame Restoration on my 97 (frame removal, repair, and upgrades) blain_gatterdam 3rd gen T4Rs 2 05-21-2015 12:17 PM
