Old 10-25-2022, 11:41 AM #1
fourfive's Avatar
fourfive fourfive is offline
fourfive is a jewel in the rough fourfive is a jewel in the rough fourfive is a jewel in the rough fourfive is a jewel in the rough
fourfive's Avatar
Hitch carrier + fishing/beach/utility cart
My version of a hitch carrier that also functions as a utility cart. The primary purpose was to have a cart I could take on beach or fishing trips that wouldn't take up additional travel space & would actually roll in the sand. The polyurethane balloon wheels seemed gimmicky & weren't cheap but made a huge difference in the sand compared to traditional plastic or pneumatic rubber wheels which made pulling a cart feel like you were dragging a rock across the sand.
I cut out the axle crossmember from my 800lb capacity gorilla cart & attached it with u-bolts to the hitch carrier. This allowed me to retrofit the swivel axle assembly & handle from the gorilla cart. Since the axle bore size on the poly & rubber wheels were different, I made removable axles using threaded galvanized pipe & iron floor flanges to be able to use either wheel. I considered using my larger steel hitch carrier for this project to allow for more travel space but decided to use my smaller aluminum HF carrier to make it lighter to pull in the sand. It was nice to be able to unhook the hitch carrier & immediately roll it to where I needed to unload it. The poly wheels I went with are 12" in diameter & 2 wheels are rated for 240#. I also made removable fishing rod holders so they wouldn't get in the way when strapping things down for travel.
Parts:
Aluminum HF hitch carrier
1/2" id x 8" threaded galvanized steel pipe (qty 4)
1/2" id threaded galvanized iron floor flange (qty 8)
3/4" galvanized iron floor flange (qty 4)
12" poly balloon wheels (qty 4)
4 cotter or hitch pins
Aluminum mesh
*Parts taken/cut from 800lb capacity gorilla cart: front & rear axle assemblies,, swivel handle
1. Black 2002 SR5 4x4 5vz: Front Toytec Ultimate coilovers/eibach 600#, SPC UCA, durobumps Rear Bil5100/Superflex, SS adjustable panhard, PCK, durobumps Body Lift 2" 4crawler Tires 315/75/16 BFG KO2 Wheels SCS F5 Matte black 16x8 3.5bs Armor Custom bolt on rock sliders (no frame drilling)
2. Black 2001 SR5 4x4 5vz: stock
3. Black 2018 TRD Pro (wife’s): Armor Custom bolt on rock sliders (U-bolts)
fourfive is offline   Reply With QuoteReply With Quote
Old 10-25-2022, 01:28 PM #2
mtbtim's Avatar
mtbtim mtbtim is offline
Real Name: Tim
mtbtim's Avatar
Real Name: Tim
Now that's a Sic Mod! Obviously not meant for wheeling trips due to the severely reduced departure angle, but for your intended purposes, it looks like it will work great.
Old 10-26-2022, 11:48 PM #3
Romeo1's Avatar
Romeo1 Romeo1 is offline
Romeo1 is just really nice Romeo1 is just really nice Romeo1 is just really nice Romeo1 is just really nice
Romeo1's Avatar
Very cool indeed. Great ingenuity there.
99’ Black “Highlander” sport, oak, 5VZ auto, 4.30 axle, e-lock, 265/75 Grabber X3,, Bilstein 6112 (2”) front 5160 rear shocks, OME 2906 springs, Durobumps, 4x Inovations front middle rear skid plates, 4XI square TRD tube sliders, lil skips tank skid, lotus dev RCA skids, overland custom sway bar links, Amp’d hidden winch, warn Vr Evo 10s
Romeo1 is offline   Reply With QuoteReply With Quote
Old 10-27-2022, 12:02 AM #4
theriddler's Avatar
theriddler theriddler is offline
theriddler is on a distinguished road
theriddler's Avatar
What an awesome idea...well done!
2002 4Runner Sport Edition-285/75R16 Duratracs, OME suspension, TRD wheels, Shrockworks front/rear bumpers, White Knuckle sliders, etc.
theriddler is offline   Reply With QuoteReply With Quote
Old 10-27-2022, 12:33 AM #5
gamefreakgc's Avatar
Real Name: Jerod
Real Name: Jerod
Great reminder to go fishing more. I've only been out once this entire year. I bet that makes it a whole lot easier getting a chair or canopy out to the best fishing spots!
326WHP 347TQ
Old 10-27-2022, 11:51 AM #6
shadow247's Avatar
shadow247 shadow247 is offline
shadow247 is just really nice shadow247 is just really nice shadow247 is just really nice shadow247 is just really nice shadow247 is just really nice
shadow247's Avatar
Looks great. My only concern is that departure angle on those tires. I feel like you will be scrubbing those tires all over place on mild inclines pulling into garages, etc... Maybe one of those hitch extensions that raises the hitch 4 inches would be a good idea.
The 4Runner Show
shadow247 is offline   Reply With QuoteReply With Quote
Old 11-14-2022, 03:36 PM #7
fourfive's Avatar
fourfive's Avatar
Thanks. A hitch extension would be a good idea but the downside would be possible interference with opening the hatch. Driving with the axles/wheels mounted is something to be considered depending on the driving conditions & the vehicle it's mounted to. Since my 4runner has a lot of ground clearance, it wasn't an issue with pavement driving but on my wife's 5th gen, I'd likely unbolt the axles which is held on by 2 u-bolts each. For off pavement driving it would definitely be wise to unbolt the axles.
carrier , cart , hitch , sand , wheels
Curt hitch spare tire carrier Long Beach ca Sakums20 For Sale: Non-T4R Items 1 05-31-2017 02:52 PM
WTB: Gen 4 Roof Rack, Rear Bumper with Carrier or hitch mounted tire carrier yotanoob Want to Buy/Trade 0 11-23-2016 01:15 AM
Surf fishing/ beach rigs?!? floydamus Classic T4Rs 16 02-20-2014 12:58 AM
Fishing/Beach Rig LovesBass 4th Gen T4Rs 5 10-01-2011 05:31 AM
