Old 09-24-2019, 02:50 PM #16
Difflock's Avatar
Difflock Difflock is offline
Real Name: Stu
Difflock is on a distinguished road
Difflock's Avatar
Real Name: Stu
Originally Posted by thegipper View Post
Did a quick search and found this video, it may help.
YouTube
This helps me very much, thank you
Difflock is offline   Reply With QuoteReply With Quote
Old 09-25-2019, 09:22 PM #17
Difflock's Avatar
Real Name: Stu
Difflock's Avatar
Real Name: Stu
4Hi not working.
This is my t case linkage, nothing looks off to me?
Whats this springy thing? Its bent though
Old 09-25-2019, 09:35 PM #18
Difflock's Avatar
Real Name: Stu
Difflock's Avatar
Real Name: Stu
So I removed that bent spring thing, reinstalled my knob and now my front driveshaft is locked when my tcase is in the 4hi position! However my dash light doesnt come on.
What is this spring thing? And do I need it? When I pulled the boot, it was just sitting in there....
Old 09-26-2019, 01:21 PM #19
That spring tensions the shifter towards the '2WD/4WD' side of the shift pattern. It should be in there. The shift lever rides up and down on the flat section of spring in the middle. Look at the orientation in the pic below.
Generally, you don't want to remove the cover for the shift lever. The 'correct' way to remove the shift lever is to pull the c-clip and leave the housing in place.
Of course, since you are looking to fix whatever is messed up below, you needed to remove that cap - but getting the lever in correctly is easier once the cap is in place. Also consider getting a new shift seat for the 4WD shifter, it is probably disintegrated (it is gone in the picture above, about to get replaced).
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Old 09-26-2019, 01:56 PM #20
Difflock's Avatar
Real Name: Stu
Difflock's Avatar
Real Name: Stu
Id assume to stop from bumping the shifter out of 4hi and into neutral accidentally? In the picture mine is pretty bent, would you suggest just leaving it out for the time being while a get a new one? I looked online for quite a while, I could not find a part number on that spring anywhere, you wouldn’t have a part number would you?
Old 09-26-2019, 06:42 PM #21
PN should be: 36349-35010, SPRING, TRANSFER SELECT RETURN
It looks to be the same for most/all of the j-shift cases (conceivably different for the forward shift case. You can probably bend it back into shape.
And yeah, it is probably mostly for safety. You can easily hit neutral when you are trying to go back to 2WD if you don't have that spring in there.
4hi , 4low , fine , light , works
2003 4Runner SR5 V6 - Auto-door lock, not working for a year, now magically working! Cookster Problems & Warranty Issues 1 08-09-2019 05:39 PM
Headlights not working on low, high beams working. HELP buckeye4runner08 4th Gen T4Rs 8 02-12-2017 11:29 PM
Turn signal not working? Std trouble shooting isn't working swapmeet 4th Gen T4Rs 9 09-14-2014 11:21 PM
95 rear window not working, motor can be heard working DLPDLP Classic T4Rs 22 01-29-2012 08:17 AM
2001 remote not working, rear wiper/defog not working theedudenator 3rd gen T4Rs 1 02-06-2011 01:10 AM
