Old 09-26-2019, 12:19 PM #1
kc9rzj kc9rzj is offline
Real Name: Jeremy Smith
kc9rzj is on a distinguished road
E-locker Wiring
So I have a unique problem. I know there are lots of write-ups on here about wiring up an E-locker for a 4runner that didn't come factory with one. None of them have info on what wires do what. I am trying to find a diagram that shows what wires to power to activate the actuator to lock the diff. I am trying to remove the 3rd member and have tried everything to remove the e-locker to do it manually but have been unsuccessful so far. I thought I could just hotwire the elocker to lock it it and then be able to pull the 3rd member out without having to remove the e-locker.
kc9rzj is offline   Reply With QuoteReply With Quote
Old 09-26-2019, 01:10 PM #2
redshift83's Avatar
redshift83 redshift83 is offline
redshift83 is on a distinguished road
redshift83's Avatar
Sonoran steel's page has a decent write-up which you may have seen, but the images show the factory wiring diagram which shows which wires control the locker motor.
Retrofit Electric Locker
The problem i think is that when the locker motor is in locked or unlocked position it is cut off from functioning until the proper wiring is connected for the direction it expects to go (i.e. locked -> unlocked) This keeps the motor from over-traveling or running while stalled and reduces the chance of things being damaged over time.
There's also another write-up here that describes how to test the locker motor and this may help you get things moving:
https://www.toyota-4runner.org/3rd-g...ay-quoted.html
This got mine moving without any issues. It may also be possible that your motor is seized and thus will not move without some help. I am not sure the best method to get things moving in that case, but it may be removing the gear cover and manually actuating the locker. You could also remove the motor "can" and move it but be aware that you will have to re-seat the motor brushes which wasn't super easy unfortunately.
97 SR5 - 202k: 99 tall /5100's, OME 906/5100s; TBU;
E-Locker swapped; LOTS of Fluid film.
91 Celica All-Trac
15 WRX - DD
99 Miata (under construction)
redshift83 is offline   Reply With QuoteReply With Quote
Old 09-26-2019, 01:32 PM #3
Technoplasm's Avatar
Technoplasm Technoplasm is offline
Real Name: Stephen
Technoplasm is on a distinguished road
Real Name: Stephen
I'm just gonna drop in and say that buying the 12voltguy locker harness was the best decision i ever made.
2002 Toyota 4Runner SR5 4X4
Dorado Gold Pearl
Technoplasm is offline   Reply With QuoteReply With Quote
Old 09-26-2019, 02:04 PM #4
nevada's Avatar
nevada nevada is offline
nevada has a spectacular aura about nevada has a spectacular aura about
nevada's Avatar
im slightly confused. why does it need to be locked to remove the 3rd?
1985 pickup: EFI 331/4r70W-Dana 300-42 TSL SXII's/raceline beadlocks-30spl longs-5.29's-spools-sky Hi steer-OBA/4g tank-10.5k RR winch-dual blue tops-200 amp alt-flatbed.
1985 4runner sr5: 22RE/5spd-6" pro-comp suspension-37 BFG at's-5.29 gears-Badlands Basher bumper-8.5k RR winch.
2006 4runner v8 limited: stock. Build Thread YouTube Channel
nevada is offline   Reply With QuoteReply With Quote
Old 09-26-2019, 02:08 PM #5
nevada's Avatar
nevada's Avatar
but, to answer the question, its the 2 green wires. they maybe be striped, I don't remember. but they are the 2 heavier gauge wires coming from the motor.
run 12v to one and ground the other, the motor will spin one direction. reverse the wire connections, and the motor will go the other way.
Old 09-26-2019, 03:24 PM #6
m0ist m0ist is offline
m0ist is on a distinguished road
I just went through this...I could not figure it out and ended up running a new wire to ecu harness. I left all the wires from the ECU to the dash, and re-pinned the connector back to the diff.
69th Street Garage: Pre-wired Elocker Wiring for 3rd Gen 4Runner - Part 1
I have a diagram towards the bottom on how I wired it.
Check out my website https://69thstreetgarage.com/
m0ist is offline   Reply With QuoteReply With Quote
Old 09-26-2019, 05:53 PM #7
thezentree's Avatar
thezentree thezentree is offline
Real Name: Robert');DROP TABLE Students;
thezentree has a spectacular aura about thezentree has a spectacular aura about
thezentree's Avatar
This. It’ll come out of the housing in either position as long as you pull the axle shafts. It will also go back in in either position, which really sucks if your 12voltguy harness hasn’t showed up yet and you realize it after you’ve buttoned it all back up and put tools away. Not that I would know that from personal experience or anything...
2001 SR5 - Like OEM, only worse (gears, e-locker, armor)
thezentree is offline   Reply With QuoteReply With Quote
Old 09-26-2019, 07:45 PM #8
3bears 3bears is offline
Real Name: Joshua 3 Bears
3bears has a spectacular aura about 3bears has a spectacular aura about
agree....you have to pull the axels regardless if a locker or not rear end
2000 SR-5 V6 Auto . Desert Dune, Spectre intake, Borla muffler, Magnafine tranny filter, B&M cooler, Talls, KYB, Airlift 1000, DRL delete, Big 3 wire, full rack, TBU, Swapped in Elocker, some LEDs, PIAA headlights, , Amsoil
Old 09-26-2019, 09:28 PM #9
Tinigunner11's Avatar
Tinigunner11 Tinigunner11 is offline
Real Name: Austin
Tinigunner11 is on a distinguished road
Real Name: Austin
Factory E-Locker Troubleshooting | BigFishAllDay (quoted) - Toyota 4Runner Forum - Largest 4Runner Forum
1997 4runner, OVER 360K miles, Bilstein 5100 and FJ80 suspension, Polaris light bar, custom full length roof rack, plus some interior mods
I've had more 3rd gens than I can count at this point
Tinigunner11 is offline   Reply With QuoteReply With Quote
3rd , e-locker , lock , member , remove
E Locker wiring help (solved) phqduphead 4th Gen T4Rs 19 10-28-2017 04:23 PM
E=locker wiring? riflecountry 3rd gen T4Rs 23 03-17-2017 04:36 PM
Help with e locker wiring! jman11788 3rd gen T4Rs 1 02-09-2017 08:29 PM
E Locker Wiring Daneums 3rd gen T4Rs 20 09-03-2015 01:02 PM
PICTURES: Need Help Identifying E-locker pre-wiring BrandonF 3rd gen T4Rs 4 08-04-2014 06:27 PM
