Old 09-30-2019, 06:50 PM #16
JohnOfTheJungle JohnOfTheJungle is offline
JohnOfTheJungle will become famous soon enough
Did your OME 891's sag?
Originally Posted by CT135 View Post
Are you running 15ish PSI at all times or just under load? I think I read somewhere that to keep them from breaking or leaking you should always have air in them?
Just put them in a few weeks ago and have kept about 15 psi in them since then, tho when I checked the other day they were at 10.
I just pumped them up to 40 psi yesterday for the hell of it to see if I’d gain height and how it would ride.
Here they are at 40 psi with probably 100 lbs in the back.
Looks like I’ve got a decent rake so I can probably raise my front coilovers a bit.
I’m going to be building a rear bumper soon too, so these airbags will def be necessary. If you’re going to have armor and carry weight then I don’t think the 891 will be good for maintaining 3” without airbags. I don’t think I even got 3 out of the box with hardly any weight in the back.
1997 Limited 4x4 3.4l 199k E-locker Blue Wire Mod | 255/85 r16 Maxxis Bighorn MT - LX450 9 wrap + Tokico black rear | Front: 2.5" King Coilover set @ 2" lift | True North Fab Front Bumper + Warn m8000 + Baja Designs Squadron Sport | Custom Sliders | NguyenWorks Rear Bumper + Tire Swingout
JohnOfTheJungle is offline   Reply With QuoteReply With Quote
Old 01-06-2021, 01:40 PM #17
blairracd's Avatar
blairracd blairracd is offline
blairracd is on a distinguished road
blairracd's Avatar
Originally Posted by MStudt View Post
If you're going to be carrying weight I would suggest running OME 861's*, and never look back.
Mike
What all did you change when adding in the 861s? I was reading another thread and the consensus was you would need extended bump stops, extended brake lines, extended sway bar links, panhard correction kit (which is on my list, but..), and another thing or two.
Living and breathing and bleeding Toyota
https://imgur.com/a/KvwQdyO
RIP my ‘96.
blairracd is offline   Reply With QuoteReply With Quote
Old 01-06-2021, 03:57 PM #18
MStudt's Avatar
MStudt MStudt is offline
official vendor
MStudt is a name known to all MStudt is a name known to all MStudt is a name known to all MStudt is a name known to all MStudt is a name known to all MStudt is a name known to all
official vendor
MStudt's Avatar
Most of the things you list should be done regardless of which coils you install. I did install extended sway bar links, panhard drop bracket, and bump stop blocks. I did not install extended brake lines, but would recommend doing this.
Mike
MStudt is offline   Reply With QuoteReply With Quote
Old 01-07-2021, 07:33 PM #19
CT135 CT135 is offline
CT135 will become famous soon enough
You should also install land cruiser shocks or 4th gen 4runner bilsteins (rated for like 1.5” lift) to get the proper length for such tall coils.
97 Limited, 5100’s, OME 883/891, Built Right UCA, Custom Sliders, coastal off-road front bumper, 4x innovations rear bumper(custom built swing out), 4.88 gears, Circuit Offroad 17x8.5 wheels, Kenda Klever RT 35x10.5r17
CT135 is offline   Reply With QuoteReply With Quote
Old 01-08-2021, 12:42 PM #20
blairracd's Avatar
blairracd's Avatar
I already have the bilsteins that are rated for 1.5-3" lift, but thank you for thinking of that!
RIP my ‘96.
Old 01-08-2021, 01:30 PM #21
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
Those are an inch shorter extended length than the 4th gen shocks if you are trying to use the full droop that the landcruiser 210V's would allow.
13.84"-22.84" vs 14.91"-23.50"
Old 01-08-2021, 03:24 PM #22
aontkos's Avatar
aontkos aontkos is offline
aontkos will become famous soon enough
aontkos's Avatar
Originally Posted by JohnOfTheJungle View Post
I installed firestone airbags and am running them at about 15 PSI in this pic with about 150 lbs of weight in the back
Originally Posted by RotaryDreamz View Post
I did install airbags to help with the sag weight since.
Would you guys mind listing the part numbers for the airbags you ordered? I've seen several threads with folks trying to find airbags with the right dimensions for OME 891s, so having that reference available would be awesome!
aontkos is offline   Reply With QuoteReply With Quote
Old 01-09-2021, 01:25 AM #23
RotaryDreamz's Avatar
RotaryDreamz RotaryDreamz is offline
Real Name: Sean
RotaryDreamz will become famous soon enough
Real Name: Sean
Air Lift 60743
RotaryDreamz is offline   Reply With QuoteReply With Quote
Old 01-09-2021, 01:16 PM #24
When getting the 4th gen shocks the owner does need to make sure bump stops are long enough (the collapsed length being 1” longer than 3rd gen). You wouldn’t want to blow the shock at full compression. That is sometimes overlooked area.
Old 01-10-2021, 06:32 PM #25
blairracd's Avatar
blairracd's Avatar
A shock rated for just 1.5” lift is shorter than a shock rated for 1.5-3” lift? I’m confused.
RIP my ‘96.
Old 01-11-2021, 09:58 AM #26
Real Name: Patrick
Real Name: Patrick
Stock 4th gen shocks are longer than stock 3rd gen shocks.
coils , experience , lift , long , weight
