Old 09-26-2019, 10:01 PM #1
The Cold War Kid's Avatar
The Cold War Kid The Cold War Kid is offline
The Cold War Kid is on a distinguished road
Loud buzzing noise from under the dash?
The noise comes on when I start then runs for 10 seconds or so. Maybe a vacuum pump? I have no idea.
The heater control does not work and the air passages are very slow to change with the control. Maybe this is something to do with the noise?
Anyone have this problem?
The Cold War Kid is offline   Reply With QuoteReply With Quote
Old 09-26-2019, 10:32 PM #2
spartacus's Avatar
spartacus's Avatar
could be the antenna motor.
Old 09-26-2019, 10:43 PM #3
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Might help to include the basic info of the vehicle your working on in your garage or signature that you know which vehicle are asking about. :-)
I am guessing you have a 1999-2002 4 runner that is doing this as the 1996-1998 dash was all non electric.
My 01 controls are functioning properly, so sorry I can't be able to help you on this one.:-(
Maybe look at the Factory service manual for your vehicle year troubleshooting guides will assist you in finding the cause of your noise. :-)
Old 09-26-2019, 11:17 PM #4
snydmax's Avatar
snydmax snydmax is offline
Real Name: Matt
snydmax will become famous soon enough
snydmax's Avatar
Real Name: Matt
Rule this out first
'98 4WD Limited, Warm Grey, 172k, Factory E-Locker, Ride-Rites, 265/75-16 Wildpeak AT3s
snydmax is offline   Reply With QuoteReply With Quote
Old 09-27-2019, 12:04 AM #5
T.Tech T.Tech is offline
T.Tech is on a distinguished road
It could be the abs actuator motor if it’s one of the later ones.
T.Tech is offline   Reply With QuoteReply With Quote
Old 09-27-2019, 06:29 AM #6
Why would the ABS run when I start it up?
Old 09-27-2019, 06:31 AM #7
It wants an antenna, of course. I've heard that run. It's quiet, compared to this. This is a loud buzz - sounding for all the world like an air pump in an aquarium.
Old 09-27-2019, 07:00 AM #8
tgreenwood75 tgreenwood75 is offline
tgreenwood75 is on a distinguished road
My 2001 does the same thing, 5+ second buzzing or sucking noise that ends with a click. Never really thought about what causes it because it's on startup and certainly seems "normal."
tgreenwood75 is offline   Reply With QuoteReply With Quote
Old 09-27-2019, 10:47 AM #9
calimobber's Avatar
calimobber calimobber is offline
calimobber will become famous soon enough
calimobber's Avatar
Yeah it might just be the abs brake booster your hearing. Its a little motor pumping air. Its building pressure to assist with the brakes.
Pop the hood and turn the key, see of its coming from the brake acuator.
My 2002 4runner Build : http://www.toyota-4runner.org/3rd-ge...r-project.html
calimobber is offline   Reply With QuoteReply With Quote
Old 09-27-2019, 10:51 AM #10
Joelzy's Avatar
Joelzy Joelzy is offline
Joelzy is a glorious beacon of light Joelzy is a glorious beacon of light Joelzy is a glorious beacon of light Joelzy is a glorious beacon of light Joelzy is a glorious beacon of light
Joelzy's Avatar
yeah that^
mine does it as well, if you turn the key on but dont start it it will usually still do it. drove me nuts at first but once i figured out thats what it was i got over it.
96 SR5 5SPD Elocker "the Barnacle"
–02 bmw 540i6
–19 Highlander SE
Joelzy is offline   Reply With QuoteReply With Quote
Old 09-27-2019, 01:00 PM #11
Still need to know the year and trim of your 4Runner to answer...
The 01/02 brake system is an electrically power hydraulic boost system that can make noises, especially when it is wearing out.
The earlier ABS system can/does make a quick noise soon after the brakes are released after startup. That's normal.
The Limited auto-AC servos can make noise if there are problems.
The auto-antenna can make noise when the radio is powered up.
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Old 09-27-2019, 01:10 PM #12
nissanh nissanh is offline
Newer 3rd gen 4runners have the expensive brake master pump which is 1/2 price of the 4runner's market price!
If you hear the sound for 30 minutes or less, that is normal as it is filling the booster with nitrogen gas. If it takes longer and/or hear the buzzing sound all times, then something is wring with the system and most likely it is not going to be a cheap repair.
Old 09-27-2019, 10:16 PM #13
I have a 2001 Sr5 2wd.
The master cylinder is massive. Scary!
The noise seems to come from the center of the car behind the dash. A humming... like an air pump.
Old 09-27-2019, 10:43 PM #14
The newer ones have a hydro booster that assists you when braking that abs motor runs to precharge the accumulator with pressurized brake fluid in case it needs to apply the brakes for the vehicles trac control or vsc. You can deplete the pressure by stepping on the brake about 20 times til the pedal feels different and then cycle the key to the on position and you will here it come on.
Old 09-28-2019, 05:15 AM #15
Mackalicious Mackalicious is offline
Mackalicious is on a distinguished road
Listen under the hood and see if its coming from the brake master. Theres an electric pump there.
Mackalicious is offline   Reply With QuoteReply With Quote
change , control , heater , noise , slow
Buzzing behind driver side dash? S1w 4th Gen T4Rs 11 04-30-2020 11:37 AM
Clicking noise around from passenger seat and loud knocking noise when accelerating Kool-Aid Problems & Warranty Issues 3 06-17-2019 09:18 PM
Squealing/Buzzing Behind Dash tommy1117 Problems & Warranty Issues 2 06-01-2012 08:57 AM
Dunlop AT20 loud buzzing? is it the tires? tamiyatim 4th Gen T4Rs 5 10-04-2011 10:48 AM
Buzzing from under dash tylorjefcoat Problems & Warranty Issues 2 05-05-2011 03:19 AM
