Old 10-01-2019, 04:29 AM #1
eurasiaoverland eurasiaoverland is offline
eurasiaoverland is on a distinguished road
Vibration through steering and gas pedal
Hi All
96 3RZ 5 speed
In my endless and so far fruitless quest to track down various road noises, I am trying to trace what might be causing a humming vibration which comes through the steering wheel, gas pedal and maybe shift lever.
Firstly, this hum / vibration is far too high frequency to be wheels or rotors. It is present all the time, and seems to resonate at certain road and / or engine speeds. It seems to have little, if any, relation to turning the steering wheel. It's similar to the noise that a cold / bad steering pump makes.
I've recently switched from winter to new AT tyres, no change in the noise at all.
I'm trying to think what it could be at the front end - it's not typical for CV noise (no clicks or knock at full lock), and this is when driving in 2WD (I don't have a centre diff so don't drive in 4WD on the road, and I am certain that 4WD is not engaged).
Maybe something in the front diff??
Or perhaps a some blockage in the steering rack?
The engine is rebuilt and runs perfectly, but I have a new fan clutch and harmonic balancer ready to go on (in order to try to get rid of another engine vibration most noticeable at 2000 rpm), but I don't see why these things would be felt through the steering...
I would be glad to hear from anyone who has traced a similar noise and eliminated it.
EO
1993 Hilux 2L diesel manual - in storage.
1996 Hilux Surf 3RZ-FE manual - overland vehicle (and rolling restoration).
1989 Landcruiser BJ60 - undergoing full restoration and engine transplant.
Over 250,000 kilometres around Eurasia in Toyota trucks: http://eurasiaoverland.com/
eurasiaoverland is offline   Reply With QuoteReply With Quote
Old 10-01-2019, 05:33 AM #2
BoomerBob's Avatar
BoomerBob BoomerBob is offline
BoomerBob will become famous soon enough BoomerBob will become famous soon enough
BoomerBob's Avatar
Drive shaft bushings or u-joint(s) going bad?
2001 2wd - Daily Driver
BoomerBob is offline   Reply With QuoteReply With Quote
Old 10-01-2019, 06:33 AM #3
STI_MECE's Avatar
STI_MECE STI_MECE is offline
STI_MECE will become famous soon enough
STI_MECE's Avatar
I have wheel bearings going out in the front end on my rig. And it's a gritty feeling which causes a him, groan (whatever you want to call it).
Diagnosing a mechanical issue on a car by describing the noise (especially for its age) is about as hard as threading a camel through an eye of a needle.
Checking wheel bearings is pretty easy.....jack up front end and spin each wheel and see if their is a audible noise if they are good it should be nothing. I doubt you have play but position hands at 9 and 3 and try and see if you can force the wheel to move side to side. You can try 12 and 6 too.
I say you probably don't have play because you don't say you have steering wheel wobble.
Sent from my Pixel 2 XL using Tapatalk
2000 SR5 4x2 Resto/Maintenance
STI_MECE is offline   Reply With QuoteReply With Quote
Old 10-01-2019, 07:08 AM #4
Not sure what you mean by driveshaft bushing, but the UJs seem good. No slop whatsoever. The rear UJ is relatively new, genuine part. Thanks.
Old 10-01-2019, 07:14 AM #5
Definitely agreee with you on noise diagnosis; however the fact that I only feel it through the steering wheel and gas pedal may make it easier to pinpoint. It's not regular driveline noise which appears at a given speed and resonates through the entire vehicle.
Wheel beraings are perfect, checked them at the weekend while the truck was up on the ramps getting a set of BFGs fitted. Absolutely noise-free when turning the wheels, no slop when rocking them. I do have a touch of wheel wobble, however I think this is wear in the rack rather than unbalanced wheels.
Thanks
EO
Old 10-01-2019, 08:09 AM #6
dogtail's Avatar
dogtail dogtail is offline
Real Name: Keith
dogtail has a spectacular aura about dogtail has a spectacular aura about
dogtail's Avatar
Real Name: Keith
So you ruled out tires wheel bearings. Just gotta keep the process of elimination going. Because you say you may be getting transfer of vibration in the shifter, I would check on drivetrain stuff. Lot of vibration can come from the rear driveshaft and transfer the vibration thru the Tcase to up front. Driveshaft can seem fine on the grab, but be sloppy on the spin and out of balance. Easy rule out of this vibration, pull out the rear driveshaft and drive in front wheel drive. I get my shafts rebuilt with new DC joint, universals and balance for $235......but I have a really good drivetrain shop near me and they know what they are doing.
*1999 3.4L, 4wd/5spd, swapped motor and trans, heavy use DD, seasonal rust proofing using WD-40 only
*2000 3.4L, 4wd/5spd, parts rig, picking the carcass
dogtail is offline   Reply With QuoteReply With Quote
Old 10-01-2019, 08:30 AM #7
mtbtim's Avatar
mtbtim mtbtim is offline
Real Name: Tim
mtbtim's Avatar
Real Name: Tim
If your lifted, I'd take a look at your driver side front differential needle bearing.
ECGS found a flaw with how the Toyota carriers are made. The spider gear does not have a machined surface inside the carrier to rest against and that causes excessive movement of the spider gear. When you lift your truck or SUV and put the CV axle at a more extreme angle, the play within the carrier allows excessive pressure to be put on the needle bearing the CV shaft rides on and that needle bearing was not made to handle that type of load. The result is people can experience a bad vibration and a roaring sound.
ECGS got an idea from ARB that uses a bushing instead of a needle bearing inside the lockers they sell. They decided a fix for the Toyota carriers would be to replace the needle bearing with an oil impregnated bronze bushing to greatly reduce the play the CV shaft has within the carrier. Their idea worked and this is a great fix.
Old 10-04-2019, 12:29 AM #8
PowrPly's Avatar
PowrPly PowrPly is offline
PowrPly is on a distinguished road
PowrPly's Avatar
I agree with MTBTIM. I just diagnosed this issue in my 4Runner and will be installing it in a few days. Simply get under the front end and grab the CV where it meets the diff on the driver’s side and check the amount of play.
I love Timmy, but you need to know something about this video. ECGS had an issue with the size of the tool they created to remove the needle bearing and you’ll see Tim have a hell of a time with it in this video. However, ECGS has addressed that by resizing the tool.
If you search Tacoma clamshell bushing on YouTube you’ll find another very helpful video. There’s an orange Tacoma in the picture frame, that’ll be the one.
Good luck!
PowrPly is offline   Reply With QuoteReply With Quote
Old 10-05-2019, 01:00 PM #9
Good luck!
Awesome, thanks guys. I do have a mild lift (OME 880s with Bilstein 4600s on the front). I just got under my truck and felt the inner CVs. On both sides there is noticeable vertical play where they go into the diff, more so on the left-hand (driver's side on your trucks, passenger side on my JDM) side.
I will take a look at the video later, but I am not familiar with who / what ECGS is... can someone link me to the correct part with the new, improved removal tool please?
Is there a similar bush for the right-hand (your passenger) side?
Is there a chance my driveshaft is now worn below spec?
Would a diff-drop eliminate the problem?
Thanks again
EO
Old 10-05-2019, 02:58 PM #10
OK, skip the above post... I've already ordered a bush and bearing removal tool. Luckily a friend is flying from the US next week (with a bunch of bits) over here to the Netherlands.
Will keep you up to date on progress.
EO
Old 10-07-2019, 12:02 AM #11
PowrPly's Avatar
PowrPly's Avatar
EO -
The passenger side (your driver side) uses a ball bearing support for the axle shaft which provides more support and doesn’t wear as easily. Hence the bushing is only available for the needle bearing side.
A diff drop may eliminate the vibration, but it doesn’t address the real issue, the needle bearing is an insufficient support. Installing a diff drop would be like turning up the stereo so you don’t hear a problem anymore. 😊
Old 10-14-2019, 10:40 PM #12
XtremeAdventurer XtremeAdventurer is offline
XtremeAdventurer is on a distinguished road
ECGS found a flaw with how the Toyota carriers are made. ... The result is people can experience a bad vibration and a roaring sound.
Just finished this today and really glad you posted. Vibration is gone! It's been a few months trying to track this one down.
XtremeAdventurer is offline   Reply With QuoteReply With Quote
Old 10-16-2019, 03:16 AM #13
bodean123 bodean123 is offline
bodean123 is on a distinguished road
An easy way to check if it’s the needle bearing causing the vibes is to put it in 4hi and see if the vibes go away.
bodean123 is offline   Reply With QuoteReply With Quote
Old 10-16-2019, 09:29 AM #14
Great to hear that! Could you describe in detail the symptoms you had, please?
Thanks
EO
Old 10-16-2019, 10:00 AM #15
mtbtim's Avatar
Real Name: Tim
mtbtim's Avatar
Real Name: Tim
Good luck!
This will continue to be a problem and I don’t know how to fix it other than making entirely new videos when there’s an update and we’re not going to do that. I did however mention in the video that I was going to contact ECGS about the issue with the tool and I would provide an update to what they told me. In all our videos, we offer helpful and quite often VERY IMPORTANT information in our videos descriptions and in a pinned comment. For this particular video, I made a pinned comment that covers the fact that ECGS did re-engineer the tool. ECGS actually sent me the updated tool for free because they appreciated the video we made. For anyone reading this post, please, please, please always read the video description and read any comment pinned by us. You will find the information shared very helpful.
engine , noise , road , steering , vibration
vibration on the gas pedal pokeyman 3rd gen T4Rs 6 05-31-2019 12:03 PM
Gas Pedal Vibration 4Runner4TW 3rd gen T4Rs 7 02-01-2019 09:54 PM
Vibration in gas pedal philo 5th gen T4Rs 4 07-23-2018 12:10 PM
Brake pedal vibration?! Forza 4th Gen T4Rs 22 01-16-2013 12:47 AM
Gas Pedal Vibration Martin8 4th Gen T4Rs 0 05-02-2006 12:45 AM
