Old 10-16-2019, 12:05 PM #16
XtremeAdventurer XtremeAdventurer is offline
XtremeAdventurer is on a distinguished road
Originally Posted by eurasiaoverland View Post
Great to hear that! Could you describe in detail the symptoms you had, please?
Thanks
EO
Bought the ‘99 4Runner with 320k miles, so I knew it was going to need some work. After a ToyTec/SuperFlex lift w/ 5100’s, I started to get a lot of stability issues. New SPC UCA, new poly bushings (upper & lower on front, rear, & panhard bar), new steering gear bushings, used 2002 Tacoma steering gear, new CV’s, you name it and I replaced it.
I was also getting a vibration almost like a wheel out of balance and was starting to get a bearing noise. Suspected the front wheel bearing, so I replaced them. The stability problems were gone, but still had the vibration and noise.
Noise started around 25-30mph, vibration started to be noticeable around 60mph and was pronounced at 80. Heaving braking caused a vibration like a warped rotor, but since I had new pad & rotors (Tundra 199 upgrade) I figured it wasn’t that.
I read this thread, checked the Driver CV, and sure enough had a lot of play at the diff.
The video made sense with what I was experiencing, so I ordered the parts & puller and replaced the bearing with the bushing.
I’d say easy as that, but it was a bit of work!
XtremeAdventurer is offline   Reply With QuoteReply With Quote
Old 10-19-2019, 06:31 AM #17
eurasiaoverland eurasiaoverland is offline
eurasiaoverland is on a distinguished road
Thanks! Your description of the noises sound a lot like what I have (though I can't remember the last time I had her up to 80 ) - will check the noise in 4WD. I don't have any stability issues as far as I know.
I'm running 4600s with OME 880s. As part of a major overhaul when I bought the car, the front bearings, ball joints, inner and outer tie rod ends, rack bushes, anti-roll bar bushes, discs and pads have all been replaced. I'm running newly bought and balanced BFG KO2s.
A friend is coming over here from the US next weekend with my new bush and tool
EO
1993 Hilux 2L diesel manual - in storage.
1996 Hilux Surf 3RZ-FE manual - overland vehicle (and rolling restoration).
1989 Landcruiser BJ60 - undergoing full restoration and engine transplant.
Over 250,000 kilometres around Eurasia in Toyota trucks: http://eurasiaoverland.com/
eurasiaoverland is offline   Reply With QuoteReply With Quote
engine , noise , road , steering , vibration
vibration on the gas pedal pokeyman 3rd gen T4Rs 6 05-31-2019 12:03 PM
Gas Pedal Vibration 4Runner4TW 3rd gen T4Rs 7 02-01-2019 09:54 PM
Vibration in gas pedal philo 5th gen T4Rs 4 07-23-2018 12:10 PM
Brake pedal vibration?! Forza 4th Gen T4Rs 22 01-16-2013 12:47 AM
Gas Pedal Vibration Martin8 4th Gen T4Rs 0 05-02-2006 12:45 AM
