Old 10-20-2019, 07:29 PM #16
lockedlex's Avatar
lockedlex lockedlex is offline
lockedlex will become famous soon enough
lockedlex's Avatar
Any chance the replacement was faulty too? (I've had used parts DOA on me).
Also, where are you located? If you're local, I'd be happy to try to diagnose it with you.
2000 Limited V6 4WD | Factory Locker | 2nd Gen SC | NGK Spark Plug Wires | AEM Boost/AFM Gauges | Scangauge II | Sonoran Steel 1.2 Lift/Washer Reservoir | AirLift Rear Airbags/Wireless Compressor | 4XInnovations Front/Rear Bumpers | Schrockworks Skid Plates/Sliders | Warn 12k LBS Winch-Synline | LED Halo Driving Lights | LED "Satoshi Cover" Lightbar | Thermal IR Cam | BFG All-Terrain KO2 | Kenwood with Sirius/Garmin Nav and Surround-View Cam | Heated Seats | Lumbar Support | Blacked out Emblems TRD Badge | Rear Diff Breather Extension | LED Taillights | LED 6k Headlights | 120V Power Socket | Flipped Hood and Fuel Release | Rear Window Switch in Cargo Area | Custom FlipBlade Key | Warm White LEDs
lockedlex is offline   Reply With QuoteReply With Quote
Old 10-20-2019, 08:29 PM #17
The Cold War Kid's Avatar
The Cold War Kid The Cold War Kid is offline
The Cold War Kid is on a distinguished road
Originally Posted by duke808 View Post
It is with great sadness I must report that the new (used) throttle body did NOT fix the problem. It has been cooler here the past week or so (since I have had the fix) and I haven't been using the ac. Well the heat is back and with the AC on and it being 80+ out, the loss of power is back. FML.
ANY IDEAS??? At this point the car is now undriveable again and I may just end up dumping the car. Lol
Check your plug that connects the TPS. Heat under the hood might be warping it... causing a loss of connection? I've seen that before.
Bend the contacts until they are sung...
The Cold War Kid is offline   Reply With QuoteReply With Quote
Old 10-20-2019, 08:51 PM #18
duke808 duke808 is offline
duke808 is on a distinguished road
I'm in San Diego. Yeah I thought of that too but this guy has a 5 star rating on eBay so I doubt it... Never know though
2001 4Runner 4WD -- 235k mi and counting!
duke808 is offline   Reply With QuoteReply With Quote
Old 10-20-2019, 08:52 PM #19
Good idea there too...
Old 10-21-2019, 12:03 AM #20
HiLife HiLife is offline
Hey duke808 sorry this one is really getting to you. I, also would offer help troubleshooting your components if I was nearer to you.
Is it possible to check for fuel pressure? Go over your ground connections making sure they are clean and tight?
Hate for you to dump a 4runner because of what's happening.
Old 10-21-2019, 01:13 AM #21
APhelps APhelps is offline
APhelps has a spectacular aura about APhelps has a spectacular aura about
Have you disconnected the battery to reset any tuning issues? (I doubt this is the issue). You might want to give it a tune up as well.
APhelps is offline   Reply With QuoteReply With Quote
Old 10-24-2019, 02:59 PM #22
hey guys yeah, I have been having my mechanic who predominately works on european cars do all the work on this thing since he's my main mechanic and does everything cheap. when I bought this he said he works on them too, and he's at a loss at this point. I'm thinking i'll take it to a japanese shop. I am not a DIY'er other than brakes and oil changes. I have had a lot of work done to this thing.
The unfortunate thing is it only happens in 85+ degree weather with AC on.... "winter" in CA is nearing and will no longer be those temps, so there really is no replicating this issue until next summer. It sucks. I guess I will drive my other car until next summer and let this damn thing sit until I can have a mechanic replicate. this issue aside, i've put a lot of $ into it and it runs perfect, also a socal car its whole life so zero rust. would be a shame to dump, I agree.
Old 10-24-2019, 03:16 PM #23
Have you tried testing the MAF against the OEM specs? You could also try swapping one. I wonder if yours is so out of whack that it has an abnormal air reading and wanting to go into a limp mode.
There's not that many components that'll cause an issue like this and worse case you could hand grenade the problem to solve it with a few parts from a junkyard.\
Likewise I'm in San Diego so if you want PM me and I'll see if I can give you a hand.
Old 10-25-2019, 12:24 AM #24
The throttle body is only the 1 part of the system. The other part is the accelerator peddle assembly itself. It has a sensor (rheostat) on it too. Im only locating a peddle assembly (78120-35401).
Could it be the cold air from the ac is somehow making that part malfunction?
Old 10-25-2019, 02:15 AM #25
I’m not necessarily sure that the ac really has anything to do with the problem besides the fact it’s placing an additional load on the engine.
body , car , finally , power , throttle
throttle body problems ..NO POWER andy3882 5th gen T4Rs 38 07-09-2020 08:54 AM
High Idle After Cleaning Throttle Body 2001-2002 D Farms 3rd gen T4Rs 10 03-09-2020 02:14 PM
2002 6cyl. 175k Vacuum leak, Throttle Body throttle lever? Hollywood1 3rd gen T4Rs 3 12-29-2018 06:25 PM
Throttle Body Cleaning - 2001 4runner - **PICTURES** ramonortiz55 3rd gen T4Rs 3 04-05-2017 01:31 PM
Electric throttle body to cable throttle body conversion Dirtyfingers 3rd gen T4Rs 8 12-29-2014 10:05 AM
