Old 10-24-2019, 06:53 PM #1
Vooryjoni's Avatar
Vooryjoni Vooryjoni is offline
Vooryjoni is on a distinguished road
Vooryjoni's Avatar
Exclamation Stuttering and stalling
Hello, for some reason, when my ac is on and I am in drive (idling), sometimes the rpm gauge starts to bounce from 400-700 rpm. It sounds like it is stuttering. Once it even stalled as I was reversing without even pressing the gas pedal. When I put it into neutral at a stop light, the issue seemed to go away. I am sure that hitting the 400rpm mark signifies some issues. Also the ac compressor kept turning on and off when this happened. Any advice and suggestions would be greatly appreciated. Thank you.
1998 White Toyota 4Runner Limited V6 4WD - 255k miles
Vooryjoni is offline   Reply With QuoteReply With Quote
Old 10-24-2019, 07:03 PM #2
APhelps APhelps is offline
APhelps has a spectacular aura about APhelps has a spectacular aura about
sounds like you have a vacuum leak.
APhelps is offline   Reply With QuoteReply With Quote
Old 10-24-2019, 07:12 PM #3
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Agree with the other user
Possibilities
1) Vaccum leak
2) the compressor bad and or low amount of refrigerant in the AC system
The idle fluctuate slighty when the AC compressor clutch engages and disengages.
So if no vacuum leak. I would have the ac compressor checked to make sure its functioning properly..
Make sure the ac belt is good and not slipping as that can cause issues too.
Old 10-24-2019, 10:14 PM #4
Vooryjoni's Avatar
Vooryjoni's Avatar
My former service advisor at the dealership suggested that it could be the compressor. I did put R134a refrigerant in the system during early summer so I think it’s filled up. Also serpentine drive belts were changed around 3 or 4 years ago. I will look into the vacuum suggestion. Thanks guys
Old 10-25-2019, 12:56 AM #5
HiLife HiLife is offline
Hows your IAC valve? Make sure the motor in it is clean and able to turn freely.
Old 10-25-2019, 07:48 AM #6
I’d clean your IAC the AC cycling on and off is normal unless your Fan was at max speed with outside air selected instead of recirc and it’s above 85.
You can clean it without removing the throttle body by removing the vacuum line that goes to the intake and spraying throttle body cleaner in the port and watch for black stuff coming out the air inlet hole in the throat of your throttle body.
400rpm , hitting , mark , rpm , stuttering
Sluggish/ Stuttering during initial acceleration nalbertasr5 3rd gen T4Rs 2 03-20-2016 05:45 PM
Stuttering upon acceleration Jhacker1 Classic T4Rs 4 08-03-2012 03:08 PM
New 2011 T4R Engine Stuttering TroutBoy 5th gen T4Rs 4 11-17-2010 12:19 AM
Slight stuttering problem... crazeazn Problems & Warranty Issues 2 04-20-2006 08:35 AM
