Old 10-09-2019, 06:11 PM #16
thezentree's Avatar
thezentree thezentree is offline
Real Name: Robert');DROP TABLE Students;
thezentree is a jewel in the rough thezentree is a jewel in the rough thezentree is a jewel in the rough thezentree is a jewel in the rough
thezentree's Avatar
Originally Posted by Inv4drZm View Post
If you're not cutting weight on every single aspect of your vehicle, the 50-65lbs you save between aluminum and steel won't make a lick of difference in mpg. Not enough to make up the extra $500 you've spent.
If you can cut weight a little everywhere, lighter brakes, removed roof rack, exhaust, etc, then yeah it could actually add up, get the aluminum skids.
Somebody needs to make a set of 1/8" AR400 skids. Slides over rock easily, probably still cheaper than aluminum.
I am trying to cut weight where I can, not for mpgs (lol lost cause) but for overall performance. I can tell a difference in the way it drives with a loaded cooler, camping gear, hi-lift, extra tools/spares, etc. It’s slower, the trans is hotter, and it takes longer to stop. 20lbs here, 40lbs there will go a good ways to help offset that.
FWIW, I contacted budbuilt about their skid weights. He said for full sets, the 3/16” steel is 111lbs, 1/8” is 78lbs, and 1/4” aluminum is 58lbs.
But yeah, stamped 1/8” AR400 skids would be tits.
2001 SR5 - Like OEM, only worse (gears, e-locker, armor)
thezentree is offline   Reply With QuoteReply With Quote
Old 10-09-2019, 10:54 PM #17
Aldo947 Aldo947 is offline
Aldo947 is on a distinguished road
Thanks.
Thanks for the links.
Aldo947 is offline   Reply With QuoteReply With Quote
Old 10-10-2019, 03:26 PM #18
kolelt kolelt is offline
kolelt will become famous soon enough kolelt will become famous soon enough
Originally Posted by bruised View Post
RCI in colorado makes aluminum skids as well. It doesn't look like they list them on their site any more for 3rd gens but you might try calling and asking. Their prices are reasonable compared to bud-built.
Last time I went on RCI went they offered full set of skids in aluminum. But much more expensive then metal. It all depends what kind of odd tossing you do. If you are just a overlander who drives a lot on road, fire roads and not so much through rocks and other hard obstacles. Then aluminum would be a good choice considering it’s lighter and better for overlanding. But if you off road a lot and wheel the piss out of it. The. Go with steel.
97 3.4 JDM/5 Speed swap/eLocker Swap/ICON CDC all around/+more.....
kolelt is offline   Reply With QuoteReply With Quote
Old 10-10-2019, 07:35 PM #19
tx_shooter's Avatar
tx_shooter tx_shooter is offline
tx_shooter will become famous soon enough
tx_shooter's Avatar
Originally Posted by thezentree View Post
Seems like I've only been able to get out in the woods a few times a year. Mine spends WAY more time commuting to work. I want big ass 1/4" steel skids but can't justify it for the same reasons I can't justify tons and 40s.
Maybe the answer is a set of steel skids that spend 95% of the time leaned up against the wall in the basement
I run an aluminum skid on my DD and only get a few chances to really danger them each year.
Aluminum or steel? The best way the question was proposed to me was this - when you come to a line where you may hit the skids do you pick a different line/ drive careful or give it some gas to scrape over it? If you picked a different line you are okay with aluminum. If you scraped over it you need to stick to steel.
My daily driver will stick to aluminum for the weight savings. My rock rig will stick to steel for the strength. Different scenarios require different specs.
tx_shooter is offline   Reply With QuoteReply With Quote
adding , aluminum , bunch , plates , skid
RCI Aluminum and Steel Skid Plates for KDSS-equipped On the Way 2013Trail 5th gen T4Rs 24 01-09-2018 12:05 AM
SOLD - 4th Gen RCI Aluminum Skid Plates $250 San Diego, CA. grantprior13 For Sale: T4R Items 0 01-08-2018 06:44 PM
Aluminum Skid Plates? TrailHunter 5th gen T4Rs 26 05-17-2017 03:26 PM
Light duty skid plates. Aluminum or 1/8 steel? razzman1 4th Gen T4Rs 1 07-09-2015 06:24 PM
