Originally Posted by DreadPirateJon
I am wondering if it is keeping some other CPUs awake on the CAN bus. Once I have the time after I fix my mistakes in the engine, Ill plug into the bus and try to figure out whats going on.
Being such an old OBDII vehicle with some older OBD parts still on it, im not exactly sure how much info ill be able to get out of the bus.
According to the
Ultragauge website you can get these readings.
Manufacture Date: 12/1996
Transmission: Automatic
Protocol: J1850 VPM
Open/Closed Loop Emissions Status
Percent Engine Load
Engine coolant temperature (°F)
Engine coolant temperature (°C)
Short Term Fuel Trim Bank 1
Long Term Fuel Trim Bank 1
RPM
MPH
KPH
Ignition Timing Advance
Intake Air Temperature (°F)
Intake Air Temperature (°C)
Mass Air Flow Sensor output in grams/sec
Absolute Throttle Position Percentage
Bank 1 Oxygen Sensor 1 Voltage
Bank 1 Oxygen Sensor 2 Voltage
Brake Horsepower 1
Brake Kilowatts 1
Torque 1 (ft lbs)
Torque 1 (N.m)
Brake Horsepower 2
Brake Kilowatts 2
Torque 2 (ft lbs)
Torque 2 (N.m)
UG Battery voltage
Mass Air Flow 2, Calibrated/Calculated
Instantaneous MPG
Intantaneous Gallons/Hour (GPH)
Instantaneous KPL
Intantaneous Liters/Hour
Instantaneous L/100km
Distance to Empty(DTE)(miles)
Distance to Empty(DTE)(km)
Time to Empty (TTE)
Fuel Level (gallons)
Fuel Level (liters)
Oil Distance(miles)
Oil Distance(km)
Service Distance(miles)
Service Distance(km)
General Purpose
Average MPH
Average MPG
Average Gallon/Hour (GPH)
Fuel Used (gallons)
Run Time
Distance (miles)
Average KPL
Average L/100km
Average KPH
Average Liters/Hour
Fuel Used (liters)
Distance (km)
TRIP GAUGES
Run Time
Average MPH
Average MPG
Fuel Used Gallons
Average Gallon Per Hour (GPH)
UltraGauge Internal Temperature (°F)
Average KPH
Avergage KPL
Avergage L/100km
Liters Used
Average Liters/Hour
Distance (km)
UltraGauge Internal Temperature (°C)
SHORT TRIP GAUGES
Run Time
Avergage MPG
Fuel Used (gallons)
Average gallons/hour
Average MPH
Distance (miles)
Average KPH
Avergage KPL
Avergage L/100km
Liters Used
Average Liters/Hour
Distance (km)
