Old 10-09-2019, 02:09 PM #16
4Runner4Leon's Avatar
4Runner4Leon 4Runner4Leon is offline
Real Name: Leon
4Runner4Leon is a name known to all 4Runner4Leon is a name known to all 4Runner4Leon is a name known to all 4Runner4Leon is a name known to all 4Runner4Leon is a name known to all 4Runner4Leon is a name known to all
Real Name: Leon
That's what the second link I posted above addresses, although they claim it should not be an issue with EM 1.2
1997 4Runner Limited 4WD E-Locker ~200k | Falken Wildpeak A/T3W 265/75/16 | Pro Comp 69 16x8 | OME 2906 | B&M 70264
Addicted Offroad Front Bumper | Spiker Engineering High-Lift Hood Struts and Ultragauge Mount
4Runner4Leon is offline   Reply With QuoteReply With Quote
Old 10-09-2019, 02:41 PM #17
Originally Posted by DreadPirateJon View Post
I am wondering if it is keeping some other CPUs awake on the CAN bus. Once I have the time after I fix my mistakes in the engine, Ill plug into the bus and try to figure out whats going on.
Being such an old OBDII vehicle with some older OBD parts still on it, im not exactly sure how much info ill be able to get out of the bus.
There is no CAN bus on the gen3 4Runner. The OBD port is directly connected to the ECU and that's it (well, and a power and ground connection). The 7.5A OBD fuse is hot all the time though...
Oh, edit before finishing: There is also a connection to the SRS (airbag) computer on the same SIL line that is used for OBD communication.
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Old 10-09-2019, 07:17 PM #18
BoomerBob's Avatar
BoomerBob BoomerBob is offline
BoomerBob will become famous soon enough BoomerBob will become famous soon enough
BoomerBob's Avatar
According to the Ultragauge website you can get these readings.
Manufacture Date: 12/1996
Transmission: Automatic
Protocol: J1850 VPM
Open/Closed Loop Emissions Status
Percent Engine Load
Engine coolant temperature (°F)
Engine coolant temperature (°C)
Short Term Fuel Trim Bank 1
Long Term Fuel Trim Bank 1
RPM
MPH
KPH
Ignition Timing Advance
Intake Air Temperature (°F)
Intake Air Temperature (°C)
Mass Air Flow Sensor output in grams/sec
Absolute Throttle Position Percentage
Bank 1 Oxygen Sensor 1 Voltage
Bank 1 Oxygen Sensor 2 Voltage
Brake Horsepower 1
Brake Kilowatts 1
Torque 1 (ft lbs)
Torque 1 (N.m)
Brake Horsepower 2
Brake Kilowatts 2
Torque 2 (ft lbs)
Torque 2 (N.m)
UG Battery voltage
Mass Air Flow 2, Calibrated/Calculated
Instantaneous MPG
Intantaneous Gallons/Hour (GPH)
Instantaneous KPL
Intantaneous Liters/Hour
Instantaneous L/100km
Distance to Empty(DTE)(miles)
Distance to Empty(DTE)(km)
Time to Empty (TTE)
Fuel Level (gallons)
Fuel Level (liters)
Oil Distance(miles)
Oil Distance(km)
Service Distance(miles)
Service Distance(km)
General Purpose
Average MPH
Average MPG
Average Gallon/Hour (GPH)
Fuel Used (gallons)
Run Time
Distance (miles)
Average KPL
Average L/100km
Average KPH
Average Liters/Hour
Fuel Used (liters)
Distance (km)
TRIP GAUGES
Run Time
Average MPH
Average MPG
Fuel Used Gallons
Average Gallon Per Hour (GPH)
UltraGauge Internal Temperature (°F)
Average KPH
Avergage KPL
Avergage L/100km
Liters Used
Average Liters/Hour
Distance (km)
UltraGauge Internal Temperature (°C)
SHORT TRIP GAUGES
Run Time
Avergage MPG
Fuel Used (gallons)
Average gallons/hour
Average MPH
Distance (miles)
Average KPH
Avergage KPL
Avergage L/100km
Liters Used
Average Liters/Hour
Distance (km)
2001 2wd - Daily Driver
BoomerBob is offline   Reply With QuoteReply With Quote
battery , checked , plugged , pretty , ultragauge
What the heck is killing my battery? Jon 3rd gen T4Rs 29 11-26-2014 12:59 PM
This is killing me! dhhr 5th gen T4Rs 8 01-20-2011 12:34 AM
Alarm light killing battery? 88.22re.t4r Classic T4Rs 4 11-06-2010 11:23 AM
2000 Headlights killing battery? BoulderZJ 3rd gen T4Rs 3 08-25-2004 10:28 AM
