Old 10-09-2019, 12:45 PM #1
Haybale Haybale is offline
Haybale is on a distinguished road
Big Sert
Hello, this is the first post I have made so lemme introduce myself a little bit. Iím from north Alabama and bought a 96 limited with 184k on the clock a while back. When buying it I was just gonna drive it hunting to keep my truck outta the woods. Well after driving it back and forth to work a few times i fell in love with it and now would rather drive it than my truck. Iíve not had a minutes trouble out of it until A couple weeks ago, I had got some stuff to do a tune up on it. Get all the fluids changed and start doing spark plugs. Get to the last one #6 cylinder, itís tough coming out. When I finally get it out I see itís been repaired by the PO with some type of cheap insert. I was at work so I had to do something to get home. I run to the local parts place and they had a insert that matched up to the one that come out. I put it in and all was good. It held for ~200 miles and on the way to work Monday morning it blew out, destroying the coil pack. So now I have a question. Iíve got 98 wrecked runner with 230k thatís supposed to run good but has been sitting for 3 years prior to me getting it. Do I try to get that one going and swap motors or do I order the big Sert repair kit and try that? Iím just a broke plumber thatís trying to get my T4r back breathing. Also would anyone happen to have a big Sert kit that I could buy or rent from? Thanks in advance.
Jeremy
Haybale is offline   Reply With QuoteReply With Quote
Old 10-09-2019, 11:41 PM #2
plcfcng's Avatar
plcfcng plcfcng is offline
Location: Southern California (please don't hold it against me)
Real Name: michael
plcfcng is on a distinguished road
plcfcng's Avatar
Real Name: michael
This is a job you may want to pay to have done at a place that has done this before. I would see if there is a machine shop that would do it in the the 4runner. I you do it and make it so it can not be repaired by making the whole to large then the head has to come off or maybe even replaced so at that point might as well pull the other head and take care of it too.
plcfcng is offline   Reply With QuoteReply With Quote
Old 10-10-2019, 06:33 AM #3
STI_MECE's Avatar
STI_MECE STI_MECE is offline
STI_MECE will become famous soon enough
STI_MECE's Avatar
In my opinion, I'd do it right. Ie. Pull the head off and swap it with another. I guess ideal gas is a head that is coming off a running engine.
My 5VZ had the same problem as you. It's on cylinder 1 though. Way easier to fix if I wanna go the time sert way. But luckily for me it's been 2k miles and hasn't blown out. And I reused the insert in there too.
I'm keeping an eye out though for a good donor head. Might be worth looking around at junkyards for fresh runners showing up.
But maybe has someone here has experience with doing time serts that can speak to their longevity. To me it's a band aid solution. Swapping it cures it but leaves you open to other problems so you gotta know what your doing
Sent from my Pixel 2 XL using Tapatalk
2000 SR5 4x2 Resto/Maintenance
STI_MECE is offline   Reply With QuoteReply With Quote
Old 10-10-2019, 06:56 AM #4
thennen's Avatar
thennen thennen is offline
thennen has a spectacular aura about thennen has a spectacular aura about thennen has a spectacular aura about
thennen's Avatar
Do you know if the head from his wrecked '98 that he mentioned will fit on his '96? I would imagine that it does.
thennen is offline   Reply With QuoteReply With Quote
Old 10-10-2019, 08:41 AM #5
Thanks for the replies. Iím going to try to get the 98 running and check it over and if all goes good pull it and swap it into my 96. Iím pretty handy with a wrench and my boss has worked on trucks his whole life just not yotaís. Ideally the 98 motor will be good and I swap em, then I could take my time and find a good head or get mine repaired right.
Old 10-10-2019, 09:01 AM #6
jgue467's Avatar
jgue467 jgue467 is offline
jgue467 will become famous soon enough
jgue467's Avatar
If the current motor Ran fine otherwise don't goof around swapping motors!
Just as others said get it done Professionally. Mine blew out a plug and destroyed the coil too. That was 175,000 miles ago, still running fine with a low cost solution. That was a no brainer to me, don't need a new head or all that labor of a swap out. Geesh.
2001 Limited 4WD - 319K - SunfireRed\Thunder Cloud; - 265/75/16 Michelin A/T2s - Fat Pat's 1.5" BL
StopTech slotted rotors - Magnefine trans filter - In series trans cooler, Original: paint, engine, 4wd, trans, mstr cyl & brake system, rear axle seals, A/C, steering pump, steering rack, front/center/rear diffs, all electric motors, seat heaters and on and on. WooHoo!!
Old 10-10-2019, 01:06 PM #7
STI_MECE's Avatar
STI_MECE's Avatar
how much did it run you to get that done? was it done by dealership? id bee interested if they warrantied the work lol
Old 10-10-2019, 03:48 PM #8
I donít know of anyone around north Alabama that would do that with the head on. Anybody got any ideas. Iím fairly confident I could do the big Sert repair if it would fix the problem. Just didnít wanna spend the $350 plus for the tool if yíall didnít think it would hold. Iíve asked around here and nobody has one that Iíve found yet.
Old 10-10-2019, 03:59 PM #9
Bad Luck Bad Luck is offline
Real Name: Patrick
Bad Luck has a spectacular aura about Bad Luck has a spectacular aura about
Real Name: Patrick
If you have to take the head off to repair it then I would just replace the head. Left and right heads are interchangeable for what it's worth.
Old 10-11-2019, 11:06 AM #10
Riceye Riceye is offline
Riceye is on a distinguished road
If you have good access to that cylinder's plug, you can do this yourself. There is a rental kit available, and installation is pretty straightforward.
aircooled.net tool rental
The insert itself is sold separately from the rental. Much cheaper than buying a one-use tool for hundreds. And, the Aircooled folks are very friendly.
_________
2000 SR5 five speed. Everything works, even the antenna. No special mods; It's my canoe, kayak and dog hauler/winter beater.
I find that things usually go well right up until the moment they don't.
Riceye is offline   Reply With QuoteReply With Quote
Old 10-11-2019, 11:39 PM #11
plcfcng's Avatar
Real Name: michael
plcfcng's Avatar
Real Name: michael
If you take oneside off the other off too. The valves are most likely out of spec. If you go for another engine before u put it in check the valve lash.
Old 10-12-2019, 10:54 AM #12
Iíve seen that but also seen where they only have the regular version and it says we need the extended version. I think I could make it work with some sockets and extensions. Has anybody ever messed with the time Serts and can confirm it can be done with the regular version? Thanks
Old 10-14-2019, 11:59 AM #13
Anybody? Before i just rent it and try
Old 10-14-2019, 12:04 PM #14
STI_MECE's Avatar
STI_MECE's Avatar
I would get the right set of tools for the job...you dont wanna wanna mess that up.
what also sucks is that your working on the worst cylinder to a job like this. Get the right stuff, and make room for the repair.
Let me know how it goes for ya. It may inspire me to do mine lol but mine aint blown out yet
back , big , iíve , sert , work
Time sert insert size confirmation 5VZ-FE NuMex00 3rd gen T4Rs 0 08-28-2013 08:35 AM
Copyright ©2000 - 2019, vBulletin Solutions Inc.
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
Feedback Buttons provided by Advanced Post Thanks / Like (Lite) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Lite) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
Copyright © 2019
