Old 10-09-2019, 11:13 PM #1
Aldo947 Aldo947 is offline
Aldo947 is on a distinguished road
1997 SR5 4X4 engine replacement 99 Taco - transfer case harness different?
Hello Everyone,
I am a new "project" 4Runner owner. Currently doing an engine swap on my 1997 SR5 4x4. I bought a used engine from B&R out of a 99 Tacoma AT 4x2.
My only concern with the engine they sold me was it was not from a 4X4 tacoma, but they said it would not be an issue..
I am finally about to drop the new engine in after hours of rehabbing it and it seems the transfer case harness connections are different. The 99 tacoma is missing the diff lock sensor and both 4wd position sensor connectors?
99 Tacoma Harness - 82121-3G 111C98
97 4Runner harness - 82121 3D390
Can you review my below assessment and confirm im correct in what im seeing? If so i assume my only option is a new harness out of a 4x4? I would re-use my old one but its been cut..
I appreciate any info to help me out here. Thanks.
1997 SR5 4X4 engine replacement 99 Taco - transfer case harness different?-transfer-case-harness-plugs-jpg  1997 SR5 4X4 engine replacement 99 Taco - transfer case harness different?-inkedharness-comparison_li-pdf-jpg
Aldo947 is offline   Reply With QuoteReply With Quote
Old 10-09-2019, 11:46 PM #2
Harness Info
1997 SR5 4X4 engine replacement 99 Taco - transfer case harness different?-1999-tacoma-jpg  1997 SR5 4X4 engine replacement 99 Taco - transfer case harness different?-1997-4runner-jpg
Old 10-10-2019, 02:43 AM #3
redhot redhot is offline
redhot is on a distinguished road
I'd be surprised if that wiring harness even plugged into your ECU let alone all the missing 4X4 stuff.
redhot is offline   Reply With QuoteReply With Quote
Old 10-10-2019, 08:37 AM #4
thegipper's Avatar
thegipper thegipper is offline
thegipper is a jewel in the rough thegipper is a jewel in the rough thegipper is a jewel in the rough
thegipper's Avatar
You'll need to swap out the engine wiring harness from your old bad motor to the donor motor. Everything on the engine side will plug in without any modifications. I was a similar situation, I had a bad 97 engine and swapped in an engine from a 99. The problem was the connectors on the ECM side were all different and the solution was to just reuse the original wiring harness. You'll need to remove the intake manifold to get the injector wires off but it's pretty easy. I want to say it only took me an hour or so to swap the harness over.
EDIT: sorry, i missed the part where you said you cut the original wiring harness. You'll need a wiring harness from a 97 w/4wd. You should be able to find one at a junk yard.
Good luck!
1999 SR5 4x4 Auto for parts
2011 Camry SE V6
2011 Highlander Limited
thegipper is offline   Reply With QuoteReply With Quote
Old 10-10-2019, 12:28 PM #5
Yup, as others have confirmed, you would have had to swap the harness even if the engine was from a 4x4 Tacoma. There are significant ECU differences between '97 and '99.
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Old 10-11-2019, 10:45 AM #6
Thanks for the confirmation. Just wanted to make sure i knew which direction i needed to go. I have a replacement harness from my same year and 4x4 coming so i can do the swap. I replaced the injectors on the new engine so i should be able to get back in there fairly easily.
Learning as I go!
Thanks!
4x4 , engine , harness , sr5 , tacoma
Transfer case replacement issues TNFISHRMAN 4th Gen T4Rs 14 06-07-2019 03:34 PM
Transfer Case Flange Replacement PlanetExpress Classic T4Rs 4 03-30-2016 02:11 PM
WTS: 1997 Toyota 4runner Transfer Case OneMoreTime Classifieds - buy & sell (no commercial ads please) 0 04-10-2011 10:03 PM
Transfer Case Replacement gstai 3rd gen T4Rs 10 08-15-2010 10:50 AM
transfer case cooler replacement r1burden Classic T4Rs 7 05-15-2006 02:20 PM
