Old 01-18-2023, 10:00 PM #61
the_welfare_wagon's Avatar
the_welfare_wagon the_welfare_wagon is offline
Real Name: Rich
the_welfare_wagon will become famous soon enough the_welfare_wagon will become famous soon enough
Real Name: Rich
Originally Posted by Rushthezeppelin View Post
That's for the parking brake, I'm talking about the actual hydraulic brake line. There's a bracket on the frame that I've been told bending is a common mod with taller lifts so that you don't end up snapping that line at full droop which would be really bad.
The one on top of the pumpkin correct? I just took some pliers and it bent nicely but took a bit of force. I probably gained a couple inches of slack by doing this. Not the best way of doing things but it works. I run no swaybar and it’s fine for that. I can get up on 2 wheels and it’s not even tight.
96 Limited: 380k+ 255/85s Geolander MTs, Ironman Nitro 2" lift, Toytec 9602HD W/FJZ80 Shocks
the_welfare_wagon is offline   Reply With QuoteReply With Quote
Old 01-18-2023, 10:21 PM #62
Zhehan Zhehan is offline
Zhehan will become famous soon enough Zhehan will become famous soon enough
Whoops. My bad.
However, even at full droop with that suspension there is plenty of slack on that line. You need to extend the line if you want more slack. The only time I've maxed out that line is when I loosened both the upper and lower control arm connections at axle with the sway bar end links disconnected and let that droop. You will never get that much droop with everything connected as normal, even with the longer shocks.
2000 4Runner SR5 Manual Trans Federal Emissions - Eibach Pro-Truck coilovers, LC 7.5/Tokico Black, JBA UCA, SPC 25945 RLLs, Mevotech Supreme RULs, TrakMotive Xtended Travel CV Axles TO-8043ET, South Bend Rally Clutch, ES & Whiteline Bushings, MagnaFlow Cat-Back, Deck-Plate Mod, 4.56 Yukon Gears, Yukon Grizzly Rear Locker, Bushwacker Flares, 16x8 Wheels w/ 285/75 General Grabber AT2, 229K+ Miles
Zhehan is offline   Reply With QuoteReply With Quote
Old 01-19-2023, 02:31 PM #63
BTW any tips on bending the rear brake braket to get a little more wiggle room there? I think I'm fine on it since I'm not deleting my sway bar but I tried to bend it and it was a bear, think I only managed 10 degrees or so.
How long are your rear shocks? If they aren't much longer than stock, then don't worry about it. It is 'worst' at full droop, which is easy to check. The OEM swaybar doesn't limit rear articulation anyway... You can also get a set of lines with an extended rear line to deal with it (improved brake feel with stainless steel lines).
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Old 01-19-2023, 03:51 PM #64
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
I would recommend getting a longer rear brake line if you haven't already: WHEELER'S OFF-ROAD SINGLE REAR BRAKE LINE FOR 1995-2004 TOYOTA TACOMA AND 1996-2002 TOYOTA 4RUNNER - FROM STOCK HEIGHT TO 3.5" LIFT (TF BLINE-04)
7.5/8 , rear , running , springs , wrap
FS: 3rd Gen '99 Stock front springs and Bilstein 5100 shocks - Los Angeles(LAX), CA 4xBear For Sale: Suspension/Wheels/Tires 4 11-29-2018 12:28 AM
FS: 4th gen Bilstein 5100 rear shocks - $100 - Colorado springs, CO gaara46 For Sale: Suspension/Wheels/Tires 1 12-02-2016 04:39 PM
FS- Bilstein 5100 Front and Rear Shocks w/FJ Springs-NJ Scoward For Sale: Suspension/Wheels/Tires 4 08-22-2014 06:16 PM
*** wtb *** bilstein 5100 rear shocks 10ac Want to Buy/Trade 0 02-06-2014 09:52 AM
Front Bilstein 5100 shocks, FJ Springs, And Daystar 1.5" Rear Spacers Installed -Pics man03999 4th Gen T4Rs 39 06-12-2010 11:03 PM
