Old 10-10-2019, 02:07 PM #1
feelingstoned's Avatar
feelingstoned feelingstoned is offline
feelingstoned is on a distinguished road
Emergency Brake Light comes on when accelerating
My E-Brake light comes on when i accelerate and sometimes when i stop. Its been doing it every day but it only seems to be doing it when the car is cold. When it warms up the light stops. It was there before i did brakes (did all 4 corners) and after. The fluid is topped off. I can also hear a rattle coming from the handle when i'm at high way speeds. Anyone know a solution? the only thing i found on here was that it needs more fluid but its on max already.
feelingstoned is offline   Reply With QuoteReply With Quote
Old 10-10-2019, 03:18 PM #2
TheDurk's Avatar
TheDurk TheDurk is offline
TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light
TheDurk's Avatar
Maybe the float on your switch is stuck or has leaked. The switch may be effed up. Or there is is a wiring issue. I'd unplug the switch and bridge the connection. If the problem goes away, it's a switch issue. Test each component. If it doesn't, it's a wiring issue, possibly in the e-brake switch or associated wiring. Use the same procedure. The rattle may have something to do with this. So maybe you want to go here first.
If all that is ruled out, get an FSM and test your brake booster.
Or get some guesses and swap parts.
My Backyard Frame Swap
Old 10-10-2019, 03:22 PM #3
thennen's Avatar
thennen thennen is offline
thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold
thennen's Avatar
Is the e-brake light on the dash the same as the regular brake light?
thennen is offline   Reply With QuoteReply With Quote
Old 10-10-2019, 03:27 PM #4
TheDurk's Avatar
TheDurk's Avatar
Yes, one light, for e-brake, fluid, and booster fail.
Old 10-10-2019, 05:53 PM #5
Ok thanks i'll start there and see if i come up with anything. I have a feeling its a wiring issue
Old 10-10-2019, 05:59 PM #6
calimobber's Avatar
calimobber calimobber is offline
calimobber will become famous soon enough
calimobber's Avatar
Check the E-Brake handle. Does it change when you pull the E-Brake up and down?
Ive had the light act up and it was the E-Brake hande. Other time it was low fluid. The light came on when I gassed it or drove up steep hills when the fluid shifted and tripped the low fluid lght.
Turns out i failed to tighten one bleeder enough and it was slowly leaking.
My 2002 4runner Build : http://www.toyota-4runner.org/3rd-ge...r-project.html
calimobber is offline   Reply With QuoteReply With Quote
Old 10-10-2019, 06:48 PM #7
thennen's Avatar
thennen's Avatar
So how do we know it's related to the e-brake?
Old 10-10-2019, 07:39 PM #8
TheDurk's Avatar
TheDurk's Avatar
You don't. You eliminate each of the three possibilities in turn. It's called troubleshooting.
Old 10-11-2019, 11:15 AM #9
thennen's Avatar
thennen's Avatar
No need to be a smartass.
Old 10-11-2019, 12:33 PM #10
96RedRunner's Avatar
Real Name: Mark
Real Name: Mark
Lol, come on man being a bit sensitive today. @TheDurk has never let silly questions slide on the obvious.
Old 10-11-2019, 01:56 PM #11
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Everyone has good days and bad days. I thought it was funny. You cant take life too seriously, you never get out of here alive. .
Troubleshooting sometimes takes time and multiple steps. When it really gets interesting, is when the parts tests good but are still bad. We have lots of threads on here that users have had that happen too as well. Those are the head scratchers.
Old 10-11-2019, 02:49 PM #12
thennen's Avatar
thennen's Avatar
Not sensitive at all.
Old 10-11-2019, 03:14 PM #13
gamefreakgc's Avatar
Real Name: Jerod
Real Name: Jerod
My money's on the e-brake handle. I had mine do that once, it was one click off but wouldn't release all the way down so all I had to do was set the e-brake again then bring the handle down and push it to the resting position.
326WHP 347TQ
Old 10-11-2019, 10:45 PM #14
TheDurk's Avatar
TheDurk's Avatar
Try Pirate4x4.Com - The largest off roading website in the world.I'm sure you will find them more accommodating.
The response was appropriate to the question.
Old 10-11-2019, 11:36 PM #15
thennen's Avatar
thennen's Avatar
Don’t be upset, man.
coming , fluid , handle , hear , light
Emergency Brake Light appears randomly apwdweb 3rd gen T4Rs 28 11-23-2017 03:03 AM
ABS brake light comes on when accelerating Reinout 3rd gen T4Rs 15 03-17-2017 01:49 PM
Emergency brake light on (always) hulk311 Problems & Warranty Issues 5 01-08-2015 01:35 AM
emergency brake light blinks when I shift massamoo 3rd gen T4Rs 2 10-26-2013 10:27 AM
Emergency Brake light coming on while driving. Krazynative 4th Gen T4Rs 3 10-28-2012 09:47 PM
