10-10-2019, 02:07 PM
#1
Member
Member
Emergency Brake Light comes on when accelerating
My E-Brake light comes on when i accelerate and sometimes when i stop. Its been doing it every day but it only seems to be doing it when the car is cold. When it warms up the light stops. It was there before i did brakes (did all 4 corners) and after. The fluid is topped off. I can also hear a rattle coming from the handle when i'm at high way speeds. Anyone know a solution? the only thing i found on here was that it needs more fluid but its on max already.
10-10-2019, 03:18 PM
#2
Elite Member
Elite Member
Maybe the float on your switch is stuck or has leaked. The switch may be effed up. Or there is is a wiring issue. I'd unplug the switch and bridge the connection. If the problem goes away, it's a switch issue. Test each component. If it doesn't, it's a wiring issue, possibly in the e-brake switch or associated wiring. Use the same procedure. The rattle may have something to do with this. So maybe you want to go here first.
If all that is ruled out, get an FSM and test your brake booster.
Or get some guesses and swap parts.
__________________
'99 4Runner SR5 5spd 3.4L V6 4WD(U.S), original '99 Talls in front, OME 906s in back, Hella fogs, Trekmaster shocks in front, Billy in back, no running boards, FIAMM horns, Alpine sound, Michelin LTX M/S2's, owned since new.
'97 HiLux SW4 5spd 4WD(Japan model bought in Brazil assembled in Argentina, very close to a 3.0 4Runner/Surf)
'71 FordWillys Jeep CJ5 (with straight six Ford Maverick 3.0 liter engine--lives in the mountains north of Sao Paulo Brazil)
My Backyard Frame Swap
10-10-2019, 03:22 PM
#3
Senior Member
Senior Member
Is the e-brake light on the dash the same as the regular brake light?
10-10-2019, 03:27 PM
#4
Elite Member
Elite Member
Quote:
Yes, one light, for e-brake, fluid, and booster fail.
__________________
10-10-2019, 05:53 PM
#5
Member
Member
Ok thanks i'll start there and see if i come up with anything. I have a feeling its a wiring issue
10-10-2019, 05:59 PM
#6
Member
Member
Check the E-Brake handle. Does it change when you pull the E-Brake up and down?
Ive had the light act up and it was the E-Brake hande. Other time it was low fluid. The light came on when I gassed it or drove up steep hills when the fluid shifted and tripped the low fluid lght.
Turns out i failed to tighten one bleeder enough and it was slowly leaking.
10-10-2019, 06:48 PM
#7
Senior Member
Senior Member
So how do we know it's related to the e-brake?
10-10-2019, 07:39 PM
#8
Elite Member
Elite Member
You don't. You eliminate each of the three possibilities in turn. It's called troubleshooting.
__________________
10-11-2019, 11:15 AM
#9
Senior Member
Senior Member
No need to be a smartass.
10-11-2019, 12:33 PM
#10
Senior Member
Real Name: Mark
Senior Member
Real Name: Mark
Lol, come on man being a bit sensitive today.
@ TheDurk
has never let silly questions slide on the obvious.
10-11-2019, 01:56 PM
#11
Elite Member
Real Name: Jon
Elite Member
Real Name: Jon
Everyone has good days and bad days. I thought it was funny. You cant take life too seriously, you never get out of here alive. .
Troubleshooting sometimes takes time and multiple steps. When it really gets interesting, is when the parts tests good but are still bad. We have lots of threads on here that users have had that happen too as well. Those are the head scratchers.
Sent from my SM-J337V using Tapatalk
__________________
7 3rd gens listed in the build thread (2 are parts mobiles)
Build Thread: https://www.toyota-4runner.org/3rd-g...os-builds.html
Brillo's Bucket Fluid Ex changer: https://www.toyota-4runner.org/3rd-g...ml#post3358086
Sparks Plugs Wire and Coil Information: https://www.toyota-4runner.org/3rd-g...on-5vz-fe.html
10-11-2019, 02:49 PM
#12
Senior Member
Senior Member
Quote:
@ TheDurk
Not sensitive at all.
10-11-2019, 03:14 PM
#13
Elite Member
Real Name: Jerod
Elite Member
Real Name: Jerod
My money's on the e-brake handle. I had mine do that once, it was one click off but wouldn't release all the way down so all I had to do was set the e-brake again then bring the handle down and push it to the resting position.
10-11-2019, 10:45 PM
#14
Elite Member
Elite Member
Try Pirate4x4.Com - The largest off roading website in the world.I'm sure you will find them more accommodating.
The response was appropriate to the question.
__________________
10-11-2019, 11:36 PM
#15
Senior Member
Senior Member
Don’t be upset, man.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is On
