Old 10-10-2019, 03:36 PM #1
blairracd's Avatar
blairracd blairracd is offline
blairracd is on a distinguished road
blairracd's Avatar
Will a 2" lift from a non 99 still lift 2''?
We all know the 99 was the tallest, and I believe it's the 01-02 was the lowest(?). So, if a 2" lift came off an 02, will it still lift my 99 2"?
I feel sorta dumb, but at the same it kind of makes sense?
Please and thank you.
Living and breathing and bleeding Toyota
https://imgur.com/a/KvwQdyO
RIP my ‘96.
blairracd is offline   Reply With QuoteReply With Quote
Old 10-10-2019, 03:43 PM #2
Reinout's Avatar
Reinout Reinout is offline
Real Name: Reinout
Reinout will become famous soon enough Reinout will become famous soon enough
Reinout's Avatar
Real Name: Reinout
☺ If I'm not mistaken the only difference was the Springs between the years, the 1999 having a taller spring.
Example: If I put 1999 springs in my 1997, I'll have the same "lift" as the 1999.
And then there's always the argument that a 2" lift will depend on what your carry, bumpers, gear, etc.
1997 4Runner SR5- ~376k Miles and counting - 5 Speed E-Locker
2007 4Runner Limited V6- 165k Miles - Automatic - Brake Controller
2011 VW JSW TDI- 130k Miles - 6 Speed - Air Lift 1000
2006 Scamp trailer 16'
Reinout is offline   Reply With QuoteReply With Quote
Old 10-10-2019, 03:58 PM #3
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
Ask what the hub to fender measurements were and compare to what you are currently at. That's the only way to know for sure because springs sag over time so he may have gotten 2 inches because his springs sagged an inch and he then netted 2 inches of lift when it would have normally gotten him 1 inch if his original springs weren't sagging.
Old 10-10-2019, 04:00 PM #4
blairracd's Avatar
blairracd's Avatar
I see. That makes sense, but with that logic, if a lift lifted your 97 2'', but my 99 was already and inch taller than your 97, wouldn't it not lift me as much ?
RIP my ‘96.
Old 10-10-2019, 04:05 PM #5
Real Name: Patrick
Real Name: Patrick
Assuming stock factory heights (not sagging) then yes, it will lift a 99 1 inch less than a 97.
Old 10-10-2019, 04:20 PM #6
4runnerfiend's Avatar
4runnerfiend 4runnerfiend is offline
4runnerfiend has a spectacular aura about 4runnerfiend has a spectacular aura about
99 talls your at 21" ~ hub to fender
All others your at 20" hub to fender.
If you have a 99 with the talls you basically already have a 1" lift.
IG: @4runnerfiend- 1999 SR5: TRD Supercharger, ELocker, Wheelers T1 Coils-tundra 5100's, Built Right UCA's, LC 8 wraps-Fox 2.0 with CD adjuster, Rokmen lower links, Savage skids, Hot Metal Fab Front Tube bumper, Savage Rear tube bumper, TruckShopSD Sliders, DuroBumps, RidgeGrapplers, Doug Thorley Headers, yellow top, XRC 12k, ARB single compressor.
4runnerfiend is offline   Reply With QuoteReply With Quote
Old 10-10-2019, 07:27 PM #7
BrianK14 BrianK14 is offline
BrianK14 is on a distinguished road
The answer is, it depends. May lift you 1”, or 2”, or possibly even 3”. How much are your current springs sagged? How much wear and sag is on the 2” lift components? Only way to know for sure is to install and see what happens. All the lift manufacturers will tell you that individual results will vary.
BrianK14 is offline   Reply With QuoteReply With Quote
Old 10-11-2019, 11:11 AM #8
AntleredRuin AntleredRuin is offline
Real Name: Daniel
AntleredRuin will become famous soon enough
Real Name: Daniel
Pretty much, any original stock spring nowadays isn't going to be worth it.
99 Talls are 'code' for a certain height of spring when buying them new, but looking specifically for a '99 4Runner in 2019 because it'll be 1-2 inches taller is a waste of time. It'll be just as squat as the rest of the stock spring 4runners around.
An 01-02 that's been lifted 2 inches will be as tall as a factory height (read: good springs) stock 99. So if your 99 springs are original and your rear is dragging in the mud, then you should just restore your ride to factory height.
AntleredRuin is offline   Reply With QuoteReply With Quote
Old 10-11-2019, 01:43 PM #9
everyones experience with the above is different.
I have a 99 with 285k when I bout it the guy was sitting at 21" in front and 21.25 in rear. original springs. Now lifted on 5100. and I still use the same front springs set on 4 of 5 perches of the 5100. gives me 3" of lift and I run aftermarket skid plates.
Yes the rear didn't handle any weight with out sagging.
dumb , kind , lift , makes , sense
What rear shocks for 3" suspension lift + 2" body lift? austinmarti 3rd gen T4Rs 6 01-28-2017 04:10 PM
FS: 4th Gen 1" Toytec Body lift, 1" leveling front spacer lift mcwalke2 For Sale: Suspension/Wheels/Tires 6 02-05-2016 12:59 PM
Toytec 3" lift + 1.5" body lift (fender measurements) HWMTrustyChords 4th Gen T4Rs 4 04-21-2015 02:03 AM
Pic request: post up your pictures of a ~3" suspension lift + 1" body lift. 98LtdT4R 3rd gen T4Rs 4 12-07-2013 11:25 PM
