Old 05-20-2022, 10:36 AM #16
Masonchamby Masonchamby is offline
Masonchamby is on a distinguished road
Thank you for the post!
Masonchamby is offline   Reply With QuoteReply With Quote
Old 05-20-2022, 06:27 PM #17
19963.4lsr5 19963.4lsr5 is online now
They also make a banjo bolt replacement with an 1/8” NTP thread in the head also. Which measures the fuel rail pressure after the regulator.
19963.4lsr5 is online now   Reply With QuoteReply With Quote
Old 12-14-2023, 05:54 PM #18
DJRodriguez88 DJRodriguez88 is offline
DJRodriguez88 is on a distinguished road
What's the difference in measuring fuel pressure before or after the regulator?
I thought before the regulator would be constant and after the regulator would fluctuate with rpm/load
DJRodriguez88 is offline   Reply With QuoteReply With Quote
Old 12-15-2023, 06:18 PM #19
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
Regulator is vacuum dependent and therefore load dependent so before the regulator it should be fairly stable, but increase with engine load (and as engine vacuum decreases). I'm not sure if there's even a spec for post regulator measurements as that fuel is returned to the fuel tank.
Old 04-03-2024, 07:46 PM #20
Js'00imited4runner's Avatar
Js'00imited4runner Js'00imited4runner is offline
Js'00imited4runner will become famous soon enough
I'm not completely sure about your question..I was just putting this out there because their hadn't been any alternatives to checking fuel pressure besides the specialized union bolt for the fuel rail. I ended up dropping the tank and putting in a new fuel pump and it solved my issue with the lack of fuel. It read constant during idle and under very slow throttle input but as soon as I gave it anymore it would drop to like 10-15 psi.
2000 Limited 4wd Millenium Silver Metallic, E rear locker, KYB Monomax All around, '99 tall coils up front with daystar 1" spacer, OME 890's in back, Weathertech Floor and cargo Mats, Track decal shackle Brackets, Satoshi grill mod (wahoo), Diff breather mod, 200k+ and still going strong!
Js'00imited4runner is offline   Reply With QuoteReply With Quote
Old 04-04-2024, 10:57 PM #21
I ended up doing your mod. Works great thanks! 👍
check , easier , fuel , line , pressure
Fuel pump or fuel pressure regulator? ggrant Problems & Warranty Issues 4 09-29-2023 10:54 AM
'19 5th Gen Fuel pressure/fuel system mugenrios2k Engines / Suspension / Wheels / Tires / Audio / Accessories 2 03-25-2019 08:38 AM
Fuel pressure rodsrunner 4th Gen T4Rs 0 08-04-2018 01:30 PM
97 4Runner fuel tank building pressure/ wont take fuel Yotaoffroad27 3rd gen T4Rs 4 10-06-2015 10:34 AM
fuel pressure check '99 4 cyl. how to? triangles 3rd gen T4Rs 4 02-07-2015 07:37 PM
