Old 10-11-2019, 09:59 PM #1
Js'00imited4runner's Avatar
Js'00imited4runner Js'00imited4runner is offline
Js'00imited4runner will become famous soon enough
Easier way to check fuel pressure
Hey everybody! Just wanted to share a easier way to check your fuel pressure. If you head down to your local pick and pull and cut off the hard fuel line that goes to the rubber fuel line and basically run "two" fuel lines with a T barb in the middle with the gauge hooked up. Make sure engine is cool, relieve your fuel pressure by loosening the fuel lines to the filter. It's a easier way to tap into the fuel system without the specially made banjo bolt fitting. I was experiencing issues with acceleration and fuel delivery. So i plumbed this in and it would hold 44lbs at idle on the gauge and fall flat and sputter during heavy acceleration. Please be careful when purging the filter and fuel lines! DO THIS AT YOUR OWN RISK! I am not held liable for any losses. Good luck and Cheers!
Easier way to check fuel pressure-20191011_204918-jpg  Easier way to check fuel pressure-20191011_204843-jpg  Easier way to check fuel pressure-20191011_180251-2268x3024-jpg  Easier way to check fuel pressure-20191011_180259-1512x2016-jpg
2000 Limited 4wd Millenium Silver Metallic, E rear locker, KYB Monomax All around, '99 tall coils up front with daystar 1" spacer, OME 890's in back, Weathertech Floor and cargo Mats, Track decal shackle Brackets, Satoshi grill mod (wahoo), Diff breather mod, 200k+ and still going strong!
Js'00imited4runner is offline   Reply With QuoteReply With Quote
Old 11-07-2019, 12:19 PM #2
bump. Incase anyone is in need of checking their fuel pressure. Cheers!
Old 11-18-2019, 12:21 AM #3
If anyone is interested I could start making some of these up for pretty cheap. Since most pick and pulls only get like a buck a foot. Their would not be a gauge or T fitting included. Just the flared ends to screw into your fuel line and the bit of hose that runs to the T fitting. So far I think I should be able to make a few if anyone is interested. Not trying to make a whole lot of money. Just trying to help out some fellow t4r members because I know how the whole lack of fuel/stalling issue feels like.
Old 11-18-2019, 10:49 AM #4
BoomerBob's Avatar
BoomerBob BoomerBob is offline
BoomerBob will become famous soon enough BoomerBob will become famous soon enough
BoomerBob's Avatar
Would the t-fitting with Shrader valve be included or would we need to buy extra parts to make this work. I already have a fuel pressure gauge and prefer to use the same kind of valve I find on other vehicles.
2001 2wd - Daily Driver
BoomerBob is offline   Reply With QuoteReply With Quote
Old 11-19-2019, 10:20 AM #5
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
OP
Looks like no T valve...
Old 11-19-2019, 10:49 AM #6
BoomerBob's Avatar
BoomerBob's Avatar
Originally Posted by brillo_76 View Post
OP
Yeah; we worked that out via PM. Looks like my little $24 Amazon kit has one so...
https://smile.amazon.com/gp/product/...?ie=UTF8&psc=1
Old 11-19-2019, 06:47 PM #7
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Nice kit.. that T fitting sst shouldn't be hard to find.
@Booomer Bob you have that SST number handy.
I saw it in one of the treads and curious if i can find one. :-)
Last edited by brillo_76; 11-19-2019 at 07:18 PM. Reason: added a line plus fixed spelling mistake
Old 11-19-2019, 11:07 PM #8
Sparky 97Runner's Avatar
Sparky 97Runner Sparky 97Runner is offline
Sparky 97Runner will become famous soon enough Sparky 97Runner will become famous soon enough
Originally Posted by Js'00imited4runner View Post
Hey everybody! Just wanted to share a easier way to check your fuel pressure. Go down to a local pick and pull and chop off the hard fuel line that goes to the rubber fuel line and basically run "two" fuel lines with a T barb in the middle with the gauge hooked up. Make sure engine is cool, relieve your fuel pressure by loosening the fuel lines to the filter. It's a easier way to tap into the fuel system without the specially made banjo bolt fitting. This does work the fuel pressure gauge held steady at 44lbs during idle and the levels changed during acceleration/driving. DO THIS AT YOUR OWN RISK! I am not held liable for any losses. Good luck and Cheers!
Thanks for sharing J! I will have to make one of these.
1997 Toyota 4Runner
Sparky 97Runner is offline   Reply With QuoteReply With Quote
Old 11-19-2019, 11:50 PM #9
BoomerBob's Avatar
BoomerBob's Avatar
Old 11-20-2019, 01:15 AM #10
3.4L Fuel (?) Issue | Page 2 | Tacoma World
Besides the specialty SST fitting. This is the only other way to check fuel pressure. Or cut away at your timing belt cover to get a banjo bolt straight into the fuel rail. Or make one with a 90 degree bend in it. But even then their is very little if not no room to thread a banjo bolt into the end of the fuel rail. The system I have rigged up is nice because you could also plumb it in before your fuel filter as well to see what the pressure is before the filter. Just didn't see the point of trying to take the timing belt cover off, getting coolant everywhere and cutting away at the metal plate and butchering that all up. When its as simple as disconnecting the fuel line, reconnecting it with the same fittings/hose and a gauge inline and it works! As long as you can get that fitting loose to plumb it in you should be good.
Old 09-25-2020, 08:14 PM #11
DIY repair thread bump.
Old 05-12-2021, 09:57 AM #12
Grapejuicepapii Grapejuicepapii is offline
Grapejuicepapii is on a distinguished road
Does anyone know the sizes to these fittings?
Im trying to recreate this set up, but can’t find any info on those fitting sizes. Any help is greatly appreciated 😁🤙🏼
Grapejuicepapii is offline   Reply With QuoteReply With Quote
Old 03-05-2022, 01:36 AM #13
I went to a local pick and pull and cut the soft line fuel fittings inside the engine bay then disconnected them and just ran a piece of hose with hide clamps and you use that to extend your fuel lines and just add a pressure gauge with a T fitting. I haven't been on here in forever...man does time fly!
Old 03-05-2022, 01:37 AM #14
Yearly DIY thread bump!
Old 03-05-2022, 02:11 AM #15
balorf371 balorf371 is offline
balorf371 is on a distinguished road
Mass airflow sensor- check if that is dirty or defective.
O2 or air fuel sensors- make sure those aren’t lazy or defective.
balorf371 is offline   Reply With QuoteReply With Quote
check , easier , fuel , line , pressure
Fuel pump or fuel pressure regulator? ggrant Problems & Warranty Issues 4 09-29-2023 10:54 AM
'19 5th Gen Fuel pressure/fuel system mugenrios2k Engines / Suspension / Wheels / Tires / Audio / Accessories 2 03-25-2019 08:38 AM
Fuel pressure rodsrunner 4th Gen T4Rs 0 08-04-2018 01:30 PM
97 4Runner fuel tank building pressure/ wont take fuel Yotaoffroad27 3rd gen T4Rs 4 10-06-2015 10:34 AM
fuel pressure check '99 4 cyl. how to? triangles 3rd gen T4Rs 4 02-07-2015 07:37 PM
