Old 10-13-2019, 11:39 AM #1
Reinout's Avatar
Reinout Reinout is offline
Real Name: Reinout
Reinout will become famous soon enough Reinout will become famous soon enough
Reinout's Avatar
Real Name: Reinout
1997 4Runner SR5 with strange starting "issue"
I have searched for other posts with similar symptoms, but was unsuccessful.
Here's the facts:
1997 SR5
5 Speed
(Mods in the list, but this problem has always existed)
What is happening:
In order to start I have to MASH the clutch all the way down to the floor - Hard! and turn the key and it starts right up.
If I DON't mash the clutch down it won't make the connection for the starter.
What have I tried: The position of the clutch pedal sensor and when I had the carpet out I tried it then: NO difference.
Here's the thing: it starts up every single time without a problem (except the few times I've left the lights on)
What have I not tried: new or rebuild starter, replacing the clutch sensor.
What else could there be that would cause me to have to mash down the clutch in order for the connection to be made?
1997 4Runner SR5- ~376k Miles and counting - 5 Speed E-Locker
2007 4Runner Limited V6- 165k Miles - Automatic - Brake Controller
2011 VW JSW TDI- 130k Miles - 6 Speed - Air Lift 1000
2006 Scamp trailer 16'
Reinout is offline   Reply With QuoteReply With Quote
Old 10-13-2019, 12:06 PM #2
OrRunner's Avatar
OrRunner OrRunner is offline
OrRunner is on a distinguished road
OrRunner's Avatar
I would definitely start with the sensor. Doesn’t sound like a starter issue. There’s probably a way of checking the clutch switch in the fsm
OrRunner is offline   Reply With QuoteReply With Quote
Old 10-13-2019, 01:03 PM #3
brillo_76's Avatar
brillo_76 brillo_76 is online now
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
When it wont start. Make sure you in neutral and hit the clutch cancel start button and hit the key to start. If it always starts then you clutch switch on the clutch pedal is bad. From what you are describing that's it. However, the clutch is supposed to be all the way to the floor for that switch to activate. Might be able to adjust that some but mine all were that way on toyotas.
brillo_76 is online now   Reply With QuoteReply With Quote
Old 10-13-2019, 01:11 PM #4
Sparky 97Runner's Avatar
Sparky 97Runner Sparky 97Runner is offline
Sparky 97Runner will become famous soon enough Sparky 97Runner will become famous soon enough
Try starting it by using the clutch start cancel button without pressing the clutch in. It should start right up. If you've already adjusted the switch on the floor then the switch on the floor must be going bad.
1997 Toyota 4Runner
Sparky 97Runner is offline   Reply With QuoteReply With Quote
Old 10-13-2019, 05:56 PM #5
19963.4lsr5 19963.4lsr5 is online now
My Saturn clutch started do that a few months ago and then pushing it had stopped working. So I bypassed the switch with a jumper until I got a new switch for the clutch pedal.
I’d replace the clutch switch first or pull the connector out of it and jump the two terminals (same thing the bypass button does).
19963.4lsr5 is online now   Reply With QuoteReply With Quote
Old 12-16-2019, 12:18 PM #6
Reinout's Avatar
Real Name: Reinout
Reinout's Avatar
Real Name: Reinout
I find it a strange "phenomenon" because all the cars I've ever owned have been manual and none I've had to jam the clutch down to the floor like this.
I did come accross an older post that covers this so it sounds like this is a Manual 4Runner thing: Clutch start switch
Old 12-16-2019, 12:23 PM #7
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Almost all my standards I owned but 1 were Toyota. That switch didn't exist until the late 90s and early 2000s. My 83 and 87 didn't have that switch. It so someone dosent start it in gear. Probably became a safety requirement.
Old 12-16-2019, 12:29 PM #8
Reinout's Avatar
Real Name: Reinout
Reinout's Avatar
Real Name: Reinout
Thanks. I get the reason for the switch 100% and reading the other post it appears I'm not the only one ☺. I can live with that.
Old 12-16-2019, 11:10 PM #9
Kanoe's Avatar
Kanoe Kanoe is offline
Kanoe is just really nice Kanoe is just really nice Kanoe is just really nice Kanoe is just really nice
Kanoe's Avatar
5 cent fix for you.
I put a cabinet door self stick rubber bumper on mine. about 1/8 inch thick and 1/2 inch diameter. Just peel and stick to the blue plastic part on the clutch pedal that pushes the switch (pretty obvious). This moves the contact position up out of the carpet nicely but still does not fully bottom out the switch. As you have already seen, the switch position is not adjustable. 2 years on and still doing its thing.
-1993 Corolla Wagon 7AFE
-2001 Echo D.D.
Kanoe is offline   Reply With QuoteReply With Quote
Old 12-17-2019, 12:43 AM #10
photoleif photoleif is offline
Real Name: Leif
photoleif will become famous soon enough
Real Name: Leif
we were having similar problems with our '99 -- had to really really mash the pedal to the floor to start. as a temporary fix, added a thick rubber spacer to engage the switch sooner, and that was semi-sorta ok. most recently though i did with the 4R exactly as i did with my '95 pickup, which was to unplug that switch's lead, which means now to start it, that clutch start cancel button must be pressed. i've gotten so used to that in the truck (did that as a first line of defense kill switch) that i do it in the 4R anyway. so why not just unplug it for real (said i). this may be a great approach for you, if adding a spacer isn't a good option for you.
'99 'Highlander' 4R SR5 5VZ-FE | 5-spd | LED lighting | TBU | 265-75R17 Duratrac stuffed after some pinch-weld convincing
'95 Xtra cab 5VZ-FE swap 5-spd | 33x10.50-15 BFG AT/KOs | 4" Superlift | ARB rear locker | OME torsion bars | Total Chaos idler arm & uniball | Smittybilt bumpers | Sportsman topper | Aisin manual hubs | K&N | Dual Optimas | Extended diff breathers | Bilstein 5100s | De-striped | Hella pencil-beams
photoleif is offline   Reply With QuoteReply With Quote
clutch , connection , mash , starter , starts
My "solution" to the charcoal canister clicking and "thupping" issue Orion K 3rd gen T4Rs 3 04-07-2020 08:40 PM
strange steering "shimmy" issue keakar 4th Gen T4Rs 7 02-11-2018 10:31 AM
1997 4Runner BUILD THREAD "Ruby" SilentYoda3 3rd gen T4Rs 7 10-15-2013 01:14 AM
1997 4Runner says "check engine" rayban123 4th Gen T4Rs 6 04-02-2006 10:10 AM
